ORI-Struts Available from BAMF
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jan 7, 2013.
  1. Dec 23, 2013 at 1:04 PM
    #261
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    Wonder if they make a sock to protect them. Like the ones they sell for icon coil overs
    http://performancelifts.com/ICON-Neoprene-Coilover-Shock-Wrap-Small-Size-191003.html
  2. Dec 24, 2013 at 10:32 AM
    #262
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    I need to pick something up to cover them they are super nasty looking currently. I had wondered about a set of shock sox for dirt bikes to keep seals protected a little better and then a cover over that to keep the shafts clean.
  3. Dec 24, 2013 at 9:00 PM
    #263
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Good idea... Here is another question, if the seal goes... Your pritty much riding on a bottomed out strut correct? Since there is no "spring" to hold it up... In turn causing more damage if in the middle of no wear
  4. Dec 24, 2013 at 9:25 PM
    #264
    BradyT88
    BradyT88 Well-Known Member
    Well if your tires don't rub at full stuff then no big. Just limp it home. If they rub really bad you have problems. I have my old 5100's in my toolbox (basically because I have no where else to put them) that I could swap in. If you want to get crafy you could make a 2x4 or piece of steel that can bolt in place of the strut for cheap and limp home on that.
  5. Dec 25, 2013 at 9:31 AM
    #265
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    This^ if your wheel wells are property Clarenced it should be a problem. And again i dont see a total seal failure unless to go some serious damage and you would have bigger problems if that happened. Like looking for your front tire :eek:
  6. Dec 25, 2013 at 12:36 PM
    #266
    Ghost848
    Tony
    Alberta,Canada
    Lol is there any shock socks that you know of jerry?
  7. Dec 25, 2013 at 5:36 PM
    #267
    JLee
    Jerry
    Grass valley CA
    Not from ORI but im sure there in some that would fit.
  8. Dec 25, 2013 at 6:07 PM
    #268
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I don't think I would ever go this route with my truck but I have to say I find this thread fascinating. :popcorn:
    Props to all for being so innovative. :thumbsup:
  9. Jan 6, 2014 at 9:54 PM
    #269
    bigslim
    bigslim Member
    I drive mine in -20 degrees in Idaho occasionally, and I spend part of the winter in Utah with all the salt on the roads. They handle the temperature fine, a little loss in ride height. I like to keep the salt off the piston shafts because it will eventually eat the chrome. I know a guy in Florida that got some type of salt solution on his struts and let them sit for a season. It pitted the chrome finish. The struts do have a rod wiper seal that keeps the road grime off the main rod seal. I would occasionally inspect that black wiper seal to make sure it's in good shape, then, so long as your piston shaft isn't pitted from salt, your main rod seal should hold up just fine.
  10. Jan 6, 2014 at 10:05 PM
    #270
    BradyT88
    Yep. Speaking of which I need to go wipe mine down. The salt is awful around here...
    And Idaho you say?:D
  11. Jan 6, 2014 at 11:22 PM
    #271
    Ghost848
    Tony
    Alberta,Canada
    yeah it was -40mthe other day here... if i could find a sock for around here i would be happy, they dump the crap around here in the winter...:/
    jerry when is your next big SALE!!!!!???
  12. Jan 7, 2014 at 6:20 AM
    #272
    JLee
    Jerry
    Grass valley CA
    The ORI'S won't ever be on sale.
  13. Jan 7, 2014 at 7:33 AM
    #273
    Ghost848
    Tony
    Alberta,Canada
    :pout:
    fine take all my bonus...
  14. Jan 7, 2014 at 7:34 AM
    #274
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    tony, just grab an icon sock to cover the ORI.... Id make the bottom tight with the top loose so when you flex the shaft is still covered and the top slides versus the shaft becoming exposed
    doesnt matter what brand of shock you have here in alberta the shafts all seem to pit within a couple years...
  15. Jan 7, 2014 at 7:40 AM
    #275
    BradyT88
    Jerry is already selling them for as low are ORI will let him so unless ORI decides to have a sell then Jerry can't sell them any lower without losing his vendor status with ORI.
  16. Jan 7, 2014 at 7:42 AM
    #276
    Ghost848
    Tony
    Alberta,Canada
    lol I understand that, its always worth a try right?
  17. Jan 9, 2014 at 9:08 AM
    #277
    Ghost848
    Tony
    Alberta,Canada
    Jerry how do there fair compared to a normal coilover? do you find they are bouncy?
  18. Jan 9, 2014 at 12:13 PM
    #278
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    i think jerry's set-up will be 100% different than you'd expect for a normal vehicle try and get in touch with the guy from Alaska, kind of the same weather patterns we experience and roads
  19. Jan 9, 2014 at 12:44 PM
    #279
    BradyT88
    I think he got the bouncy from me. haha. Mine are bouncy, but I think it is because I have no rear shocks and they are not tuned, they just have random amounts of air in them at the moment. I'm waiting on my resi's and fill kit before I go rent an N2 tank.
  20. Jan 9, 2014 at 1:43 PM
    #280
    JLee
    Jerry
    Grass valley CA
    Yeah my set up is a little different then you would see. But I like how they ride they soak up the bumps well and the truck is super stable. Sure it's a little stiff sometimes with how I have them set but being linked front and rear and no sway bars they handle like a dream.
