Opinion of the Bilstein 5100's
Discussion in 'Suspension' started by 4x4x4trd, Mar 18, 2008.
  1. Dec 5, 2008 at 4:37 PM
    #61
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can use the stock one if its in good shape.......i see no problem in doing so.
    thanks for the tips on the iac....i gotta go buy gaskets before i take the iac out.
  2. Dec 6, 2008 at 1:10 PM
    #62
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Ok. Got the top plates on and am trying to get these bitches back in. What is the bloody secret to getting the bolt in the lower mount???? That is without disconnecting everything and bolting it back up.
  3. Dec 6, 2008 at 2:38 PM
    #63
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if the top is still loose........good.....kinda needs to be a little loose. the bottom bolt will slide thru, but you gotta have some play in there. and yes............they can be a bitch man!!
  4. Dec 6, 2008 at 3:02 PM
    #64
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    One thing I have done in the past to get the suspension pushed down a little more is , VERY CARFULLY, use the factory bottle jack, place it between the fender and the spindle, and by hand, jack the spindle down a little bit. Also, make sure you have BOTH tires off the ground.
  5. Dec 6, 2008 at 3:26 PM
    #65
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Got it. Bolted up the top plate and then used my fat ass to push down on the spindle. I had my knee on the brake disc and kinda muscled it in. At the lowest setting on the front she sits about 1 1/2" higher. The back end not so much.
    Glad I got that done.
  6. Mar 7, 2009 at 5:32 PM
    #66
    Bassetdad
    Bassetdad What if God Smoked Cannabis
    Harrison, Ohio
    2001 De-Badged SR5 Access Cab 2.7 / 5m
    Access Tononu Cover AFE Pro-Dry S Drop-in Filter American Mag Wheels Bilstein 5100's Black Billet Grill Clear Taillights Perma-Tech sprayed Kennesaw Mountain Rear Bumper Michelin Tires PIAA Driving Lights PIAA Headlights Piaa Tail Light Bulbs Tinted Windows – 50% Toytech AAL URD Short Shifter Tranny - Mobil 1 Engine - Mobil 1 Custom Three Bike In Bed Rack New Toyota Undercoated Frame Clear LED 3rd Brake Light
    I'm taking my Tacoma in Monday morning to get the frame switch out. I bought my 5100's from Sonny & the dealer has no problem with putting them on for me.
    If I'm running 16" tires do I want to put the front setting on 1.75 & the rear.85 to even the truck out?
  7. Mar 7, 2009 at 5:54 PM
    #67
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Your rear shocks are not adjustable... And tire size has nothing to do with level. Lift on the other hand has something to do with size of tire you will be allowed to fit...
    Ohh, and what in the world is 16" tires:eek:
  8. Mar 8, 2009 at 9:15 AM
    #68
    bryan83taco
    bryan83taco Well-Known Member
    Hawai’i
    2023 TRD Sport 4x4
    Just ordered a set of rear 5100's. I tried the toytech shock extenders but they didn't look too sturdy to me when I put them on. I plan on putting bilsteins up front sometime soon.
  9. Mar 8, 2009 at 9:56 AM
    #69
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    What the hell is the frame switch out?
    I obviously know about the buyback but are they replacing the frame on some too?
    Also, is it worth it to put 5100's on the rear? I know this has been asked a hundred times but I just need to justify the extra cost. I have an 09 TRD sport and am getting a leaf added from the TSB. I am definitely putting 5100's on the front - set to 1.75. Just don't know about the rear.
    I would like to be off-road capable but do not plan on any serious wheeling. This is also a daily driver and may make a few 8+ hour road trips with the family - so I need a comfortable road ride too.
    I want capable but comfortable for under $400.
  10. Mar 31, 2009 at 9:11 PM
    #70
    TacoSter
    TacoSter Well-Known Member
    Chicago Burbs
    Had 08 taco, in a 4runner now
    http://www.bilstein.com/suvs_5100.php
    I read somewhere that the rears give up to 1"
    The link shows this to be true??? or am I reading it wrong?
  11. Apr 1, 2009 at 2:39 PM
    #71
    roxspin72
    NC
    Oh Yeah!!!
    Dont misread the chart:
    The fronts have 4 settings from stock - 2.5" lift
    Rear is just stating that they compensate for up to so many inches of lift. Believe the 5100 rears work with up to 2" lift...
