Overdrive in low range
Discussion in 'Off-Roading & Trails' started by holapalli, Dec 3, 2012.
  1. Dec 3, 2012 at 7:11 PM
    BradyT88
    BradyT88 Well-Known Member
    Yes. I have done it in Moab. Doesn't shift into overdrive. I know first gens do it too. Might not even shift out of 2nd on 1st gens actually, but for them there is a fuse they can pull to fix that. Kind of doubt that will work on 2nd gens though. Much more electronic.
  2. Dec 4, 2012 at 2:11 AM
    holapalli
    holapalli [OP] New Member
    PALL
    ICELAND
    07 TRD
    39,5" TIRES
    Yes, the tires are 39,5". When driving in deep snow we usually use 4lo so its good to have little bit more speed. Also i have two transfer cases to go extra slow in big hills, deep slush and powder. The most diffrens will be between 4LLOW 4 and 4LLOW OD.
    I think I only have to cut the black and yellow wire from the case to driving computer so i can go up to OD in low range, but I will try it next weekend and let you now.
  3. Dec 4, 2012 at 2:41 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I've gone into 5th in 4lo with my manual trany.
    The reason is I go 4lo when I hit the dirt since you cant go 4lo without stoping & you never know when you might need to go lower. I'll start in 2nd & go from there.
  4. Dec 4, 2012 at 10:30 AM
    BradyT88
    Nice!! What all have you done to that thing? Artictrucks kit and some extra stuff or what? Look damn good man.
    I have looked at the wiring diagram for the transfercase and what not, so I can't really say what will work. Sorry.
  5. Jan 16, 2013 at 7:11 PM
    BradyT88
    Did you ever get this figured out?
