Outside Temperature Monitor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by frano, Dec 19, 2010.
  1. Dec 19, 2010 at 10:42 AM
    frano
    frano [OP] Member
    Western MA, USA
    2011 Tacoma Double Cab
    My 2011 DC 4X4 SR5 did not come with an outside temperature monitor. Does anyone know of an aftermarket unit that can be installed and approximate cost? Thanks.
  2. Dec 19, 2010 at 10:46 AM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    apparently it's pretty easy to install the factory overhead unit. i have the same truck as you and mine actually has the ambient temp sensor behind the grille as well as the associated wiring into the cab.
