ORI-Struts Available from BAMF
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jan 7, 2013.
  1. Dec 19, 2013 at 10:58 PM
    #221
    bigslim
    bigslim Member
    It's a 2000 Nissan pathfinder. I thought BradyT88 would like to see the rubber spacers I used to keep it from knocking against the mount/top hat. Not the most practical project or vehicle, I know, but it's still fun. All that work is just another reason to buy a BAMF tacoma instead
  2. Dec 20, 2013 at 7:44 AM
    #222
    BradyT88
    BradyT88 Well-Known Member
    I did actually. I may try something like that in the near future if it still knocks after I flip the top hat. Thanks!:thumbsup:
  3. Dec 21, 2013 at 6:28 AM
    #223
    Fire252fighter
    Fire252fighter The guy that comments every now and then
    Pittsburgh pa
    09 sr5 tacoma
    Nothing
    Questions on these. In the event of a failure what do you have any internal spring? Like if my shock breaks I'm not screwed cuz of the spring...? Prob a noob question but I'm interested in these just don't quite understand them yet. Second could I have these and not own a nitrogen tank or is that pretty much a necessity.
  4. Dec 21, 2013 at 12:43 PM
    #224
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    In a total failure you would be on the bump stops It would be a rough ride but you could limp off the trail. And I highly recommend a N2 tank at least a rental for a month or so until you get them diled in how you like them.
  5. Dec 21, 2013 at 1:43 PM
    #225
    BradyT88
    Yep, but I think a total failure is pretty unlikely. These things are big compared to my 2.5x16" Kings I have for my rears, obviously they are shorter but they are a lot bigger around.
  6. Dec 21, 2013 at 2:15 PM
    #226
    JLee
    Jerry
    Grass valley CA
    Yeah I don't see it happening unless a rock or branch got up in the wheel well some how. And a standard Coil Over would be toast as well if that happened.
  7. Dec 21, 2013 at 2:31 PM
    #227
    BradyT88
    Exactly.
  8. Dec 21, 2013 at 4:33 PM
    #228
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    i fear blowing a seal ;) at least with a blown seal on a CO you have your preload to hold you up
  9. Dec 21, 2013 at 4:35 PM
    #229
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Seals are rated to 5000 psi, I'm not too worried about those.
  10. Dec 21, 2013 at 4:40 PM
    #230
    BradyT88
    Not sure if Jerry mentioned this, but I heard Jerry blew one of his seals by adding too much pressure so it leaks, and he just fills it up every time he wants to wheel and it lasts him the day of wheeling.
    Jerry can confirm I guess.
    If that is true then I think it would take a pretty catastrophic fail to cause problems.
  11. Dec 21, 2013 at 4:42 PM
    #231
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    These things are way tougher than most folks give them credit for. If they fail its no different than busting a coil you'll figure out how to get it off the trail even if it means whittling a peg leg for it.
  12. Dec 21, 2013 at 8:15 PM
    #232
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Curious if anyone has tried using these in the rear for Go-fast stuff? Could you put a 16" or something in the back and do away with leaf's and be considered LT in the rear? and would they perform as well as Bypasses/SUA?
  13. Dec 21, 2013 at 8:50 PM
    #233
    JLee
    Jerry
    Grass valley CA
    I blew the inner seal so my lower chamber would be pressurized to 350 with in a few days. It was a small leak and I would just let out some pressure in the lower chamber when the ride go too stiff. It never leaked out of the strut just chamber to chamber.
    You need somthing to locate the axle so you would have to link it to run them without leafs.
  14. Dec 21, 2013 at 9:59 PM
    #234
    BradyT88
    You would just be linked at that point. There is an LT guy somewhere (not on here I don't think) that somebody posted a pic of that is running these in the rear on a 4 link setup believe and an LT kit up front.
  15. Dec 22, 2013 at 11:59 AM
    #235
    VolcomTacoma
    Jeff
    NorCal
    Yea that's what I figured. Wasn't sure if there was some other way of doing it.
  16. Dec 22, 2013 at 1:55 PM
    #236
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    So it's been a bit since OP. How do these do on 2nd gen? Mid travel setup?
  17. Dec 22, 2013 at 2:05 PM
    #237
    BradyT88
    I was out tearing up a nice rutted out trail yesterday and got a lot of compliments from the guy riding with me about how smooth my front end is. And I agree. Kills my 886's. Hit some of the stuff hard enough to put the whole front end in the air and it lands nicely.
    The only complaint I have is the rebound is harsh. They bang they rebound so hard. JW and I fixed that a little by increasing the pressure in the lower chamber, but I lost that increase when temps dropped 50* outside since I don't have N2 to put back in them yet.
    Once I have my DMZ kit installed (hopefully in a couple weeks) and some N2 to add some pressure back to them, I will head out to the dunes and really give them a go.
  18. Dec 22, 2013 at 2:32 PM
    #238
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    Definitely watching this thread. Got Kings on the front currently but would be willing to make the swap. There seems to be something special going on with ORI…
    Jerry, are you going to be in Moab for Rock Therapy 2014?
  19. Dec 22, 2013 at 2:54 PM
    #239
    BradyT88
    He'd better be there! and I should be too. haha
    If you already have ext. travel Kings or Icons then I don't know if it is worth spending the money for the swap. I was upgrading from 5100's so I was already looking at spending money on Icons and decided to give the ORI's a try. They are sure nice, but I have no comparison of them to Icons or Kings.
  20. Dec 22, 2013 at 2:57 PM
    #240
    JLee
    Jerry
    Grass valley CA
    I'll be there :cool:
