ORI-Struts Available from BAMF
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jan 7, 2013.
  1. Aug 27, 2013 at 9:02 AM
    #141
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    I figured as much. Just wondering what are some good reasons of going from the coilovers I have now to ORI's, especially on an IFS rig??
  2. Aug 27, 2013 at 9:13 AM
    #142
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Then the extended length is too long. I thought the internal limits and bumps were one of the major advantages to the ORI's to begin with?
    Aren't these being built to spec anyways or are they just a generic 8"? If the latter is the case maybe see about getting them built to spec to fully take advantage of the ORI's?
  3. Aug 27, 2013 at 9:22 AM
    #143
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah the first set that went on were 10" travel (going to LT soon) so we had to limit them. The 8's will be close on the down travel but the bump is used with removing the factory bump but we might still have to limit the 8's as well if the UCA binds up.
    These are just a standard ORI if the porting needs to be changed or the oil levels need changed in them we will have them built like that but so far they are doing great on and off the trail the way they are.
  4. Aug 29, 2013 at 7:24 AM
    #144
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Do you still have any in stock?
  5. Aug 29, 2013 at 7:27 AM
    #145
    JLee
    Jerry
    Benicia, CA
    No not at the moment i have a few sets on order but none in stock.
  6. Aug 29, 2013 at 7:27 AM
    #146
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    He will in a few weeks! You should def pick up a set of the 8's :D
  7. Aug 29, 2013 at 10:47 AM
    #147
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I think I will. So they come with limit straps and the coil bucket adapter for $1300?
  8. Aug 29, 2013 at 11:12 AM
    #148
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
  9. Aug 29, 2013 at 12:51 PM
    #149
    JLee
    Jerry
    Benicia, CA
    Yes everything is included.
    We have found it's the UCA the binds before the CV so the CV's are good.
  10. Aug 30, 2013 at 7:06 AM
    #150
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    Jerry! Any word if these would work for a 1st gen long travel??? Just curious runing numbers looking at multiple options for building the new rig! I dont think ill be SAC for a little while as Im going to build up some axles first, looking at running something for around a year to two years
    Would love to be SAC by moab next year, but I dont see it as a viable option stupid priorities :p
  11. Sep 2, 2013 at 11:17 AM
    #151
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Subbed. Want for LT.
  12. Sep 2, 2013 at 6:49 PM
    #152
    JLee
    Jerry
    Benicia, CA
    Yes with LT For sure they will fit.
  13. Sep 2, 2013 at 9:14 PM
    #153
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    what would a set of 10's cost??? and timeline ish??
  14. Sep 3, 2013 at 6:46 AM
    #154
    JLee
    Jerry
    Benicia, CA
    I'll have the check and get back to you on the 10's. I think the lead time is still 8 to 10 weeks but it could be less.
  15. Sep 3, 2013 at 6:53 AM
    #155
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    thanks Jerry :D
  16. Sep 8, 2013 at 1:12 AM
    #156
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    Oh man these look sick--saw a set on one of the guys in our group up in Maine on the 31st. Looked like he had 14" struts all around on his crawler. The pistons on these are massive! I f'n wish I knew about these before the plunge into Icons...congrats on becoming a dealer, looks like this company's gonna be around awhile:cool:
  17. Oct 9, 2013 at 9:40 AM
    #157
    JLee
    Jerry
    Benicia, CA
    Update! I have 2 black sets and one blue set heading to me in a day or two if someone is ready to order there will be no wait time on these.
  18. Oct 14, 2013 at 10:18 PM
    #158
    FATaco
    FATaco Meh
    Friends call me Ginger
    Fairbanks
    07' TRD DCSB
    Dakars w/AAL, OME/886's, All Pro Front Bumper, Rear bumper, IFS skid, and UCA's. Superwinch Tigershark. Magnaflow muffler... vrooom
    So, if I bought a set and wanted to adjust the ride height before buying my own tank, you say most welding shops would be able to fill em' up? I know a lot of tire places are selling tires filled with nitrogen these days. Would this be the same type of connector? Or, is having my own tank a prerequisite before buying this set up?
  19. Oct 15, 2013 at 6:38 AM
    #159
    JLee
    Jerry
    Benicia, CA
    Most welding shops would have the tanks not fill them. And i dont think the tire shops have regulators that go to 1000psi so i dont know if they can fill them.
  20. Oct 17, 2013 at 12:20 PM
    #160
    BradyT88
    BradyT88 Well-Known Member
    Have you guys tried taking the oem bumps off of the front and seeing if the shock bottoms out before the LCA hits the strike plate? Just curious because when I land my jumps, My OEM bump gets pretty damn flat...
    And my big question, as far as cooling goes in high-speed stuff, how do these compare (without adding a resi) to some 2.5" C/O's that don't have resis. Like say the ext travel Kings or Icons, which are 5.5" and 6" travel C/O's for the 2nd gen. Will they fade significantly faster or will the difference be negligible?
    Had a thought, do these really fade much at all since they are just air shocks (no oil in them right?) filled with Nitrogen? I know that tires filled with nitrogen don't change psi hardly at all from cold to hot, but what about in these shocks?
