Oregon/Washington Craigslist Ads
Discussion in 'North West' started by Mitch, Oct 20, 2012.
  1. Nov 16, 2018 at 8:49 AM
    #9921
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    If the voltage isn't enough a bigger wire will allow still more juice is what I meant
  2. Nov 16, 2018 at 8:51 AM
    #9922
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Yeah, and please everyone know I'm not trying to diss on anyone's setup or brand. Just wanted to mention here what i've found from researching a bit on here and other forums. I did a LOT of reading before finally purchasing a couple batteries for my setup. I know a lot of people hate Optimas for example, but I went with them simply because my friend has had good luck, and he was the one that did most of my wiring.
    Please take the info given however you like :thumbsup:
  3. Nov 16, 2018 at 8:57 AM
    #9923
    YF_Ryan
    Kent, WA
    That would definitely give less loss, but the tacoma alternator still has a maximum voltage it puts out, which is not in the suggested charge range for the battery in question. It sounds like you might be able to put in some ?diode? that tricks the truck into pumping out higher voltage, or possibly just max voltage, longer but... shrugs*
    I'll leave this alone now, getting a little off topic. If anyone would like more information please feel free to do a little googling on the subject and searching on the forum.
    Thanks all!
  4. Nov 16, 2018 at 9:22 AM
    #9924
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There are two main issues. One is, as mentioned, AGM type batteries require 14.7VDC to get fully topped off and be healthy. The 2nd issue is the alternators in 2nd and 3rd gens are designed with fuel economy in mind. They are purposely made to charge based on load demand and by default will not have an output at much over 13.9-14VDC.
    In this case bigger wire will not change the output of the alternator. However, there mods out there that remove the output voltage restrictions on the stock alternator systems and will allow them to charge at a much higher rate. IIRC, some are getting rates as high as 15VDC.
    https://www.tacomaworld.com/threads...ts-see-them-multiple-batteries-thread.295653/
    It is a big thread, but there is a lot of good info about all this stuff in here.
    bobsuruncle and YF_Ryan[QUOTED] like this.
  5. Nov 16, 2018 at 9:42 AM
    #9925
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    18 LX570 on 35s, 06 Tundra DC beater
    Literally pallets of them. Dude said 3-400
  6. Nov 16, 2018 at 10:06 AM
    #9926
    constar
    constar Member
    Conor
    Stock Stick Shifter '14
    Dog, stickers.
    Hey gang, is it out of line to ask for someone with the 50 previous posts to boost my craigslist ad?
  7. Nov 16, 2018 at 10:10 AM
    #9927
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Yes, that's against the rules. We had an individual come in here and get on our case about a similar scenario and got this thread temporarily shut down. However, if you mention what you're selling and it's a good deal... I might just happen upon the ad and post it up. No promises.
    cemented likes this.
  8. Nov 16, 2018 at 10:10 AM
    #9928
    YF_Ryan
    Kent, WA
  9. Nov 16, 2018 at 10:11 AM
    #9929
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
  10. Nov 16, 2018 at 10:11 AM
    #9930
    constar
    constar Member
    Conor
    Dog, stickers.
    Right on, thanks for the heads up.
  11. Nov 16, 2018 at 12:54 PM
    #9931
    360joules
    360joules FWC Stalker
    Troy
    Portland Oregon
    SOLD
    Just putting this out there...
    I bought a set of 4 black matte SCS F5 wheels - 16x8 with 0 offset. I haven’t even opened the boxes but you can see the details and the date on the receipt.
    I decided to go with Stealth6’s instead. I’m hoping to get my money back from someone who wants instant gratification, or trade for stealth6’s in gunmetal. :)
    PNWTacoma likes this.
  12. Nov 16, 2018 at 12:58 PM
    #9932
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    I saw the thumbnail on the main page and had hope it was the Stealth :) Good luck with the sale.
  13. Nov 16, 2018 at 1:00 PM
    #9933
    JoeTacoma02
    Yes, way out of line! Whatcha selling :D
    Benzdriver81 likes this.
  14. Nov 16, 2018 at 1:24 PM
    #9934
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
  15. Nov 16, 2018 at 4:11 PM
    #9935
    Enehmee
    Enehmee Active Member
    Chase
    2018 White Tacoma TRD OR
    Pm sent
  16. Nov 16, 2018 at 4:13 PM
    #9936
    Digiratus
    Roaming the PNW
    The RedHead
    @turbodb
  17. Nov 16, 2018 at 4:27 PM
    #9937
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    cemented[QUOTED] likes this.
  18. Nov 16, 2018 at 7:52 PM
    #9938
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Welcome to TacomaWorld!
  19. Nov 17, 2018 at 2:37 PM
    #9939
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  20. Nov 17, 2018 at 2:41 PM
    #9940
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
