outlet and cigarette dont work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotr, Jan 15, 2010.
  1. Jan 15, 2010 at 6:19 PM
    tacotr
    tacotr [OP] New Member
    James
    San Diego
    06 Taco trd off road
    I bought a used 06 tacoma trd off road and the cigarette lighter and power outlet on the dash dont work. I have tried changing the fuse. I have read all the other posts and nothing has worked. Any ideas?
  2. Jan 15, 2010 at 6:29 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    are they plugged up?
  3. Jan 15, 2010 at 6:43 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Are you getting voltage at the plug with the ignition on?
  4. Jan 15, 2010 at 7:08 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Does the horn work?
  5. Jan 15, 2010 at 7:22 PM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    check your fuses
  6. Jan 15, 2010 at 7:33 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    The fuse for the accessory plugs is underneath the kick panel not under the hood.
  7. Jan 15, 2010 at 8:01 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
  8. Jan 15, 2010 at 8:41 PM
    tacotr
    James
    San Diego
    Their is not a plug in the outlet. I check the fuse under the dash and even replaced it with the spare. I check for voltage with a multimeter and their was nothing. I check all these with the key in the acc and on position.
  9. Jan 15, 2010 at 8:45 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    the plug on the back of the outlet
  10. Jan 15, 2010 at 9:23 PM
    dexterdog
    Oly WA
    2012 F150
    Do you have voltage at the fuse? If so than trace it from there. If you don't have power at the fuse then a wiring schematic may be in order.
  11. Jan 16, 2010 at 4:56 AM
    DrRabbitFurHead
    Salem, VA
    This guy sounds smart! :thumbsup:
