ORI-Struts Available from BAMF
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jan 7, 2013.
  1. Dec 22, 2013 at 2:59 PM
    #241
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    I like the idea of being able to adjust them quickly and easily. Hit the trails… Adjust. Leave the trails… Adjust.
    The Kings I have are terrible when it comes to adjusting. Everything else about them is great except that.
    I would like to see these things in action. Also it would be cool if he was there with a support trailer and could sell and install on site. Might just have to get some then!
  2. Dec 22, 2013 at 2:59 PM
    #242
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    See above! ^^^^
  3. Dec 22, 2013 at 5:02 PM
    #243
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I'll have some with me in MOAB for sure along with other goodies :cool:
  4. Dec 22, 2013 at 5:25 PM
    #244
    JLee
    Jerry
    Benicia, CA
    In Red ^
  5. Dec 22, 2013 at 5:46 PM
    #245
    BradyT88
    BradyT88 Well-Known Member
    Like Jerry said, you'd want to link the rear. There's no point in adding them onto leaf springs since the leafs already generate your lift.
    I can't speak for ride quality like I said above, but as for more lift, they generate whatever lift you want. You can set it high or low. You are still basically capped at 3-3.5" of lift just because the rest of the suspension can't do that without a drop bracket lift.
  6. Dec 22, 2013 at 7:13 PM
    #246
    Fire252fighter
    Fire252fighter The guy that comments every now and then
    Pittsburgh pa
    09 sr5 tacoma
    Nothing
    Thanks for the info jerry and everyone else. Learning a lot. Are new uca's required for these or just a good idea. Noticed everyone had after market ones. I currently just have stock setup in the front with coil spacer. Full leaf in the back. Just trying to see if I would need any extras other than your kit to run these. Nitrogen tank noted. Thanks guys
  7. Dec 22, 2013 at 7:24 PM
    #247
    JLee
    Jerry
    Benicia, CA
    These have been around for over 10 years its just new to the ifs market thanks to me :D
    IdRatherBNTheSanJuans likes this.
  8. Dec 22, 2013 at 7:26 PM
    #248
    JLee
    Jerry
    Benicia, CA
    Uni ball UCA's are recommended or LR the stock UCA can't handle the extra travel.
  9. Dec 22, 2013 at 7:48 PM
    #249
    BradyT88
    I think he meant to say, "can't"
    You'll want to get some Light Racing UCA's or some uniball UCA's otherwise your OEM UCA will be your limit strap...
  10. Dec 22, 2013 at 7:49 PM
    #250
    JLee
    Jerry
    Benicia, CA
    Fixed
  11. Dec 22, 2013 at 8:13 PM
    #251
    JLee
    Jerry
    Benicia, CA
    No just mounts to allow them to fit with ifs.
  12. Dec 23, 2013 at 7:29 AM
    #252
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    What's the cost for front? 8" I'm assuming.
  13. Dec 23, 2013 at 7:41 AM
    #253
    JLee
    Jerry
    Benicia, CA
  14. Dec 23, 2013 at 7:54 AM
    #254
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    So do these come with top mounting plate and limiting strap when you order from your web site?
    Also how do these handle in -40 temps?
  15. Dec 23, 2013 at 8:41 AM
    #255
    JLee
    Jerry
    Benicia, CA
    The do not come with limit straps there not needed with the 8" If you don't have a UCA that can handle the travel you will need to add limit straps. And I would have to check to see if they can handle -40 temps.
  16. Dec 23, 2013 at 8:49 AM
    #256
    Ghost848
    Tony
    Alberta,Canada
    Ok im running the lr uca those should do for now but if you could find out temp limits that would be great!
    And what about top mounting plate?
  17. Dec 23, 2013 at 9:21 AM
    #257
    BradyT88
    Light Racing will do fine. When with JW we found that my LR UCA's actually had more down travel than his Total Chaos uniball UCA's.
    I imagine they can handle the temps, but you will lose some good ride height and will have to have N2 to fill them back up.
    I had mine aired up to abut 840psi when I left JW's and it was in the 50's. I have about 7.5-8" of shaft showing. About a week later the temps dropped down to around 0 and they dropped a good inch. I didn't have a gauge to measure the pressure drop but I did some rough math and figured my pressure dropped down about 60-100 psi (I can't remember the exact number I calculated off the top of my head, haha).
    So if you stay at a constant -40, just air them up when they drop. When the temps come back up just let some out. If you are moving from area to area where the temps change greatly, like driving in 1 day from -40 to like 0, I doubt it will hurt them but you will be riding high until you let some out.
  18. Dec 23, 2013 at 9:27 AM
    #258
    Ghost848
    Tony
    Alberta,Canada
    Whats the max pressure on these things then?
  19. Dec 23, 2013 at 9:41 AM
    #259
    JLee
    Jerry
    Benicia, CA
    The main seal can handle 5000psi the recommended pressure is 600psi but they can handle more, I don't recommend running over 1000psi unless it's High Way only.
  20. Dec 23, 2013 at 10:48 AM
    #260
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    Mine have been in -20*F, I never adjusted them and saw a range of 60*F in temperature change as it warmed up to 40*F a few days later. The ride height fluctuated with the temps but has been consistent going back to the original ride height they were set at when last charged relative to the temp. I have not checked the pressures in the chamber so I can't speak to that but my guess is that they have remained fairly consistent. My only concern running them in conditions like this are the seals and shafts being damaged by the shit they put on the roads and all the grime, grit etc from the constant freeze/thaw going on where I live.
