Overhead Console Compass
Discussion in '2nd Gen. Tacomas (2005-2015)' started by B_brand, Mar 20, 2010.
  1. Mar 20, 2010 at 3:16 PM
    B_brand
    B_brand [OP] Well-Known Member
    Brandon
    Oklahoma
    I have a 2010 DC SR5. In the overhead console it has a place to put a garage door opener. Does anyone know if I can change this so I can have a compass and thermometer like the TRDs? I am not sure if all the wiring is in place for a compass and thermometer. Has anyone else done this??
  2. Mar 20, 2010 at 3:42 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    All the wiring is there. The hard part is acquiring the the compass/temp overhead console at a reasonable price. Only a compass/temp from an '09/'10 will work in your truck.
  3. Mar 20, 2010 at 3:48 PM
    B_brand
    Brandon
    Oklahoma
    Do you have to replace the whole console or can you just take out the garage door opener holder and put in the compass?
  4. Mar 23, 2010 at 4:15 PM
    kevinva
    kevinva Active Member
    Virginia
    09 Double Cab SR5 4x4 Longbed
    I replaced the whole console in my 2009 SR5 with a console from a 2009 TRD that I bought off of Ebay and it just plugged in to the connector and worked. Just make sure you get a 2009 or 2010 console, because the 05-08 consoles will not work in the 09-10 trucks (and the 09-10 consoles will not work in the 05-08 trucks).
    Toyota part number 83290-04011 is for just the temperature/compass portion of the console. I believe that it is designed to swap with a non-functional temp/compass module rather than to replace the garage door opener compartment, so I don't know whether it would do what you want.
    If you do a search for "overhead console" here on TacomaWorld you will find quite a bit of information from people who have swapped out their consoles.
  5. Mar 23, 2010 at 4:32 PM
    normbal
    normbal Well-Known Member
    Norm
    socialist occupied Maryland
    White SR5 long bed
    minor mods. Hood moustache, truckchamp SS oval step-bars, Go Rhino Hitch step, popnlock plus tailgate hoseclamp, Weathertech digitalfit floor mats. Wheel and spare tire locks.
    Spent about a half hour obsessing over this last week; found several sources for the part for about $200 plus S&H. I'm not flying an airplane. Calculating density altitude on my driveway isn't going to make a difference in whether I overshoot the stop sign at the end of my street. At $200 I can live without it, but I will check w/ eBay and some salvage yards from time to time. If I find one for $100, I'll jump on it.
    Google the part number above and you'll find some listings.
  6. Mar 24, 2010 at 5:32 PM
    B_brand
    Brandon
    Oklahoma
    Thank you guys for the help!
