Original equipment shocks in Limited vs OEM Bilsteins in the TRD OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by R2D2, Feb 22, 2017.
  1. Mar 15, 2018 at 11:48 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    I put the front strut assemblies and the rear shock (no springs) from a very low mileage OR on my Sport. It helped definitely. The front springs are softer on an OR than a Sport.
    You should be able to pick up <5,000 mile OR struts (damper and spring assemblies) and rear shocks for $200-250. I think mine had less than 1,000 miles.
    I did not do a front end alignment because I never touched the LCA cam bolts. I removed the sway bar and popped the UCA ball joint. Neither of those will change the alignment. Once reassembled, I checked the ride height, and it was within 1/8" form the original....so my alignment is fine.
  2. Mar 15, 2018 at 11:57 AM
    GoLongJoe
    GoLongJoe Well-Known Member
    Joe
    2005 Tacoma PreRunner -- 2WD Project
    Tires, soon to be shocks, bushings, and bull bar. No lift, not needed.
    Ok cool, from what I've seen, The iron man springs should give about 2 inches of lift (hopefully will work with the TRD offroad shocks) in the front to level me out. I'll also be putting an add a leaf in the near future.
  3. Mar 15, 2018 at 12:03 PM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    I have a set of 2015 TRDOR front & rear shocks and the front coil springs. Located in GA. They had a little over 10k miles on them when I took them off.
    Would a 2016 lose ride height if you put 2015 2nd gen suspension on it?
