Our AC system SUCKS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 30, 2018.
  1. Sep 8, 2018 at 4:39 PM
    #681
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think this is the perfect amount.
  2. Sep 8, 2018 at 4:54 PM
    #682
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I dont think water will run down inside unless you were squirting water toward it.
    I also bent the metal lip down some where the seal goes with a rubber mallet.
    20180908_184819.jpg 20180908_184733.jpg 20180908_184607.jpg 20180908_184644.jpg
  3. Sep 8, 2018 at 5:07 PM
    #683
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yes and no. You have to be really good with the dremel in order to open up that honeycomb and make it look half decent (i.e like it was not a total hack job) also, there is only so much space you can work with in the actual scoop part of it itself before you start messing with its mounting integrity. I made a series of 5 large holes and 2 large rectangular windows using my dremel with a cutting disk as well as a 3/8 drill bit to make the holes large enough allow for some decent heat extraction out of the scoop. It's not as simple as opening the honeycomb if you want to do it right.
  4. Sep 17, 2018 at 3:07 PM
    #684
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    8AA085E4-A6B4-4DF0-9BC9-DA225DC731AC.jpg 44F94EC6-D5EF-4CEB-B7BC-7228375E0389.jpg Idled for 45 min today waiting for my Wife to pickup some things at the store. Electric fan running. A/C Controls were NOT on max. Fan speed on 3.
    Roostfactor likes this.
  5. Sep 17, 2018 at 4:34 PM
    #685
    R490
    R490 Well-Known Member
    Upgrayedd
    VA
    Are we still talking about AC sucking?
    I'm pretty sure my AC system is making me sick, because there's mold somewhere in the system and the Lysol trick doesn't work at all.
  6. Sep 17, 2018 at 4:46 PM
    #686
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Are you just spraying it into the vents?
  7. Sep 17, 2018 at 4:53 PM
    #687
    R490
    Upgrayedd
    VA
    Nope, into the exterior intake under the hood.
  8. Sep 17, 2018 at 5:50 PM
    #688
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Try something like this before you dig any deeper. This creates a massive foam that expands inside the vents and cleans it out. Make sure you remove the cabin filter before you use this.
  9. Sep 17, 2018 at 6:06 PM
    #689
    TomTwo
    Bill
    I-85 Southbound
    We used to use this on Police cars and Inspector cars and first responder vehicles when I was a Shop Manager.
    R490 likes this.
  10. Sep 18, 2018 at 8:05 AM
    #690
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    Wouldn't it be tapping into the black wire and the white wire to run the resistor in parallel to the Thermistor?
    The resistor could be installed at the plug between the two pins?
    Thanks
    Fritz
    loginfailed likes this.
  11. Sep 23, 2018 at 3:24 PM
    #691
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes, you can either install it across the white and black wires on the dash harness side or you can strip back the black sheathing and install it on the thermistor side of the plug. Either way it needs to go in parallel with the evaporator temperature sensor.
    Weissenheimer and Roostfactor like this.
  12. Oct 24, 2018 at 8:31 PM
    #692
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
  13. Oct 24, 2018 at 9:15 PM
    #693
    Roostfactor
    TX panhandle
  14. Oct 25, 2018 at 1:14 PM
    #694
    BillDaCat8
    Jake
    PHX
    Roostfactor[QUOTED] likes this.
  15. Mar 25, 2019 at 4:19 AM
    #695
    B ill y
    B ill y Well-Known Member
    Billy
    Sarasota County, Florida
    2018 4Runner Trd OR, 1997 FZJ80,1985 FJ60
    try ammonia it kills mold spores ... And to the hood venters I did this to my 80series years ago and it works good but when it rains it would make the windshield fog up really bad . so bad it was annoying and took spacers off.
  16. Apr 7, 2019 at 4:27 PM
    #696
    SBDUNC
    SBDUNC Member
    Texas
    2013 DCSB TRD Sport, Supercharger
    Are these the two wires you're talking about? My AC sucks, and it's about that time of year again. I'm glad i found this thread.
  17. Apr 7, 2019 at 4:36 PM
    #697
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes I think that’s the connector.
    Weissenheimer and SBDUNC[QUOTED] like this.
  18. Jul 31, 2019 at 5:28 PM
    #698
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    I'm done with poor AC performance at low speeds. Gonna take action soon. Electric fan and window tint hopefully make time to get done by end of August.
    crtx likes this.
  19. Jul 31, 2019 at 5:33 PM
    #699
    TomTwo
    Bill
    I-85 Southbound
    I put a fan on my 2013 it sure helped in slow traffic and when sitting at a drive in window.
    MattCowsmasher and 2WD[QUOTED] like this.
  20. Jul 31, 2019 at 5:44 PM
    #700
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Okay so I found over time that there are multiple ways of tackling this issue.
    The first thing I found is that heat retention under the hood is horrible on the system and if you remove the rear most weatherstrip under the hood at the cowl it helps a ton in increasing airflow.
    The second thing I found is that lack of proper insulation inside the cabin is a huge contributor to the AC system not working s well as it should. Something as simple as a well made windshield reflective heat shield which blocks out the majority of the sun from soaking the interior during the hottest can lower interior temps some 20-30 degrees. Left on while sitting in the truck it allows the AC system to have to work less to cool down all of that interior space and the system stays cooler longer before it starts to fall off in temps a little bit.
    Additionally I would be willing to bet that some nice sound deadner material like Dynamat, Stinger, or Noico in the variety which is meant to repel away heat strategically placed on the roof would be IMMENSELY helpful as well. I am not at that point yet, however, though I would like to do that before next summer.
    The third thing and this is a bonus for Sport hood owners. In effort to further allow for underhood heat soak, you can open up the slit or the faux grill on your hood to allow for some venting. It's a tedious process and it sucks, but any little bit helps.
    Combined, I have found this triple combo to be highly effective for me in maximizing cooling capabilities inside of the cabins while the truck is in park in a stationary spot on a disgustingly hot day. :)
    2WD likes this.
