ORI-Struts Available from BAMF
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jan 7, 2013.
  1. Nov 3, 2013 at 3:31 PM
    #181
    BradyT88
    BradyT88 Well-Known Member
    So is this not happening now? Or did Wicked just not want to run limit straps? I was under the impression you were going to put a longer top hat on to move the shock lower so that is would bump out just before you get metal on metal at the OEM strike plate on the LCA.
  2. Nov 3, 2013 at 3:36 PM
    #182
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Hold up a cummins?
  3. Nov 3, 2013 at 3:50 PM
    #183
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    No they are set up to full droop of the UCA to get full bump your tire would be high up in your fender you can trim away your fenders and pull the bumps but we couldn't get that much up travel out of the UCA before it hit the top of the fender. The way it's set up you get the most travel out of your system you can pull your bumps or shave them down a little to gain more up travel but the limit is down. Sure I can set it up to hit the bump you would just have to run limit straps so you don't rip apart the Uniballs on the UCA's.
  4. Nov 3, 2013 at 3:50 PM
    #184
    JLee
    Jerry
    Grass valley CA
    Yeah not too sure they will maybe some 20's might but these little 8's would never hold it up.
  5. Nov 3, 2013 at 4:09 PM
    #185
    BradyT88
    Got ya. So do they still come with limit straps like you were planning or is that out the window now?
  6. Nov 3, 2013 at 4:14 PM
    #186
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    A friend of mine has a converted full size to a wheeling rig. F350 I want to say, and the corner weight was just close enough to scare them away from the ORI's
  7. Nov 3, 2013 at 4:14 PM
    #187
    JLee
    Jerry
    Grass valley CA
    There is no point for them you don't need them. The 10's will come with limit straps.
  8. Nov 3, 2013 at 4:17 PM
    #188
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Haha Brady i think your over thinking what Jerry is saying..
    His top plate uses the ORI internal bump to limit droop..
    But uses the OEM bumps for up travel..you can trim the stock bumps for more up travel if you want.
  9. Nov 3, 2013 at 4:19 PM
    #189
    JLee
    Jerry
    Grass valley CA
    This^^
  10. Nov 3, 2013 at 4:38 PM
    #190
    BradyT88
    Got ya! I was thinking it was using an internal bump to limit up travel not down travel and then just strap it for down travel.
  11. Nov 3, 2013 at 4:38 PM
    #191
    benbacher
    Anchorage, AK
    Silly goose.
  12. Nov 3, 2013 at 7:24 PM
    #192
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Really okay I was wondering if a 10 inch would fit up front for the drop bracket guys
  13. Nov 3, 2013 at 7:26 PM
    #193
    JLee
    Jerry
    Grass valley CA
    They might but its really pointless as they wouldn't be using but 5 or 6" of the stroke.
  14. Nov 3, 2013 at 7:32 PM
    #194
    BAMFTACO
    Juan
    Kings bruh
    Gotcha so there just better off getting replacement coil overs
  15. Nov 3, 2013 at 7:36 PM
    #195
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    These could be used with a 3.5" LT kit right?
  16. Nov 3, 2013 at 7:39 PM
    #196
    JLee
    Jerry
    Grass valley CA
    The 10's yes the 8's would be too short.
  17. Nov 3, 2013 at 8:45 PM
    #197
    RockyMtnTRD
    Noah
    Colorado
    '11 TRD OR
    hack job
    :thumbsup:
  18. Nov 23, 2013 at 10:48 AM
    #198
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    :cheers: More props to Jerry for putting the ORI's together for our trucks.
  19. Nov 23, 2013 at 10:51 AM
    #199
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    C'mon tax returns. Daddy wants some ORI
  20. Nov 23, 2013 at 11:43 AM
    #200
    JLee
    Jerry
    Grass valley CA
    Get your order in now they are about 8 weeks out :(
