Opinions: 'ride quality' tsb-aal + tsb vs. 2" aal
Discussion in 'Suspension' started by bluevan99, Oct 23, 2009.
  1. Oct 23, 2009 at 8:13 AM
    bluevan99
    bluevan99 [OP] Active Member
    07 DC LB SR5 TRD Sport
    Jumpin on the group buy and just need to decide on my rear setup so i can order.
    Interested in good on-road quality primarily. need "1.5 lift in back after everything settles.
    What have people noticed?
    Thanks
  2. Oct 23, 2009 at 2:55 PM
    Brunes
    Brunes abides.
    Rotorhead
    Ride quality is subjective. If you don't have the TSB done yet...It's probably less hassle to get the 2" AAL...but it's your call.
  3. Oct 23, 2009 at 3:05 PM
    bluevan99
    Yeah i hear you there is no "right answer" for sure. I had one sales rep tell opinion that you should get more springs in the pack if you can with the tacoma, while another said the extra spring will make the back end ride really stiff unless there is a load. Anybody had a side by side experience? anyone with the tsb and tsb-aal think it's overkill (vs just the single spring aal)?
    Nice to see N. Fla represented, i lived there awhile back :D
  4. Oct 23, 2009 at 4:16 PM
    trd sport
    trd sport Well-Known Member
    queens,ny
    07 double cab trd sport
    I just picked up my truck yesterday from the dealership and had no problems whatsoever in getting the TSB done. What I can tell you is .GET IT DONE, the ride is like night and day! My truck has no more bounce and sits 1" higher, much smoother ride than before and do not feel the slap in the rear susp as I used to going over bumps. The truck makes a smoother transition over rough roads and this is without a load in the bed. Get it done you will not regret it-- plus it is FREE!
  5. Oct 23, 2009 at 7:09 PM
    bluevan99
    I appreciate that info. I don't have any problem with getting the tsb, rather i need/want a little more lift than the tsb so it becomes a question of one larger leaf or the tsb and a smaller leaf. Both will end up the same but will they ride similar? ahhh questions questions....
  6. Mar 21, 2010 at 5:53 PM
    wolfe0zero
    wolfe0zero opportunityisnowhere!
    David
    Irving, TX
    Black 09 Tacoma 4x4 TRD-Offroad shortbed
    Port installs: Borla exhaust Predator running boards Roof rack Bluetooth I-Pod interface Installed Toyota accessories: Bed mat J-hooks for bedrails Hood protector Aftermarket: Pioneer AVIC Z130BT Total Chaos UCAs Toytec ultimate lift kit Wet Okoles Arm rest mod Bed storage lock mod Stubby antenna Wade in channel deflectors Weathertech digital fit mats TYtoshi Grille Redline hood struts Waiting for install: Spidertraxx 1.25 spacers
    I'm in this same boat, anyone have a side by side comparison since they've released the AAL FOR the TSB vs just a larger AAL? Or should I just throw it all out and get a full leaf pack. :)
    Plan to do 3" level lift and have the TSB done already.
  7. Mar 21, 2010 at 5:58 PM
    Brunes
    Brunes abides.
    Rotorhead
    Any day of the week and twice Sundays I would recommend getting a whole new leaf pack.
  8. Mar 21, 2010 at 6:11 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I've never put an AAL on the Taco but from previous rigs I can tell you it always made it a bit more stiff, not necessarly worse; it's subjective like the others said but it is definitely not softer.
    Another option is a block. I usually stay away from blocks but after putting a 1" block on mine there was 0 change in ride from the rear and it doesn't have that 'blocked' look either. So a 1.5" block is an option for you if you like the feel of the rear now and/or don't need increased load capacity.
    If you don't need more flex for wheeling or increased load capacity a new leaf pack might just be a waste for you but it will always be the coolest option.
  9. Mar 21, 2010 at 6:51 PM
    wolfe0zero
    David
    Irving, TX
    Specifically what I was shooting for. :cool:
    No but seriously, assuming a new leaf pack isn't an option and I didn't want a block, annnnnd I hadn't done the TSB and had it to do over again...
    Advantages/Disadvantages to :
    Larger leaf vs TSB + smaller leaf is what I was looking for.. more along the lines of if anyone had tried both and noticed a significant difference between the two. I can assume that the leaf+TSB would be a stiffer ride than a larger leaf, but was looking for someone who could say first hand.
    But, I guess it really isn't a huge factor cause I'll likely end up going with a full leaf pack, but the price difference between a full leaf pack and a TSB + smaller leaf is significant enough to question it's worth.
  10. Mar 22, 2010 at 1:25 PM
    billas333
    billas333 They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    I have the TSB with a 1" block right now. I am thinking about going with an AAL though.
    Recommendations with the TSB? I see toytec has an $80 set of AALs.
    Anyone running AAL with a block?
  11. Apr 8, 2010 at 11:54 AM
    twr437
    twr437 Well-Known Member
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    nerf bars, bed cover, husky liners, Icon coilovers, LR UCA, rear 5100s, TSB AAL, diff drop, carrier baring drop, axel shims, AFE pro dry filter, BHLM, mesh grill, Black emblems,
    What are you measuring in the rear from hub center to bottom of fender with the 1" block and TSB???
