Outlet in cab not getting power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajohnson225, Jun 25, 2015.
  1. Jun 25, 2015 at 12:16 PM
    ajohnson225
    ajohnson225 [OP] Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
    The outlet in the cab (under radio and ac) doesn't seem to work anymore. When I plug my radar detector into the outlet, it flickers for maybe half a second then turns off. Any help what could cause this?
  2. Jun 25, 2015 at 12:26 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Check the fuse
  3. Jun 25, 2015 at 12:26 PM
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    Have you tried any other devices in that outlet? It's possible your radar detector could be on the fritz.
  4. Jun 25, 2015 at 12:28 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    is it loose, does it spin, does it come out some? Mine came loose from behind and I had to open the dash up and fix it.
  5. Jun 25, 2015 at 1:18 PM
    ajohnson225
    Austin
    Baton Rouge
    I've tried other items and they don't work either. Which fuse would it be? Or at least which panel? I took the plug out and examined and it looks to be okay
  6. Jul 2, 2015 at 12:13 PM
    Albers
    Albers Member
    Southern Indiana
    2005 Tacoma, double cab, short bed 4X4
    I'm having the same issue. All the fuses are good, so I'm assuming there is something behind the outlets that is disconnected. How do you get the panels off to get to them?
  7. Jul 2, 2015 at 4:44 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it comes on at all it's probably dirty do you smoke and use the same socket?
