Ordered this and hoping it works for a different purpose.
Discussion in 'Lighting' started by ToyotaKTMracing, Sep 9, 2012.
  1. Sep 9, 2012 at 6:07 PM
    ToyotaKTMracing
    ToyotaKTMracing [OP] The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    I bought a dome light led panel like this and was wondering that if I cut the wires, that I could hook it up to the fuse box to come on with my parking lights/head lights. Is it possible and will it work? I have a certain project to do with it and these lights would work perfect for it.
    http://www.amazon.com/BestDealUSA-W...8943&sr=1-1&keywords=BestDealUSA+12+led+panel
    EDIT: IF YOU'RE SMART AT WIRING, READ POST #26 AND HELP ME
  2. Sep 9, 2012 at 6:21 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Light expert people, help out :D I'm guessing it would work. Wouldn't see how it couldn't but I want to make sure.
  3. Sep 9, 2012 at 7:10 PM
    ToyotaKTMracing
    Shay
    West Virginia
  4. Sep 9, 2012 at 8:11 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I would if I could find one small enough. Whenever I get the light here, and get the mod hooked up, you'll see why. It's just a simple mod I wanted to try. Hoping it will be cool enough to be a sticky. Guess we'll see.
  5. Sep 9, 2012 at 8:15 PM
    beckleyota
    beckleyota Well-Known Member
    wv
    o7 taco
    vent visors,tint,kenwood headunit, trex eyelids,kenwood componants,5100's,1 aal,cabellas seatcovers,painted stereo suround
    I wouldn't think u would need a relay n fuse unless you would b running it for extended periods of time I'm sure it has little power draw
  6. Sep 9, 2012 at 8:19 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I'm creative with lights and stuff and I hope it's cool enough to where people will want to do the mod too and where people you drive by will stare. It's a secret so no one will steal my idea. :D
  7. Sep 9, 2012 at 8:21 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
  8. Sep 9, 2012 at 8:22 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The parking light fuse is located in the underdash fuse panel to the left of the steering wheel. It's only powered when the parking lights are turned on.
    Buy one of these:http://www.ledunderbody.com/Add-A-Circuit-and-4-Amp-Fuse.aspx?gclid=COTjvP2GqrICFWWCQgodPBsAXQ and use it to connect the red wire on that LED panel to the parking light fuse. Then attach the black wire to a good ground.
    Locally, our Autozone has the best price on the add a fuse. Around 7 bucks. NAPA is twice that. Thieves.
  9. Sep 9, 2012 at 8:24 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Well update this thread when you get it done! I'll be subbed.
  10. Sep 9, 2012 at 8:25 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Well there's that way or just run the positive wire into the fuse slot with the fuse. Either way works. I've done just running the wire into the slot.
  11. Sep 9, 2012 at 8:28 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Just make sure you end up with a fused wire to run your accessory on. Depending on which side of the fuse you attach the wire to, the existing fuse may or may not protect your added circuit.
  12. Sep 9, 2012 at 8:30 PM
    ToyotaKTMracing
    Shay
    West Virginia
    True. Maybe I'll just get one of the add a fuse for this :rolleyes:
  13. Sep 10, 2012 at 10:41 AM
    ToyotaKTMracing
    Shay
    West Virginia
    Will I need anything to hook it up with? Or just straight to the fuse and ground it?
  14. Sep 10, 2012 at 11:10 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    You don't need a relay, (those are for turning on "big" power) LEDs draw almost nothing. From the pic, it appears that all you need is source (12 volt positive, fused) and a ground.
  15. Sep 10, 2012 at 11:12 AM
    Aw9d
    Aw9d That one guy
    This is all you'll need.
  16. Sep 10, 2012 at 11:14 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
  17. Sep 10, 2012 at 11:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just tap into the parking light power wire under the hood. I believe it's a green wire going to the parking light but a test light will confirm (also not sure if different colors were used for different years). The little bit of extra draw from that LED won't blow the fuse and it'll be fuse protected with the parking light fuse.
  18. Sep 10, 2012 at 1:48 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Okay
  19. Sep 10, 2012 at 1:53 PM
    ToyotaKTMracing
    Shay
    West Virginia
    And FYI, this mod will only work with stock grills. Sorry about satoshi owners, but hey, you can always get an idea like this to go with a satoshi grill too. Everybody will just have to wait and see. :D
  20. Sep 10, 2012 at 2:08 PM
    2000GTacoma
    Snow Hill NC
    Back lit toyota emblem
