Optima Batt question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lIlOtAcO, Aug 25, 2010.
  1. Aug 25, 2010 at 7:35 PM
    lIlOtAcO
    lIlOtAcO [OP] Well-Known Member
    Chad
    Jax, FL.
    2010 S/C PreRunner SR5
    Brand FlippiN New
    Will putting a brand new optima battery that has 800 cca affect anything? I know its a bigger battery and all but just wanted to check.
  2. Aug 25, 2010 at 7:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It will make the truck start better.
  3. Aug 25, 2010 at 7:39 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    especially in the cold...:D
  4. Aug 25, 2010 at 7:41 PM
    lIlOtAcO
    Chad
    Jax, FL.
    Brand FlippiN New
    but no risk of frying the elec system. I know its a basic 12volt system but the starting at 800 amps is what i was worried about. And im in FL coldest ive seen is 40's in Feb
  5. Aug 25, 2010 at 7:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You'll be just fine. Im running one.
  6. Aug 25, 2010 at 7:44 PM
    T0LLPHR33
    BSP TRD Off-Road
    I'm running a 75 series Red Top...you'll be fine...
  7. Aug 25, 2010 at 7:45 PM
    Series1000
    Series1000 Well-Known Member
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    Lots
    I'm also running one, a yellow top.
  8. Aug 25, 2010 at 7:59 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I had the Red Top D34/78 with 800cca and it works fine in the Tacoma. I now have the Yellow Top D34/78 with 750cca and didn't notice a difference.
  9. Aug 25, 2010 at 8:23 PM
    lIlOtAcO
    Chad
    Jax, FL.
    Brand FlippiN New
    yeah that is what i picked up a D34
  10. Aug 25, 2010 at 8:25 PM
    lIlOtAcO
    Chad
    Jax, FL.
    Brand FlippiN New
    and 4 cyl no problems right?
  11. Aug 25, 2010 at 8:49 PM
    T0LLPHR33
    BSP TRD Off-Road
    ^shouldn't have a problem at all with the 4 cylinder...
  12. Aug 25, 2010 at 8:49 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    800 cca just means it can supply that much, your starter will still only draw what it needs, due to ohm's law and such, so no worries.
  13. Aug 25, 2010 at 8:53 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    Yall are running the D34?? I bought a yellow Top D34 and it didnt fit, took it to toyota they all said its too small. so i bought a $100 toyota battery and returned the 245 yellow top. I'll get a d35 next time
