Overdrive switch?
Discussion in 'Technical Chat' started by zkdawg, Feb 22, 2017.
  1. Feb 22, 2017 at 3:30 PM
    zkdawg
    zkdawg [OP] Greenville Taco
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Fog light mod, JBA LT headers, drop-in k&n filter, energy bushings, tried fold topper, 2nd air filter removed, all new stereo system minus subs, plastisol the wheels.
    I was just wondering if it is possible to make overdrive switchable? I say cuz I kind of sucks you can't use 5th gear w/o overdrive. So instead of having to switch in to 4th gear to turn it off, have a switch somewhere so you can turn it on/off yourself.
  2. Feb 22, 2017 at 5:05 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    5th gear is overdrive. So if you don't want to overdrive, shift into 4th which is a 1:1 ratio.
  3. Feb 23, 2017 at 6:52 AM
    tgear.shead
    tgear.shead Well-Known Member
    Yeah. What he said ^^^
  4. Feb 23, 2017 at 5:37 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Sounds like he's talking about the torque converter locking up.
  5. May 1, 2017 at 7:13 AM
    zkdawg
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Yes, I was wanting a switch the make it where I can stop the converter from locking up. I have been having problems where the truck has no go when I turn on my AC and I have noticed it is better when I have it in 4th gear, not allowing the converter to lock up. I have been watching the trans pan and converter temp on my scanner and the converter even while just sitting in drive will continue to get high, I mean in the 190+ range and it is norm around 160-165 area. That's why I have been suspecting it to be something with the converter or the electronics having to do with it. If I can control it manually, I can start to eliminate things and find out what the hell is going on. It only does it with the AC on and it started out of no where, instantly.
