Optimism: 2021 will be better; Big 4 trail trip.
Discussion in 'Northern California' started by El Taco Diablo, Oct 26, 2020.
  1. Oct 29, 2020 at 8:43 PM
    #61
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    If your adding a hand throttle you might as well add dual line locks and a rear disco. My rigs not long enough to add the rear disco but with a Taco you should be able too.
    https://trail-gear.com/drivetrain/rear-disconnect-kit.html
  2. Oct 29, 2020 at 8:51 PM
    #62
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Already got my driveshaft shortened. Not about to do it again lol.
    Also those are only for gear driven T-cases. Not my chain case.
    Hand throttle is way easier. Mount shifter, run cable, connect to throttle body with DIY bracket
  3. Oct 29, 2020 at 8:56 PM
    #63
    theesotericone
    Bishop CA
    You just need an adapter to go from the chain case to gear drive pattern. Easy peassy.
  4. Oct 29, 2020 at 8:58 PM
    #64
    betterbuckleup
    Ian
    Concord, CA
    Got a mill I can borrow? Whip one right up :D
  5. Oct 29, 2020 at 9:01 PM
    #65
    theesotericone
    Bishop CA
    Better. lol
    Paging @eimkeith I figure you'll want a rear disco as well so might as well get you over hear. How's the flat belly going?
    eimkeith likes this.
  6. Oct 29, 2020 at 9:03 PM
    #66
    betterbuckleup
    Ian
    Concord, CA
    haha yea that and the other like 3 things I want him to make for our platform. Can we clone him? We need another @eimkeith to crank out more goodies for our trucks.
  7. Oct 29, 2020 at 9:07 PM
    #67
    theesotericone
    Bishop CA
    It was easier when he was only doing shit for 3rd gen 4Runners. Since he branched out to other Toyota platforms it's been harder to make him make things. lol
  8. Oct 29, 2020 at 9:16 PM
    #68
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Damn y’all are way too motivated, I am over here wondering if I’m gonna like put gas in my truck this weekend, My fuel light has been on for a week and a half so I stopped driving the truck
  9. Oct 29, 2020 at 9:19 PM
    #69
    betterbuckleup
    Ian
    Concord, CA
    :rofl:
    You finish your triple stick install yet?? That truck needs to see some action
  10. Oct 29, 2020 at 9:35 PM
    #70
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I need to pull the case and reseal it, it’s got a leak and then a new battery relocated and should be drivable:anonymous:
    instead of working on the truck I poured concrete today
  11. Oct 30, 2020 at 5:52 AM
    #71
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Ian. How much did you fork out for your shafts? I was charged 700. But it was also a full rebuild with a new CB.
  12. Oct 30, 2020 at 7:21 AM
    #72
    betterbuckleup
    Ian
    Concord, CA
    I paid like 340 I think for shorten and lengthen.
    U said you needed a new rear slip joint though and a carrier bearing.
    if they had to rebuild the rear slip joint, or fix the splines. That probably took up a good amount of cost. Pretty labor intensive.
    Who did the drive shaft work for yours?
  13. Oct 30, 2020 at 8:31 AM
    #73
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I think mine was about that much too
    Fernando[QUOTED] likes this.
  14. Oct 30, 2020 at 8:48 AM
    #74
    betterbuckleup
    Ian
    Concord, CA
    When you say a full rebuild, did they put in all new U-joints too? At that point I could see it costing that much.
  15. Oct 30, 2020 at 9:24 AM
    #75
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    mine was a retube for the front and a custom driveshaft for the rear all new parts ( he gave me a double cardin from a drive shaft someone returned)
  16. Oct 30, 2020 at 9:34 AM
    #76
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Yup. Full rebuild. Some shop in loomis that my fab guy uses. I'll get the name tonight IF i get my truck :bananadead:
  17. Oct 30, 2020 at 9:36 AM
    #77
    betterbuckleup
    Ian
    Concord, CA
    Hm. Yea when you start throwing new parts at it, cost will add up.
    My guy went from stock .065 to .095 I believe on the tubing since you have to cut it anyway.
    I asked if I needed new U-joints and stuff, but the OEM ones on there were still good so no need.
    Replaced the rear slip joint zerk though as I sheared mine off on a rock. Probably gonna do it again :anonymous:
  18. Oct 30, 2020 at 2:46 PM
    #78
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    I need one of those too. Or 2, maybe.
    What else would you like to see for our trucks?
  19. Oct 30, 2020 at 2:50 PM
    #79
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm totally waiting to see what comes from the coil bucket reinforcement you guys were talking about in the 1st gen thread.
    eimkeith[QUOTED] likes this.
  20. Oct 30, 2020 at 2:51 PM
    #80
    eimkeith
    J Keith
    I do have the patterns worked out for the chain & gear cases....
    Flat belly had a hiccup today - I rejected the entire run of transfer case clocking plates (they were tapped for 5/16-18 instead of 8x1.25.) BUT, I'm also talking to both an American and a Japanese company about making the splined couplers (once I verify the length of the stock automatic coupler) - so that's cool.
    Once that stuff is sorted, I'll start making steel prototypes of the crossmember, and then we're off to the races, so to speak.
