Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Dec 9, 2019 at 7:33 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    hey guys, i have an ongoing driveline vibe issue.
    had a block lift, then switched to deaver springs, archive hangers, and an 8.4 with 4:10's and a trutrac. sweet! then i had mid travel kings installed. vibe issues. driveline tuned at drivelines northwest, vibes. bought a digial angle finder, measured, thought i was only 2* out and installed 2* shims. VIBES, still. bought a tracbar soon to be installed by my man @JimSnell . need feedback. do i get the angle perfect before tracbar install?? i totally trust jim to do ace work as he has for me many times. but we are both treading new ground as i mod fast and aggressive. any help or guidance would be fantastic. currently i think im within 1* but have bad vibes 0-20mph. slight after that.
  2. Dec 9, 2019 at 9:48 PM
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    I think you have two options.... Take out the batteries, or turn it off. :anonymous::anonymous::anonymous::anonymous::anonymous::duh:
  3. Dec 12, 2019 at 10:04 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Got another cortisone shot in my knee today. Holy crap, that needle was huge with no anesthetizing. Puncture wound is about 1/16" long.
    Also gave me a shiny new walking stick.
  4. Dec 12, 2019 at 11:14 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Honestly, a Trac bar is just a bandaid to vibrations and doesn't solve the real issue. If you're having wicked axle wrap, then a Trac bar would be beneficial. Where are you feeling the vibrations? Steering wheel? The seat? At certain speeds or rpms? Are you still running the 2 piece drive shaft or did DLNW set you up with a one piece? Did they phase the drive shaft correctly? Have you tried different wheels or tires? Sounds like you've changed everything but the wheels and tires. If the wheels and tires are the only thing that stayed the same, I'd try to rule those out by running a different set to see if anything changes.
  5. Dec 13, 2019 at 8:44 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    I didn't see U-joint or carrier bearing in that list.
    I replaced my carrier bearing with the Inner Empire one that is poly, not the OEM rubber one that cracks.
    Also, when replacing the carrier bearing, I was diligent on making sure the phase was correct by using my daughter's Hello Kitty pink finger nail polish to mark alignment lines. Once installed, the squealing of the u-joint was clear as were the vibrations.
    The 3rd member u-joint at the pinion was bad....ovaled… blocked... yeah.
    bobsuruncle[QUOTED] likes this.
  6. Dec 13, 2019 at 8:47 AM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    This carrier bearing
    IEDLS
    bobsuruncle likes this.
  7. Dec 13, 2019 at 12:20 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    That would have been next on my list of amateur diagnostics depending on if he's one piece or 2. Also if the carrier itself has been shimmed.
    Do you know how long I've been trying to buy a poly carrier??!!!!!? :goingcrazy: so long that I gave up. I've read several threads on them but all links dead ended. :bananadead:
    Do the 1st and 2nd gen share the same CB?
    :bowdown:
    I'd like to think if he had dlnw build one for him they used new and quality ujoints so I'd hope they are good. Ujoints can be deceiving some times. They look good from the outside since the caps can be fine, but the needle bearings and shit housed. You don't know until you remove it.
  8. Dec 13, 2019 at 1:53 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    the links are dead but the website should be active = here
  9. Dec 13, 2019 at 9:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Bob, buy mine! It's from the original IEDLS group buy. I never did anything with it. Still have it, still in the box.
  10. Dec 13, 2019 at 10:58 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Pm incoming
    Digiratus[QUOTED] likes this.
  11. Dec 15, 2019 at 10:23 AM
    andesite
    andesite creeper
    Brian
    Mosier, Oregon
    2.7L 5MT 2011 ACLB
    2.5” Radflo coilovers | Demello armor
    Anybody else experience a head gasket failure? Last night at the I-5 Donald/Aurora exit. Have about 180k on my 2.7L. What should I expect?
  12. Dec 15, 2019 at 11:33 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    What were your symptoms? I've had head gasket failure on my older Toyota trucks, but not my Tacoma.
  13. Dec 15, 2019 at 12:14 PM
    andesite
    andesite creeper
    Brian
    Mosier, Oregon
    2.7L 5MT 2011 ACLB
    The cabin heat going out intermittently over the past couple weeks was the first sign. After topping off the coolant the problem persisted, so I wasn’t thinking it was a loss of coolant issue.
    Around Troutdale my temp gauge shot up into the red, then dropped back down to cold. The truck was running fine, no rattling or loss of power. I was like wtf? Is it just a sensor problem? I cautiously drove down Sandy Blvd and back onto the interstate in Hollywood. Again, the pedals are telling me nothing is wrong with the engine. First sign of a problem was around the Canby exit and I had to downshift up an incline I normally don’t need to. A minute later shit (and coolant) goes sideways and I’m stalled in the middle of a busy intersection.
    In hindsight, it reads like an NTSB report of pilots disregarded or misinterpreted every sign they’re about to crash. I have animals at the farm in Albany. Trucks can be replaced much easier than lives, so sometimes I gotta keep driving, even if I shouldn’t.
  14. Dec 16, 2019 at 7:39 AM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    FTFY
  15. Dec 16, 2019 at 10:28 AM
    CBenfell
    CBenfell I don’t know sh*t about f*ck
    Christian
    Western Washington
    21 DCSB TRD OR Midnight Metallic Black
    Crippling Debt
    Is anybody on here a hook up for things...Glock related?
  16. Dec 16, 2019 at 11:01 AM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    Pew Pew
  17. Dec 16, 2019 at 5:45 PM
    CBenfell
    Christian
    Western Washington
    Crippling Debt
    Hey thanks
  18. Dec 17, 2019 at 3:57 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    *****NOT FROM CA*****
    Hey every one, I am going to be interviewing on the 30 or 31st for a job in Albany and have a few questions about the area:
    Where should I be looking for a house? We do not have kids and dont plan on having any. I am assuming salem? Looking for a 300k house in a nice neighborhood, having some land would be even better. Yes I have done some researching of house prices, so the land would be a long shot LOL. Any areas to avoid?
    I have a solid axle Tacoma on 37s that I'll be bringing with me if I get the job, how easy will it be to register it?
    There is no weird state inspection or anything like that?
    The trucks "legal" here in Illinois so I assume it would be ok out there.
    How active is the Tacoma/toyota wheeling community? Any clubs?
    *****Thanks in advance, I'm not from CA so I assume I'll be ok there LOL!!*****
    JDAM, toucan and Toywoodsguy82 like this.
  19. Dec 17, 2019 at 4:54 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
    2013 DC offroad MGM. 2012 Super White SR 4x4 RC
    SCS/Bilstein/Icon/JBA/ Relentless/ATH/Smittybilt/Meso/Mobtown/Archive Garage/BAMF/Pioneer/Rockford Fosgate/Sundown/Wet Okole/Spiker Engineering/I'mMr.Yo/RAMMounts/Softopper/Weathertech/Factor55/Morel/DD
    Where are you interviewing, if you dont mind? I am in Albany.
  20. Dec 17, 2019 at 4:58 PM
    slander
    Hickory, NC
    I'll keep it underwraps for now incase someone else on here is interviewing as well, dont need someone dredging up my TW history and using it against me LOL!!
