Overhead Console Temperature Display
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RaininTacos, Feb 10, 2021.
  1. Feb 10, 2021 at 6:18 PM
    RaininTacos
    RaininTacos [OP] Member
    2006 Access Cab 4x4
    I have a ‘06 Access Cab 4x4 Base. Been looking at changing out the overhead console for a unit that has the temperature and direction display. However, I have seen a few threads discussing problems with the electronics in those units.
    Came across this ‘Updated’ unit yesterday.
    https://www.amazon.com/gp/product/B00BUSOKBQ/ref=ask_ql_qh_dp_hza
    Two questions
    1. Does anybody have experience with this updated unit? Is it an improvement?
    2. Can this be installed in the empty space in my existing console or is it necessary to buy a whole upper console with this part installed?
    Thanks
  2. Feb 10, 2021 at 6:53 PM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I bought one of those, and the electronics design has been "fixed" from the flawed original circuit board. The initial one died after a few years, but this replacement has been going strong for at least 10 years. If you don't want to have to resolder the board every year, buy one of these and forget about it!
    Pretty sure you need a new overhead console that was designed to hold it.
    Before jumping through those hoops, do a quick check to see if your base truck has the wiring. If it does, you'll also need a thermistor which is about $20 at your local Toyota dealer. I found the thermistor connector taped up to a wiring harness behind the grill. I initially didn't think I had it, but it was there (in my 08 X-Runner). X-Runners didn't come with that overhead console, but it was pre-wired for it.
    Good luck!
    TRDSport10 likes this.
  3. Feb 10, 2021 at 7:49 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Not worth it. I grabbed the 47 ohm resistors at Fry's (100 for $4.27) and soldered them in. Thing's working like a charm. I can drop a pair in an envelope for you if you'd like, it's a 10 minute repair.
    The problem is a pair of resistors on the board. They wind up failing and soldering them is a pain as you'll have to use a hot air rework station and still contend with the SMT component's ability to contend with the heat it generates and the ambient conditions.
  4. Feb 10, 2021 at 8:03 PM
    dbbd1
    dbbd1 Well-Known Member
    Just buy the resistors.
  5. Feb 10, 2021 at 8:13 PM
    RaininTacos
    2006 Access Cab 4x4
    EdgemanVA likes this.
  6. Feb 10, 2021 at 8:33 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    EdgemanVA and TRDSport10 like this.
  7. Feb 11, 2021 at 6:16 AM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    The X-Runners are oddballs in this regard.
    Mine has the temp sensor in place under the hood and is wired to the overhead console. The wiring (at least power) is connected, I had my dashcam powered from there for a few years.
    While the temp/compass is fairly pointless, I have gotten pretty used to having it in my 2011 4x4 so I may just go ahead and replace the sunglass melter and garage door opener holder with something I will actually look at and use.
    And yes, you do need to replace the whole overhead console.
    EdgemanVA[QUOTED] likes this.
  8. Feb 11, 2021 at 8:04 AM
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    That looks like it, and Amazon says it fits my Tacoma, so I think that's the one.
  9. Feb 11, 2021 at 1:13 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    They're 47 ohm? For some reason I have 51 Ohm written down and was getting ready to order some.
  10. Feb 11, 2021 at 1:36 PM
    Taco 422
    USA
    The SMT's are 51 ohm, Fry's had 47 ohm 1/4 watt then jumpped to k-ohm values. One or two of the writeups used 47 ohm and they worked, I've had no problem over the last three days on and off road.
    I suggest some tubing for safety/good practice, but there's enough room you can space them apart.
    I can send you 2 or 3 in an envelope if you'd like.
    This guy seemed down to earth and to have put in a little thought.
    https://siliconmethod.com/diy-tacoma-display-repair-guide/
