Overheating during towing
Discussion in 'Towing' started by jroach321, May 30, 2008.
  1. May 30, 2008 at 8:04 PM
    jroach321
    jroach321 [OP] Member
    Chattanooga
    01 TAcoma 4x4 white
    thanks for everything guys!
  2. May 30, 2008 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like an oil cooler. Your tranny cooler is integrated into the radiator. You can see the tranny lines going into it near the bottom.
  3. May 30, 2008 at 9:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It just dawned on me that you said the boat was 4000 lbs. If you are going by the boat weight, that does not include fuel, trailer, or anything else in the boat. If this is the case, you could be well over 5000 lbs.
  4. May 30, 2008 at 9:23 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Thanks Chris!!!
  5. Jun 3, 2008 at 11:47 AM
    AFBombdude
    AFBombdude Member
    Litchfield, AZ
    '01 PreRunner SR5
    Bone Stock for now
    You could run an electric "pusher" fan on the front of the radiator. Turn it on/off manually before the hills.
  6. Jun 4, 2008 at 1:23 PM
    Front Runner
    Front Runner Member
    NC
    06 Reg. Cab 2.7L Automatic
    This may be a stupid question, but how do you know the tranny got hot also???
  7. Jun 4, 2008 at 4:17 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You don't..... these trucks don't have any sort of tranny temp gauges.
    However - If these toyota trucks are anything like the Jeep Grand Cherokee we used to own..... if you have any problems with the tranny itself (based on data the computer is reading from it) - the system will go into LIMP mode and prevent the transmission from destroying itself.
    When I say LIMP Mode - I mean, it'll shift hard and/or strange - missing gears, etc. You might even get a CEL if it gets too bad.
    But again, just a guess.... I would hope they are setup like this to prevent damage.
  8. Jun 4, 2008 at 4:51 PM
    Front Runner
    Front Runner Member
    NC
    Limp mode would be nice. I wonder what do we have on our trucks to prevent the tranny from destroying itself????
  9. Jun 4, 2008 at 8:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The newer trucks with autos have a tranny temp light that will iluminate when the tranny starts to get hot. I cant remember at what temp it lights up.
  10. Jun 4, 2008 at 10:26 PM
    Janster
    Jandy
    Lancaster, PA
    Which reminds me.....<off topic> is Scangauge ever gonna come out with tranny temps?
  11. Jun 5, 2008 at 4:26 AM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    I assumed the tranny was hot because i could not touch the metal part of the shifter.
  12. Jun 5, 2008 at 11:18 AM
    Front Runner
    Front Runner Member
    NC
    When you say "newer", would that apply to my 06 also?
  13. Jun 5, 2008 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Not sure what year they started with the tranny dummy light, but 05's and up have it. :)
