Optima battery spacer / tray....by STREETACOS
Discussion in 'Street Trucks' started by Beefed Taco, Nov 23, 2009.
  1. Nov 23, 2009 at 9:55 AM
    Beefed Taco
    Beefed Taco [OP] Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    This allows you to get rid of the old acid dripper and run a Optima battery in the 95.5-04 Tacoma. It works with the OEM hold down clamp and will keep the battery from moving around under hard driving thanks to it's 4 side tabs, dowel pin and set screw tab. Available in silver or black finish and comes with stainless set screw so you can choose to do this extra step.
    #1. remove corrosive battery
    #2. remove plastic tray
    #3.drop spacer/tray into factory hole on inner fender
    #4.drill hole & screw in stainless set screw (provided)
    #5.install Optima & OEM hold down
    #6.say goodbye to checking battery water level and unwanted movement
    Tray $29.95
    USPS priority medium flat rate box w/delivery # $12.80
    Total $42.75
    I'm 100% against hammering customers when it comes to shipping.
    USPS
    flat rate is the cheapest & quickest method when compared to UPS & FedEx.
    PayPal info streetacos@hotmail.com
    Top
    Bottom
    from this
    to this!
