Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. May 24, 2010 at 6:58 PM
    #481
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    worked like a champ....thanks SS!:):)
  2. May 24, 2010 at 8:13 PM
    #482
    misc
    misc [OP] Well-Known Member
    Glad we could help, gang. I didn't come up with the instructions, I just made them easier to do...
  3. May 26, 2010 at 1:13 PM
    #483
    bmac
    bmac New Member
    Brian
    Vancouver
    SR5 4X4
    New to the commuinty and wanted to pass on my thank you for saving time and $$$$
  4. May 26, 2010 at 10:03 PM
    #484
    bmac
    bmac New Member
    Brian
    Vancouver
    SR5 4X4
    Thanks again for your help on making this a simple fix! Although now I have reinstalled the components and my compass is working (only now giving me untrue readings) , although it is almost giving me an opposite reading, any ideas/
    Thank you soo much
  5. May 27, 2010 at 3:39 AM
    #485
    misc
    How far off is it? We've had some members be off by as much as 9deg, only to have it come true the next day...
  6. May 27, 2010 at 6:26 AM
    #486
    ExFordFan
    ExFordFan Semper Fi
    Mark
    Wauwatosa, WI.
    Stock
    I was reading this thread 2 weeks ago when I was going through this forum and found this particular thread intresting and thought to mself when mine quits working I'll know how to fix it. well the following day mine started working intermitantly and by the end of the week it didn't work. So that saturday I pulled it apart and repaired it using this thred. This thread jinxed my compass and thermometer......... Only kidding. Great thread and well written. Thanks.
  7. May 27, 2010 at 12:17 PM
    #487
    Dem1
    Dem1 Well-Known Member
    Demi
    California
    06 Tacoma TRD
    Leer Camper, Thule racks, Cobra Cb
    Mine just went out and I only have 34,000 and toyota is trying to charge me. Bull **it great trucks but toyota is pissing me off. Guess I be using the tips. thanks for the post
  8. May 27, 2010 at 12:35 PM
    #488
    ExFordFan
    ExFordFan Semper Fi
    Mark
    Wauwatosa, WI.
    Stock
    How much are they trying to charge you????
  9. May 27, 2010 at 12:47 PM
    #489
    LeadFootCaliKid
    LeadFootCaliKid It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    Thank you for writing this! Mine went out before I was a member on TW. I was really bummed when it did and even more bummed when Toyota told me $300 or something crazy for a new one. When I joined this site, I accidentally stumbled onto this thread and subscribed to it immediately. When I did my dash LEDs (the 1st time) I did this too. It worked when I tested it, then stopped working when I got everything put back together. Recently, when I did my dash LEDs for the 2nd time, I took the compass out and did it again with enough solder to rise it off the board a little bit. Thanks for saving me a bunch of green on something stupid.
  10. May 27, 2010 at 12:53 PM
    #490
    Dem1
    Demi
    California
    06 Tacoma TRD
    300 just for the part plus labor. I didnt even go that far though. Just kinda bummed stuff keeps breaking on my truck and I just bought it.
  11. May 27, 2010 at 1:02 PM
    #491
    CalgaryRider
    CalgaryRider Well-Known Member
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    2009 Tacoma SR5 Too many to list, but its a SR5 with a TRD Sport Heart
    Hey Guys, time to throw a new spin into the mix.
    I have a 2009 SR5 and I have recently been upgrading my SR5 parts to TRD parts, and one of the upgrades was the outside temp and nav upgrade. I connected everything in the console and the nav works great, but on the outside temp I only get the --- lines. Is there another sensor I need to get or is there something wrong with the board? I have yet to pull it out and look to see if the 510 needs to be re-soldered (thats the plan for tonight)
    The console is from an 06 TRD, so its in that time frame for a solder to go, but just wondering if there is something more I should be looking for?
    Thanks
  12. May 27, 2010 at 1:03 PM
    #492
    misc
    Do you have the sensor behind the grille?
  13. May 27, 2010 at 1:06 PM
    #493
    CalgaryRider
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    I will have to look when I get home. But most likely I do (as the SR5 is pretty much pre-wired for anything TRD)
    Whereabouts should I be looking and is it easy to identify?
  14. May 27, 2010 at 1:08 PM
    #494
    misc
  15. May 27, 2010 at 1:11 PM
    #495
    CalgaryRider
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    Man your quick!!!
    I will definitely know what I'm looking for now! Thanks for the help!
  16. May 27, 2010 at 1:18 PM
    #496
    Dem1
    Demi
    California
    06 Tacoma TRD
    Im about to take mine apart. Ill let you guys know how it goes. Thanks to the thread author!!!
  17. May 27, 2010 at 5:36 PM
    #497
    Dem1
    Demi
    California
    06 Tacoma TRD
    So I took it all apart looked at everything and all the solders looked fine. The lcd however had a burn mark in the right bottom corner? So i looked some more and figured id just resolder the chips anyways........ put it all together and IT WORKS! Im stoked! Thanks again!!!
  18. Jun 1, 2010 at 7:08 PM
    #498
    dmicgrif
    dmicgrif Well-Known Member
    mike
    kihei, maui
    2005, 4x4, 4 door, LB, black all over
    just got my truck, mine doesn't work so glad that toyato of wilmington is fixing it for free.
  19. Jun 4, 2010 at 11:24 AM
    #499
    fjm0008
    fjm0008 Well-Known Member
    Jack
    Annapolis
    06 4x4 LB White
    Sirius Starmate and ipod integration w/Pay15 Toy USA Spec, Hardwired Radar Detector and GPS, DRL Mod,Tailgate Anti Theft mod, Hi Lift Jack, CB Radio, Back up sensors, Front 30% tint, Leer 100R Cap, Weathertech, Under hood light and 12V outlet, D Rings, N-FAB Step Bars, Bed Mat, Yakima Bike Rack, OEM Roof Rack
    2006 with 36500 miles, it waited until the warranty expired to go out on me. I will be taking it apart tonight. Thanks for the help!
  20. Jun 4, 2010 at 11:42 AM
    #500
    JKD
    JKD Well-Known Member
    The way the temperature is sent to the display changed in 09. Your 06 module will not work in your 09 truck. (In 09 they switched to sending the temp signal on the AC control bus.)
    You need an 09-10 module.
