Other Use for This Switch??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FlyFisherCJ, Apr 13, 2018.
  1. Apr 13, 2018 at 7:24 AM
    FlyFisherCJ
    FlyFisherCJ [OP] Well-Known Member
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    All,
    Quick question... I will be installing a camper shell on my TRD OR DCLB here in the next week or so. With that, I will loose the bed light function of the 3rd brake light. Can I use the switch in the cab (see pictured below), to run perimeter work lights that I want to mount to the top of the shell?
    If anyone has done something similar to this, could you include any wiring details? Like what wire and tapped into and how you routed the lights and wires?
    Thanks for the help!!
    (not my truck, just needed a picture of the switch)
  2. Apr 13, 2018 at 8:02 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I haven't done it but I can't see why not. I'm going to assume the switch itself does not switch the light directly but a relay to trigger said light.
    Find the relay and use it to trigger your new lights as long as it's rated for the amperage.
    Technically you could probably tap in at the light but the issue is if you're putting a higher amperage light you could overload the fuse or wire so it's better to just start fresh to an extent.
    And if it does trigger the light directly you could still just rewire a relay into it.
    FlyFisherCJ[OP] likes this.
  3. Apr 13, 2018 at 8:09 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    I'm assuming thats switched through a relay, so I dont see why not.
    FlyFisherCJ[OP] and Joe23 like this.
  4. Apr 13, 2018 at 9:01 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    These should help
    It is relay controlled. Looks like if you want to tap in and keep the functionality of the switch as is, I would use green wire near the relay, or you can pick it up at connector IE1
    This will also help, especially post #9
    https://www.tacomaworld.com/threads...s-using-double-cab-cargo-light-switch.436440/
    Good luck, and let us know how it goes.
    [Edit
    @RedEmpire provided better link https://www.tacomaworld.com/threads/other-use-for-this-switch.543947/#post-17608941 with pictures for accessing the green wire at connector IE1. Thks @RedEmpire
    /Edit]
    2016Tacoman likes this.
  5. Apr 13, 2018 at 9:10 AM
    FlyFisherCJ
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    ^^^ Awesome!! thanks for the links. Now to see if I am brave enough to tackle this one..
  6. Apr 13, 2018 at 9:43 AM
    Judicar
    Judicar Well-Known Member
    2016 Tacoma TRD OR DCSB
  7. Apr 13, 2018 at 10:41 AM
    Khrolar
    Khrolar Well-Known Member
    Vancouver Island
    4 door 2017 trd off-road,
    None... :(
    I have had this idea as well, however I was going to try and set it up so the canopy lights came on just like the factory bed lights do. Haven't gotten around to looking into it yet, but let me know what you find!
    doyledoonz likes this.
  8. Apr 13, 2018 at 10:49 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    That switch also turns the interior light on with the door if I remember correctly
  9. Apr 13, 2018 at 10:54 AM
    1000101 Well-Known Member
    Jon
    Reno, NV
    2022 TRD OR DCSB
    I think it's a different switch on the overhead console for the interior lights. At least on mine. Ask me about why i thought i had a burned out dome light already lol.
    shakerhood[QUOTED] likes this.
  10. Apr 13, 2018 at 10:56 AM
    shakerhood
    Southern Ohio
    You might be right, maybe I'm thinking that it sends power up and energizes the other switch? I remember fooling around with it the 1st day I bought the truck and have not touched it since.
  11. Apr 13, 2018 at 10:58 AM
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Hmm. Could be. I had never touched mine after I first bought it either. But the place that did my repairs after I got rear-ended flipped the interiors to off. Took me a day to realize what changed.
    shakerhood likes this.
  12. Apr 13, 2018 at 11:00 AM
    9TRDTCO
    9TRDTCO Well-Known Member
  13. Apr 13, 2018 at 11:26 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    ive seen similar switches being used as winch in/out
  14. Apr 13, 2018 at 11:32 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
  15. Apr 13, 2018 at 11:34 AM
    FlyFisherCJ
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    :rofl::rofl::rofl: Just a random picture online
    9TRDTCO likes this.
  16. Apr 13, 2018 at 12:01 PM
    9TRDTCO
    I knew it wasn’t him lol
  17. Apr 13, 2018 at 1:07 PM
    RedEmpire
    RedEmpire Well-Known Member
    Southern Pines, NC
    2017 MGM Tacoma DCLB 4X4
  18. Apr 13, 2018 at 1:43 PM
    Khrolar
    Vancouver Island
    None... :(
    Just checked my DCOR, the switch besides the steering wheel only controls the bed lights, and the switch by the rear view mirror, on the roof console, only controls the interior cab lights.
    They do not effect each other.
  19. Apr 13, 2018 at 2:19 PM
    shakerhood
    Southern Ohio
    Good deal, thanks for the info.
  20. Apr 13, 2018 at 2:25 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Nope, That's mine!
    Lt. Dangle likes this.
