Overheating during towing
Discussion in 'Towing' started by jroach321, May 30, 2008.
  1. May 30, 2008 at 7:23 PM
    jroach321
    jroach321 [OP] Member
    Chattanooga
    01 TAcoma 4x4 white
    My 01 tacoma 4x4 3.4 is overheating on every hill when i pull my 4000lb boat. It does great on flat but overheats immediatly on hills. Overdrive is off and ect/power is on. I know its a bit much to tow but it shouldnt be overheating.
    any suggestions besides the obvious tranny cooler
  2. May 30, 2008 at 7:33 PM
    MotoXFreeStyle61
    MotoXFreeStyle61 Displaced Texan
    San Antonio TX
    06 PreRunner SR5 4Cyl, Access Cab, 5
    Black Head Light Mod, Tacoma All Weather Mats, ScanGauge II, Tonnaeu Bed Cover, 40% Tint, Added Fog Lights, 600W x 1 Alpine MRP-M650 Amp, Alpine 10" Type-R SWR-1022D Sub, Secondary Air Filter Removed, Day Time Running Lights, K&N Drop In Air Filter (oiled), Westin Bullbar (Black Powder), Alpine IVA-W505 w/Nav, JL Audio 6.5" Front Speakers, Toyota SR5 Seat Covers, 2.5" Toytec Spacer
    maverick491 is definitely the guy to talk to. I would read this over before you go asking questions, if you haven't already. He goes over a tone in there.
    http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
  3. May 30, 2008 at 7:36 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I'm getting Chris4x4 on this too-but our towing capacity for 2001 V6 is 5000lbs so it's not the weight-maybe your cooling ststem needs attention.
  4. May 30, 2008 at 7:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like it could be your clutch fan. Are the fluids good? Thermostat good? What color is the fluid? Do you have a tranny cooler?
  5. May 30, 2008 at 7:46 PM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    it just seems strange that its only on hills. its like the tranny heats up almost instantly and causes the truck to overheat.
  6. May 30, 2008 at 7:49 PM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    fluid is at the right level and thermostat would cause spikes at other times other than just hills. Fan has resistance when turned off and clutch is not locked up. Coolant is green... I know i know it should be red. but do you think not running toyota coolant would do this?
  7. May 30, 2008 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That could be the case, as the tranny is not going to lock up into the lower gears. Have you towed the boat before without isses?
  8. May 30, 2008 at 7:49 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Think of it this way... You're towing capacity is 5,000lbs. You're towing 4,000lbs.
    When you're driving uphill, that 4,000lbs is a lot heavier and takes a lot more effort. You lose momentum and need the additional power to get it up the hill. That is not uncommon for vehicles being expected to tow close to their rated limits.
    When was the last time you checked your radiator fluid? Do you have enough in it? Is your overflow tank at the full mark? What is your fluid rated to? Are your fans working? When was the last time you had a radiator flush?
    We had a 99 Grand Cherokee that we towed 6500lbs with to Tellico a couple times. Rated capacity is 6500lbs. Guess what? Every hill, the temp gauge went into the red and every downhill, it went back down again. Typical....but not alarming.
  9. May 30, 2008 at 7:51 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I would advise leaving the 'ect switch' in off position because IMO it being on prevents the torque converter from locking out at 52MPH like it would in normal mode and may cause tranny to overspin unneccesarily
  10. May 30, 2008 at 7:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im thinking that you need a tranny cooler. I dont think that your year had one.
    Chapito likes this.
  11. May 30, 2008 at 7:52 PM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    first time for boat pull. fluid is at correct level. And that a jeep thing! jk
  12. May 30, 2008 at 7:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    He said that he takes the tranny out of O.D., and I dont think that the tranny locks up in 3rd on that year of truck. But, good thinking.
  13. May 30, 2008 at 7:54 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Where wuold it be located Chris...cause on mine I see a small rectanular one right in front of the AC cooler-is that for oil?
  14. May 30, 2008 at 7:54 PM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    i agree with the tranny cooler. i just thought it seemed like something else may be wrong. does toyota coolant make a difference?
  15. May 30, 2008 at 7:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok then. Add a tranny cooler. Then try towing the boat at a slower speed. You may also want to do as Janster stated and have the cooling system flushed. Also add some "water wetter". It helps keep the engine cool. :)
  16. May 30, 2008 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    How big is it?
  17. May 30, 2008 at 7:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It shouldnt.
  18. May 30, 2008 at 7:59 PM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    Since the tranny did get hot, should i change the fluid now?
  19. May 30, 2008 at 8:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Autos are REALLY sensitive to the heat. If you think you got it hot, change it.
  20. May 30, 2008 at 8:04 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    If memory serves me it's about 2''x6''
