OV tune
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brazor12, Feb 22, 2021.
  1. Feb 22, 2021 at 8:55 PM
    Brazor12
    Brazor12 [OP] Member
    Brendan
    2019 white Tacoma TRD Sport 4x4
    Trd Pro Grille
    I’m about to pull the trigger on a 91 OV flash tune but was wondering if anyone is running one and what their recommendations would be all I’ve read are good things especially since I’m running 35s with 4.88 nitros
  2. Feb 22, 2021 at 9:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There are no 91 tunes. All tunes are Octane Learning. There are Reg and Prem fuel initial set points. The tunes adapt from there just like the Stock tune does.
    Brazor12[OP] likes this.
  3. Feb 22, 2021 at 10:00 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    I have the 87 tune on 33's. Big noticeable difference on mine. Hope others can chime in with your similar setup.
  4. Feb 23, 2021 at 5:04 AM
    N5J_Taco
    N5J_Taco Well-Known Member
    Are you having someone load it for you or do you own the tune kit?
  5. Feb 23, 2021 at 5:49 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    The max ignition timing advance is not different? Or is there a max? Seems silly to make a 2 different tunes if they both end up in the same place
  6. Feb 23, 2021 at 6:17 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I was running premium tunes for a while but recently switched to regular(87base) tunes. I haven't noticed much of a difference personally, but I am also using custom user-created tunes, not OVtunes base-files so by default they are a bit peppier.
    If you're gonna flash it yourself, you could just try both. If you're gonna have somebody flash it for you...just make sure you're okay with buying only premium fuel as you don't wanna load a premium base tune and then start running regular gas. You can do it the other way around (flash regular87 tune and rune 91octane fuel), but not premium tune with regular gas.
  7. Feb 23, 2021 at 8:03 AM
    Brazor12
    Brendan
    Trd Pro Grille
    Having someone load it he has a tuning kit and everything