    Hope this helps...:cool:
  12. Jun 9, 2009 at 2:03 AM
    #72
    Casper_k77
    Casper_k77 New Member
    Latvia
    06 PreRunner SR5 2WD
    Need your help and advise!
    I just got imported to Europe -Tacoma '06 PreRunner SR5 2WD Double Cab. Unfortunatly here in Europe we do not have Tacomas on the market that is why I can't get advice here.
    I am not sure what suspension is on my truck now ? The sticker on the side of the bed says TRD Off Road ? I am not sure cause shocks are not bilstein blue/yelow but shocks are black and I do not have alloy wheels, 115V/400-watt deck mounted power outlet, multi-function overhead console with compass and temperature gauge, engine skid plate? I am suspecting that it is stock regular suspension and somebody puted sticker on to show-off.
    Now my rear Left rear shock leaked out so it got to be replaced. I want to replace all 4 shocks on to 5100 bilstein. I want to have comfortable ride, cause my previouse ride was Chrylser 300C. I want to have smooth and comfortable ride. I am not doing any crazy off-roading .I am using my truck on street in the city mostly and and wods(hunting), gravel roads for transporting my four wheeler(Suzuki LTZ400). I am not using truck to carry really havy loads on daily basic. What would you suggest ?
  13. Oct 26, 2009 at 9:54 AM
    #73
    mchon
    mchon Member
    Los Angeles
    00´ Prerunner SR5
    BFG All Terrain 31X10.5 R15, Hella 500´s, Front Lightbar, Raptor Liner, Bilstein 5100 F&R.
    Hey i just got the 5100´s all around for my 2000 tacoma set the front at the higuest ring but it feels hard...i wanted to level out the truck and it looks good cuz its higher in the front do any of you know how the different ring measurements on the front 5100´s work? when i got them they were set to the middle height ...dont know if this is the right heigh to level it out and i screwed up going one higher or what? any comment is greatly appreciated.
  14. Jul 25, 2010 at 10:29 AM
    #74
    biggame
    biggame Member
    4x4 trd sport
    do you mind giving me your lift setup... Im new to lifts but i was planning on getting 5100's for the front and setting them to 2.5. It seems like you have the setup im looking for i want a lift that rides good but doesnt cost much
  15. Sep 14, 2010 at 4:39 PM
    #75
    Tacoma2nd
    Tacoma2nd Active Member
    06 prerunner
    2.5 inch coil spacer and rear add-a-leaf
    I just got a 2.5 inch spacer lift for the front and 1 inch add-a-leaf in the back. Its still not leveled out so i was gonna get the Bilstein 5100 adjustable shocks to level it out. Would this work or would it just be really bad for my truck?
  16. Sep 14, 2010 at 5:16 PM
    #76
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the billy 5100's would be alot better than a spacer man.
  17. Sep 14, 2010 at 6:28 PM
    #77
    Tacoma2nd
    06 prerunner
    i know but i already have the spacer and i dont want to take it off. i was wondering if you could have both at the same time
  18. Sep 14, 2010 at 6:53 PM
    #78
    roxspin72
    NC
    Oh Yeah!!!
    If you leave the Billies at stock... But the ride will be shitty compared to Billies set at highest level. IMO...
  19. Sep 15, 2010 at 1:42 PM
    #79
    Tacoma2nd
    06 prerunner
    damnit. the front of my truck isnt tall enough so i was just trying to see if i could level it out with the bilsteins. do you know anyway i could make it higher without getting rid of the spacer i already have on now.
  20. Aug 28, 2011 at 7:42 AM
    #80
    2007TacBorla4X4
    2007TacBorla4X4 Well-Known Member
    Bob
    Jax, FL
    TRD Sport 4X4 Short Bed
    Borla cat back, K&N cold air, Silver star bulbs, Nerf bars,NEW BFG, Weather teck windows, Flash light on the drivers seat, TRD off Road ft tow hook, Rear driving lights on bumper, Weather teck windows & ft bug guard, 4X4 switch glows, Windows tinted 20% sun shade
    Hey you guys thanks for all the info. I just traded in my 2007 SR5 4X4 in for a 2011 TRD Sport 4X4 then yesterday I put on the BFG 285-70-17, yes the mud flaps had to come off & its still rubs. So I will see who has the best deal 5100
