ORI-Struts Available from BAMF
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jan 7, 2013.
  1. Aug 14, 2015 at 2:22 PM
    #321
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Planning on it, we've got one big fab job thats eating up all the equipment and techs to finish, so I'm on jackstands til then hahaha. I'm thinking coming down a total of two inches should be the sweet spot for these. if I could have 2" less shaft showing all the time it seems like it'll be right on the money.
  2. Aug 18, 2015 at 3:38 PM
    #322
    benbacher
    Anchorage, AK
    Ok, so after flipping the top hats to the downward position, which seems to be the way they were intended to be mounted in the first place after seeing a few pics in this thread, and installing my reservoirs in the engine bay I now can give an accurate quality breakdown. The facts:
    Driver side Upper PSI: 825
    Driver side Lower PSI: 200
    Passenger side Upper PSI: 725
    Passenger side Lower PSI: 200
    Amount of chrome showing on each side is right at about 5" giving me 3" of down travel and 5 up. Ride quality is highly desirable, single bounce when doing 45-50 and getting all 4 tires off the ground, shocks cycle and truck goes down, and then right back up to ride height with a very smooth transition at that speed. Seems to soak up a lot of the small stuff as well, almost responding like a flutter valve would in a custom shimmed King, very little road feel is translated into the cab. Body roll is very controlled even with all the weight I have over the cab, custom roof basket and 250 pound Mt. Mckinley tent on a DOM bed rack. Corners really flat even at high speeds (+45mph)
    Overall I'm totally stoked about these bad boys now. Before I had the resi's I had upward of 1000 PSI in each upper and 6.5-7 inches of chrome shaft showing, so no down travel at all. This is a huge improvement.
    Blackout14 likes this.
  3. Jun 26, 2016 at 2:05 PM
    #323
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    @JLee
    Hey Jerry, which way do the top hats go? I got mine 2nd hand with no instructions. I think they are the BAMF hats. Mounting tabs up or down?
    I posted this in another thread and most people told me the tabs go up, but it seems to me they should point down. Can they go either way? It seems in all your photos the tabs are down.
  4. Jun 26, 2016 at 4:02 PM
    #324
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The threads go up on the top hat.
  5. Jun 26, 2016 at 4:08 PM
    #325
    weldo
    Pittsburgh, pa
    were the pictures of the tabs down a different design?
  6. Jun 26, 2016 at 4:14 PM
    #326
    JLee
    Jerry
    Benicia, CA
    No its the same top plate in both of those pictures just flipped. With them down you will need limit straps or you will blow your CV's the first time you flex out in 4WD.
  7. Jun 26, 2016 at 4:55 PM
    #327
    weldo
    Pittsburgh, pa
    Oh I gotcha! Thanks for the insight!
  8. Jul 29, 2016 at 8:20 AM
    #328
    IdRatherBNTheSanJuans
    IdRatherBNTheSanJuans Well-Known Member
    Coe
    05 TRD Sport 4x4 DCLB
    Kings. JBAs. AllPro standards. Mastercraft CXT 255/85r16s
    Hey Jerry and others-
    I'm extremely interested in these, and would like to clear up a couple questions I have:
    1. What is the total travel that can be gotten out of a stock uca and aftermarket uca (I.e.-how much travel total with the Ori's in this config.)
    2. Can I run 10" Ori's with limit straps with aftermarket ucas for now-in case I go with +2" Lt later?
  9. Jul 29, 2016 at 9:27 AM
    #329
    BradyT88
    BradyT88 Well-Known Member
    With Superbumps and LR UCA's I am pulling about 11" of travel at the hub. That's full droop to fully compressed bumps. The superbumps compress quite a bit more than the stock bumps so you gain an inch or more of up travel by going to them. With 33's on hard landings I was hitting my subframe on the ground... Adding a 3/8" spacer to the bumps helped mostly fix that.
    I think you can fit a 10" on stock. It might be pretty close to bottoming out at full stuff, but if you kept the stock bumps on it should be fine. Jerry would know for sure.
  10. Jul 29, 2016 at 9:31 AM
    #330
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    You're going to need to post pics / video of cycling your suspension at that 11" for proof amigo. Even with aftermarket uniball uppers and lowers without a CO even installed 10" is fish tale measuring. A stock length arm suspension with ball joints just is not going to pull that much travel...prove me wrong.
  11. Jul 29, 2016 at 9:42 AM
    #331
    BradyT88
    I don't have a vid. Maybe I'll have to do one one of these days. I've posted pics before and taken shit for it in the past. When I pulled out the bump and shock I can cycle just under 11.5". On the upper and lower ends of that the CV's will start to bind so I wouldn't ever run that much. My superbumps are limiting a little of that with the spacers in and the ORI's stop my droop just before the CV binds so I am probably pulling just under 11" or right at it.
    These pics aren't the best. I took them while I was installing the superbumps and ORI's, but they are one set I have.
    IdRatherBNTheSanJuans likes this.
  12. Jul 29, 2016 at 9:51 AM
    #332
    BradyT88
    No tape measure here, but this is with the shocks completed deflated and then inflated all the way to full droop.
  13. Jul 29, 2016 at 10:08 AM
    #333
    Coe
  14. Jul 29, 2016 at 10:33 AM
    #334
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    So what is the actual usable travel with wheels on, bumps / straps or when the CV binds at droop ? 8.5 - 9" ? Even with a +2 kit you can't get 11" because the CV's bind at droop.
  15. Jul 29, 2016 at 11:36 AM
    #335
    BradyT88
    I've measured it just shy of 11" at the wheels with everything bolted together like I run it with no CV binding issues.
  16. Jul 29, 2016 at 12:06 PM
    #336
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    This just does not make any sense ? When I had a mid travel kit with Dirt King uniball uppers and lowers even without the CO's installed it would only cycle just under 10" bumped and everyone with Total Chaos uppers and lowers is getting the same thing and the limiting factor is the misalignment spacer bottoming out. So those uniball kits are mechanically limited at 10" or less so how on the world are you guys getting 11" with ball joints ? It just does not seem physically / mechanically possible ?
  17. Jul 29, 2016 at 2:29 PM
    #337
    weldo
    Pittsburgh, pa
  18. Jul 29, 2016 at 4:20 PM
    #338
    BradyT88
    When I installed my ORI's with n0rth's help he had just got his TC UCA's on his truck. Putting them side by side with my LR UCA's; we found that my LR's had more articulation. Which was ironic because he specifically got the TC's to replace his LR's when he got the ORI's because he was worried about the LR's limiting his travel.
  19. Jul 29, 2016 at 4:22 PM
    #339
    Coe
    I think I'll be going this route! SounSounds like the best of all worlds for a daily/wheeler!
    Thanks for the info guys!
  20. May 20, 2018 at 10:03 PM
    #340
    Bobby18
    Bobby18 Well-Known Member
    Bobby
    2008 Tacoma Prerunner
    DTF +6 LT, Kings 2.5x10 C/O, 2.5x2 Bump, Adv Fiberglass 1 Piece Conversion
    I am bringing this back to life!!!
    How are these holding up? I will be 4-linking my rear and thinking about using the ORI's.
