Overhead compass
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nazlax10, Apr 8, 2016.
  1. Apr 8, 2016 at 9:21 PM
    #41
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    So even though you set the zone it'll still end up going to CAL mode? Try just setting it on your zone and see if that work.
  2. Apr 9, 2016 at 2:15 AM
    #42
    nazlax10
    nazlax10 [OP] Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    I tried that and yes it still is locked essentially in calibration mode. Which I guess all this makes senses because the vss isn't connected so the unit thinks the vehicle isn't moving at all.
  3. Apr 9, 2016 at 7:30 AM
    #43
    nazlax10
    David
    Woodstock, GA
    You guys are awesome @adio:bowdown:, and @Up2NoGood:bowdown:!! I went out this morning, hooked into wire number one and drove to the gas station. About half way there voila it worked! :D:D:thumbsup::bananadance:. That's the positive side. The negative is my neighbors are probably keeping a close eye on me because yesterday I'm driving around in circles in a playground parking lot and today I have a bunch of wires hanging from my roof, screaming in excitement driving down the road haha. Thank you guys so much. I love having a fully functional overhead console instead of 2 sunglasses holders.
    adio, kgarrett11 and yote like this.
  4. Apr 9, 2016 at 10:48 AM
    #44
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    So you couldn't wait until I could help you out? I figured lol. Looks great Dave, good job. I think the only way for you to properly thank everyone is to do a proper write up since I imagine we will soon be starting a console trend here on TW :D :fingerscrossed:
    You @adio & @Up2NoGood are a bunch of badasses
  5. Apr 9, 2016 at 10:52 AM
    #45
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Can I swap out my bluetooth mic thats between the map lights into my new console? Did any of you guys do that? I dont use it a whole lot but at the same time I dont want to lose it.
  6. Apr 9, 2016 at 11:09 AM
    #46
    nazlax10
    David
    Woodstock, GA
    I would do a write up but didn't take any pictures since it wasn't really going my way lol.
  7. Apr 9, 2016 at 11:13 AM
    #47
    nazlax10
    David
    Woodstock, GA
    That piece is not swappable lol. What I did was take out the front sunglasses holder, then take out the digital display and put that in. I used an exacto knife to cut the plastic welds and then expoxy to put it back together. I can do the swap for free if you send me both consoles :D
  8. Apr 9, 2016 at 11:39 AM
    #48
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Oh so instead of swapping the entire console, you just swapped the front sunglass section? hmm id what I want to do, I was just planning on doing a full swap, maybe I can relocate the mic? I'm sure there are threads on it. I will compare both consoles when it comes in and see if I'm comfortable with cutting it out and make a decision after I look things over. Thanks for the offer, I might take you up on it. I will keep you updated on what i decide to do.
  9. Apr 9, 2016 at 12:58 PM
    #49
    nazlax10
    David
    Woodstock, GA
    Sounds good:thumbsup:
  10. Apr 9, 2016 at 2:16 PM
    #50
    adio
    HI
    Great to hear you got it working.
    So was it the VSS wire after all?
  11. Apr 9, 2016 at 2:24 PM
    #51
    nazlax10
    David
    Woodstock, GA
    I'm assuming it was. I hooked up one wire and it worked! Magic haha
    adio[QUOTED] likes this.
  12. May 11, 2016 at 12:00 AM
    #52
    adio
    HI
    @nazlax10 @kgarrett11 @Up2NoGood
    Finally changed out the screen to that green/blue-ish look. More in line with the display on any rear view mirrors.
    Before.
    1E611EC6-D637-409F-B847-5306B8148002_zps_280dc318226945dfcb2850ead8cd0514e527cfe1.jpg
    After. Bye bye amber.
    FB195725-00F8-4E57-BF22-D5EBB2AE3535_zps_56099dea029e5d19c2403054c239adad3b55ea3b.jpg
    Screen is from 97-01 Ford Explorer. Tried looking for one that had the cool white, but couldn't find anything.
    FE8F19A1-B529-447A-8EFB-086BF045066E_zps_c691fdbdbdab4c97b0c3eaf836f54cf3afbe82be.jpg
    Original screen that you need to re-solder and replace with the 97-01 Explorer screen.
    06BECEC9-EBD3-48E8-8866-C5A0025DC815_zps_7396a7b1d2955406453707b9a7716837c7b3158d.jpg
    Original amber screen on the right. 97-01 Explorer on the left.
    A5077864-EB4C-4E68-ABE0-8C81AAE17FBC_zps_d0acceaf18644f84184746116ba79af71b02f898.jpg
    Not an expert at soldering as you can see haha. As long as the solder is in good contact it'll work.
    34CD99A7-DAF2-4B54-BE90-015347DA93A3_zps_d4b33cde87d22ab111d05f2ea8074c95346bd1a6.jpg
    kgarrett11 and jmaack like this.
  13. May 11, 2016 at 4:49 AM
    #53
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  14. May 11, 2016 at 5:12 AM
    #54
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Nice work changing colors.
    adio likes this.
  15. May 11, 2016 at 5:17 AM
    #55
    nazlax10
    David
    Woodstock, GA
    That looks awesome man, great work :thumbsup:
    adio likes this.
  16. Mar 15, 2017 at 4:58 PM
    #56
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    Does anyone have a parts list for this?
    I just got my overhead console and am looking to get started on the install for this.
    @nazlax10 @adio @kgarrett11
  17. Mar 15, 2017 at 5:52 PM
    #57
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Once u get the console you are set my man!
  18. Mar 15, 2017 at 5:58 PM
    #58
    big_jarv
    2020 TRD Pro
    Is there a specific temperature probe I need? Or any special wiring?
    kgarrett11[QUOTED] likes this.
  19. Mar 15, 2017 at 6:09 PM
    #59
    nazlax10
    David
    Woodstock, GA
    No real special wiring. You should already have the probe attached to your horn support bracket in front of the radiator. You'll just run two wires into the cab from that probe to your console. Then power, ground, and switched power, and you'll need a vss input. On the back of the radio it's the purple with white stripe. The vss gives the until the compass input. The wiring is all listed here.
    kgarrett11 and big_jarv[QUOTED] like this.
  20. Mar 15, 2017 at 6:11 PM
    #60
    nazlax10
    David
    Woodstock, GA
    Here's a pic of the temp probe so you know what you're looking for.
