Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Apr 22, 2012 at 9:04 PM
    #9301
    Bobert14
    Bobert14 [OP] .
    Yea, its supposed to clean out the system. Earlier in the year I ran some through the vacuum lines, motor oil, and fuel system and the truck idled a whole lot lower rpm for awhile and ran a bit smoother. It pours white smoke like a frigging mofo at first. I think the entire neighborhood put me on their shit list for life.
  2. Apr 22, 2012 at 9:27 PM
    #9302
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Mine beeps either in 4HI or 4LO. I believe it has to do with either the VSC, or the Auto LSD working overtime. It is a very rapid beeping sound when one the rear wheels is slipping or spinning faster than the other.
    I'll have to read and try to dig up a mod for it. I have already disabled the alarm fob beep and seatbelt chime...don't know why I have done this yet.
  3. Apr 22, 2012 at 9:42 PM
    #9303
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    When I got home this morning I had to get something out of my attic so I stood in the bed o ft he truck. Holy fuck was the rear suspension squeaking. Every little move I made the leafs squeaked. Fuckin annoying. I'm stock in the rear right now. 2 weeks ago it was in the dealership for 80,000 mile service. Anyone elses shit squeak?
  4. Apr 22, 2012 at 9:45 PM
    #9304
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Got my tires mounted today...another surprisingly awesome experience with a corporate company :)
    Out the door @ Costco for $60.87. 4 tires mounted and balanced filled to 35 psi with Nitrogen. I got to hang out while they were working on it and like usual, just got to bullshitting with the guys. All of them loved the Taco, made one guy regret selling his '88 yota (fully framed/tubed w/ 44" IROKs). He showed me some pics of it playing at Tahuya, and told me to check out the new boulder garden up there (maybe :eek:).
    Really happy with the tires! They are considerably more quiet than I expected, and track well on their own. Will need to get an alignment soon, but everything is pretty straight and true. Now I just need to get them dirty and see how they perform...:mudding:
    No rubbing while street driving, but I will definitely have to do some trimming up front, like that damn bowl (?) on the bottom front-side of the front wheel wells. I hate that thing, why is it even there??? Didn't get to test them off road, so excuse the typical warehouse pics, but it's right near my house and keeps the continuity of my progress pics.
  5. Apr 22, 2012 at 9:51 PM
    #9305
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Looks Good Ben!!!
  6. Apr 22, 2012 at 9:54 PM
    #9306
    Mitch
    Mitch
    Spokane, WA
    Looks really good. Did you buy them from Costco? When I was trying to get my tires mounted Costco told me they wouldn't do them unless I bought the tires from them. Supposedly some corporate shit
  7. Apr 22, 2012 at 10:03 PM
    #9307
    Mitch
    Mitch
    Spokane, WA
  8. Apr 22, 2012 at 10:04 PM
    #9308
    NetDep
    NetDep Well-Known Member
    Tim
    Southern Utah
    2011 Toyota Tacoma Off Road MGM
    How much and what lift did you go with!! Your truck looks amazing!! Very clean and well done!! Lots of ideas there!!
  9. Apr 22, 2012 at 10:31 PM
    #9309
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Ben has all the VSC type stuff that beeps when it senses wheel slippage. Really annoying when your whole idea is to get the wheels slipping in sand, or if you don't care (offroading).
    Lots of different wire mods, here's this one on ABS disable, I suggest read the first post then skip all the way up to post 70 and read from there. I didn't read to see if the theory regarding the locker-equipped trucks had a solution, but I don't have a whole lot of problems with the ABS.
    Here's the yellow wire, which is giving you ATRAC-like capability in 4LO for trucks that only have TRAC.
    A few tips:
    -portable units don't work nearly as good as window units. I've got a 12k BTU portable unit that can't keep up with my old window unit that was something like 900 BTU. This might be different now (I bought 3 years ago)
    -Make sure you know how many BTUs you need for your room. If you get a portable, over-estimate by a ton.
    -getting the biggest possible unit is not always best, it can cause it to cycle too much. Same deal for too small, too small never shuts off.
    -keep in mind that A/Cs take up a ton of power. You might be tripping breakers a ton, don't be surprised if your place can't handle it.
    -on portable units, get one that has two hoses, an inlet and an outlet. More efficient and doesn't create as much condensation to empty.
    -Keep a lookout on the energy efficiency. Some of the cheap units can cost a butt ton to run and end up costing you more in the long run.
