Overheating Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, Jun 1, 2021.
  1. Jun 1, 2021 at 6:50 PM
    iJDub
    iJDub [OP] Well-Known Member
    I was towing about 5000 lbs of rock in a trailer today. I was stopped on a hill (uphill) and had the car in drive, but my foot on the brakes. I noticed my temp gauge went up from the normal half way mark to about 3/4 way to max temp. I shifted the transmission to neutral and the temps dropped after a minute or so.
    1) Why would the water temp shoot up in drive vs neutral if I was stopped?
    2) Could there be any damage to the engine if it was 3/4 for about 3-5 minutes?
    Thanks!
  2. Jun 1, 2021 at 6:53 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    No damage to the engine!
    In drive the engine is trying to overcome the static friction of the torque converter, but has less air-flow because you're stopped. In neutral it's spinning freely.
    TnShooter likes this.
  3. Jun 1, 2021 at 6:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Where you still on the hill when the temps dropped?
    My truck idles higher in P and N.
    But not much more. Not enough to blow that much more air across the engine, but maybe.
    Have you checked the fluid level in the radiator?
  4. Jun 1, 2021 at 6:58 PM
    iJDub
    I was still on the hill when the temps dropped. Fluid level normal. It was a hot day (about 100 degrees) - hopefully everything's fine.
  5. Jun 1, 2021 at 7:19 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’m in agreement with no damage done. You gave the cooling system and transmission a good work out. If the temperature needle was buried in full hot and you floored it the rest of the way up the hill, that can possibly cause damage.
    If you haul that much weight in hot air regularly, you might consider adding a transmission cooler. Even if yours has a towing package, it could extend the life of your transmission. I put one in a different vehicle that had a thermostat controlled fan, worked good, it was a b&m.
  6. Jun 1, 2021 at 7:28 PM
    iJDub
    This was a one time thing - just to remove the gravel from my back yard. Thanks for the input guys!
  7. Jun 1, 2021 at 7:31 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    See, that could potentially be a problem because the temp gauge needle on these trucks are designed to go to to half and stay that way until you have overheated it. If you see anything above half there is a good chance you were already at 230+ degree territory. Maybe even 250-260+ degrees.
    Do yourself a favor and when you tow, leave it in 4 when going up hills, this is especially true when in steep terrain for extended periods of time. A real temperature gauge (and not just going off the OE dummy gauge) may be a good thing to look into as well. Especially if you tow often.
    AEM makes a direct plug in X series gauge (it should be PN: 30-0300) to the OBD2 plug which reads the temp output directly from the PCM. This way you have absolute direct information of your coolant temperature at all times.
