Output shaft seal confusion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacomatoy, Mar 29, 2020.
  1. Mar 29, 2020 at 10:33 PM
    07tacomatoy
    07tacomatoy [OP] Shoots den
    Pacific Ocean
    2007 4x4, 2019 TRD SPORT 4x4
  2. Mar 31, 2020 at 12:57 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New Dorman rear wheel bearings using complete axles 926-139 & 140
  3. Apr 1, 2020 at 3:00 PM
    07tacomatoy
    Pacific Ocean
    Thank you for reply and help looking into it.
    Drivers side:
    Part# 90311-47012 or 90311-47027
    (Saw someone’s ECGS order and this is what’s listed on the invoice)
    Passenger:
    Part# 90311-47013
    I’m going to stick to the above. And ignore that the seals are noted to fit right or left online (camelbacktoyota).
  4. Sep 30, 2021 at 12:39 PM
    BrysonHart
    BrysonHart Active Member
    Bryson
    2020 cement taco
  5. Sep 30, 2021 at 1:03 PM
    Huckin Grate
    Huckin Grate Well-Known Member
    Calgary, Alberta
    2008 SR5 MT V6 4x4
    BrysonHart likes this.
  6. Sep 30, 2021 at 1:13 PM
    BrysonHart
    Bryson
    2020 cement taco
    Thanks you so much man, notice you bio says 08, is this true for 3rd gens also?
    Gonna check that thread rn! :thumbsup:
  7. Sep 30, 2021 at 1:16 PM
    BrysonHart
    Bryson
    2020 cement taco
    Just realized I’m in a 2nd gen thread *facepalm*
  8. Sep 30, 2021 at 1:24 PM
    Huckin Grate
    Calgary, Alberta
    2008 SR5 MT V6 4x4