    -Having a remote kicks butt.
    -If you can get it where it has a timer for stuff like shutting off after a few hours, turning on at certain times, etc., that's good stuff. Helps when going to bed and nice to have it on a few minutes before you get home.
    -The very best feature is units that have self-adjusting speeds. When the room lowers to a certain temperature, the unit will either drop the fan speed, or (if it's a really good unit), stop blowing. Make sure this feature works with the A/C portion on!!! My stupid unit only does this with the dehumidifier portion :mad: which is a useless setting.
    My friends and I have bought our last 4 units at Sears and have had good luck. The Kenmores seem to be really good. My current unit is the Soleus 12k. It works, but it was about the only real good unit on the market at that time. I expect there's better units now. The portability sure is nice, I usually have it in a bedroom or computer room, but wheel it to the front room during a get-together. Note that it's still a heavy pig and not something girlfriends are going to want to push - they will make you do it.
    I've never had to drain my unit, it evaporates too fast.
  10. Apr 22, 2012 at 10:35 PM
    #9310
    Chickenmunga
    Keizer, Oregon
    Oh, and nice job Ben!
    Do they do alignments at Costco? Need to see the price... I've been hearing Schwab is starting to be kinda crap since the Old Man died :(
  11. Apr 22, 2012 at 10:36 PM
    #9311
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    You sir are like a walking Almanac of information on all sort of things +1
  12. Apr 22, 2012 at 10:39 PM
    #9312
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Adam! Looks extra good cuz I got 'er all purdy today, and gave her bath :D
    Nope, got 'em from a private seller. Read about it HERE if you're interested, it's a good story of wits and luck. I think they have to ring it out as a "Seasonal Tire Swap" to adhere to their corporate policies. That's what the guy eluded to anyways. It wasn't a problem that I didn't buy them there.
    Costco was the 3rd place I called to get quotes (actually at my girlfriend's suggestion) and by far the coolest, cheapest, and least arrogant. They also laid to rest the myths regarding mixing Nitrogen and Oxygen in your tires.
    Discount = $180 + and wouldn't touch them if I had wheel spacers
    Les Schwab = $90-$120
    I don't have a build thread (yet), which is actually good for me and you guys, cuz that shit would take me like a month to complete, and the reader a week to decipher my run-on sentence rants...:p
    Here's the gist of it: OME 885 Coils w/ 90k Nitro Shocks up front, OME N182 Shocks and Dakar Leafpack in back, Light Racing UCAs, 1/2" Toytec Front Spacers, 1" Low-Range Off-Road rear blocks, swaybar relocate, (4) 1" BORA Wheel Spacers, 285/70R17 Goodyear MT/R (old style)
  13. Apr 22, 2012 at 10:44 PM
    #9313
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Mike! I didn't check to see if they do alignments :facepalm:but that is in the very distant future for me as well. I will definitely be going there again if they do. Jason, Marty and Brian were all really helpful and knowledgeable.
  14. Apr 22, 2012 at 11:05 PM
    #9314
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Firestone might still be doing lifetime alignments.
  15. Apr 22, 2012 at 11:42 PM
    #9315
    Mitch
    Mitch
    Spokane, WA
    I think I ended up calling 15 shops to get quotes for my tires. Ended up finding a place that on their website said they had a deal to put on snow tires. 40 bucks out the door. I showed up. They put them on. Asked if they were snow tires because "those sure don't look like snow tires". I pointed to the snow flake and smiled. Gotta love those Duratracs snow/mud :D:D:D:D:D
  16. Apr 22, 2012 at 11:51 PM
    #9316
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Extreme weather tires!!! Those are definitely snow-worthy.
  17. Apr 22, 2012 at 11:54 PM
    #9317
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I might look into that, it's usually between $150-$180 for the lifetime, but some have gotten it for as little as $120. I will have to check out the local Firestone to get pricing and see how legit they are. :thumbsup:
  18. Apr 22, 2012 at 11:55 PM
    #9318
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I wish i had lifetime alignments I've gotten 4 of them in the last 3 months
  19. Apr 23, 2012 at 12:08 AM
    #9319
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Shit man...well, I guess you do wheel across canyons in the earth
  20. Apr 23, 2012 at 12:13 AM
    #9320
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I just like the lifetime because if you get at least 3 alignments over the course of you owning that vehicle, it pays for itself. I get alignments every few months, so it more than paid for itself already. :)
