Overland Drawer Build- DIY Camping Drawers- Pic Heavy Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Jun 16, 2018.
  1. Jul 14, 2018 at 6:01 PM
    #41
    Hawco636
    Hawco636 Great White North
    2010 MGM SR5 - V6 Manual
    I have to agree with @ChainsawCharlie
    The slides are engineered to handle X lbs in a certain orientation. Maybe there are specific slides for your desired application, but the ones you have used so far would only be suited for the way they are used.
    ChainsawCharlie likes this.
  2. Jul 14, 2018 at 7:58 PM
    #42
    Papadave418
    Papadave418 [OP] Well-Known Member
    Thanks for the feedback. I failed to explain this concept well, so I went back to my trusty yellow binder paper blue prints. The sliders are vertical but resting right on the truck bed connected only by the base between the sliders and a rear board to anchor it and keep the sliders vertical. The rough plans might help visualize my idea. Usually sliders are screwed to a cabinet wall, these would be free standing. They are HEAVY and strong, think it would work?
    Photo of the sliders, I think they could potentially hold the weight directly
    Imagine the bed slide under the cooler in this orientation
    rmac010 and Biohazard495 like this.
  3. Jul 15, 2018 at 10:31 PM
    #43
    Papadave418
    Ok now I’m looking at another option for a slide. Thinking about using T-Track slides meant for table saw slide jigs with a rectangle T nut. So the T-Track would attach to the bed of the truck directly in between the grooves. The plywood slide would have 2 T Nuts that attach from the bottom and hooked into the T-Tracks. At the far end of the slide the T Nuts would anchor the slide as it extends out of the truck. With a little grease I think the T nuts would slide well in the track. I would put a thin plastic sheet on the bottom of the bed slide so that it slides easily against the composite bed, and that would take the load of the bed slide. The T Nuts would keep the bed slide from leaning out of the truck. A lot of words to describe a simple thing!
    Mini T-Track slides
    T Slot nuts
    Dimensions
  4. Jul 16, 2018 at 12:21 AM
    #44
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    Damn. OP got some mad design and construction skills.
    Looks nice! Very well laid out and executed.
    Papadave418[OP] likes this.
  5. Jul 16, 2018 at 8:42 AM
    #45
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Lee valley sells veritas t slot track and its cheaper i believe. Fyi.
  6. Jul 16, 2018 at 8:57 AM
    #46
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Love seeing the competition :thumbsup: GREAT work man!
  7. Jul 16, 2018 at 9:10 AM
    #47
    s.e.charles
    s.e.charles Well-Known Member
    very trick!
  8. Jul 16, 2018 at 8:41 PM
    #48
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Very nice!
  9. Jul 22, 2018 at 3:05 PM
    #49
    Long Time Toy Fan
    Long Time Toy Fan Well-Known Member
    17 DCOR
    Cookie cutter Tacoma, 888/Dakars/LR/ECGS/Sliders
    MTB question, is your son's bike a Trance jr 26? If so is it legit? How was it on Whistler? I'm thinking about one for my son and there is very little info out there. Also sweet Trance 2 and drawer system.
  10. Jul 22, 2018 at 3:43 PM
    #50
    Papadave418
    I got him the Stance which is basically a Trance junior. Components aren’t quite as nice but I figured he’d out grow it long before he wore it out. It did great at Whistler. I would catch up on the downhill straights purely based on that I have more mass, but I was surprised how well it did. He loves it. It’s 26er
  11. Jul 25, 2018 at 1:28 PM
    #51
    KapitanWalnut
    KapitanWalnut Well-Known Member
    Kurt
    Colorado
    '16 DCSB TRDOR Inferno
    Always position your "C" channel slider such that the long side of the profile (the back of the "C") is in line with the line of force. So, in a drawer system, the static force is from gravity pulling downward vertically, so you want the "C" channel set up vertically. You also need to use something to ensure that the back of the "C" stays parallel with the line of force - this is why the channel is secured to a plumb frame (the body of the drawer). If the back of the C is allowed to rotate away from vertical, then a force concentration will appear on the corner of the channel's profile. This will become a sheer or draw point - the point of mechanical failure. So, the frame that the channel is secured to must not twist easily.
    Finally, note that bolting something into the end-grain of a 2x4 or the side of a piece of plywood is one of the least secure mounting methods. That's why you never see butt joints in a load bearing scenario. In your case, the screw going into the edge of the plywood is just going in between the various layers, and these layers will pull apart quite easily, so it really won't be able to hold much weight. You could increase the load capacity by putting thin strips of wood on the top and bottom, then bolting through the whole stack effectively clamping the edge together.
    MJTH likes this.
  12. Jul 25, 2018 at 1:28 PM
    #52
    KapitanWalnut
    Kurt
    Colorado
    Really nice build! I enjoyed checking it out.
  13. Jul 25, 2018 at 4:31 PM
    #53
    Papadave418
    Thanks for the info!!
  14. Aug 2, 2018 at 7:46 AM
    #54
    Jcannon
    Jcannon Well-Known Member
    Jay
    OKC, OK
    05 DC 4x4 TRD OR
    Really nice, starting to look at building some for mine.
  15. Aug 2, 2018 at 9:06 PM
    #55
    Papadave418
    Do it, it totally changed camping for me. Heading to Lake Tahoe CA tomorrow with it!
  16. Aug 3, 2018 at 12:09 AM
    #56
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    nice build!
  17. Sep 14, 2018 at 3:56 AM
    #57
    Cullen@GotExhaust
    Cullen@GotExhaust Well-Known Member Vendor
    Cullen
    Virginia
    White 2019 Tacoma TRD Off-Road
    Stock
    Hats off to you my friend, this is awesome!:hattip:
  18. Sep 14, 2018 at 1:24 PM
    #58
    Papadave418
    Thanks!
  19. Sep 18, 2018 at 10:18 AM
    #59
    Blackwolf
    Blackwolf Well-Known Member
    Paul
    Northern VA
    2018 Inferno DCSB TRD Off-Road
    Great writeup! I have been brainstorming some ideas for a low-profile bed slide system for under my tonneau as well
  20. Sep 19, 2018 at 2:10 PM
    #60
    kisstoo
    kisstoo Life is a journey.
    Bhatti
    Corona, California
    Toyota Tacoma TRD 4X4 Off road
    Awsome, i am getting my diamondback cover soon and your project will be a great help to come up some thing like that. thanks a lot for sharing.
