Outerwears Air Intake Cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hashemg, Aug 20, 2008.
  1. Aug 20, 2008 at 6:58 AM
    hashemg
    hashemg [OP] Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    http://www.outerwears.com/products.asp?cat=11762&pg=12
    after doing some extensive research, I finally ordered a cover to protect my K&N Air Intake Filter.
    I ordered it from the website above because of the valuable reputation they have with ATV/Dirtbike enthusiats.
    The price is incredibly reasonable (23.95 for the 4cyl intake) and they give you plenty of details to make sure u order the corrrect one.
    I was split betweent buying the outerwears cover and the drycharger that K&N makes (quote I got was $45 for the cover)
    Then come to find out, Outerwears manufactures the drycharger cover for K&N. its the same exact material and technology, you are just paying to have have the K&N name on it.
    I just wanted to share this info with everyone so you don't have to go through the same research I did.
    I have not put the cover to the test so i do no have any feedback on performance yet. As soon as I do I will post
  2. Aug 20, 2008 at 7:07 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Pantyhose does the same thing...
  3. Aug 20, 2008 at 7:22 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    you can get the material in some ATV/Snowmobile mags that will work just fine...pre filter material.
