Overland Torque Tune (OTT) by Overland Tailor
Discussion in 'Performance and Tuning' started by JustDSM, Mar 20, 2022.
  1. Mar 23, 2022 at 4:28 PM
    JustDSM
    JustDSM [OP] Oderint Dum Metuant
    Justin
    Ogden, UT
    Thanks so much for stopping in and sharing your thoughts about how OTT is working out for you! Without the support of our tuners and folks like you, the Toyota tuning market not be what it is today. It really is a treat we have the many options available from the various tuners. Gives you the ability to find something that fits your unique needs. So thank you for your willingness to give OTT your trust.
    @Bagelmobile: if you feel like your throttle setting isn't 100% to your liking be sure to let us or your tuner know. We have options, and if something custom is in order, we can work with you on that. It's important to us you get what you need.
  2. Mar 23, 2022 at 4:30 PM
    JustDSM
    Justin
    Ogden, UT
    You guys are gettin' after it! :) Love it!
  3. Mar 23, 2022 at 8:00 PM
    HRC4
    HRC4 Member
    2020 Tacoma TRD Pro MT
    URD short shift kit 265 75 16 Goodyear Duratrac's
    @Bagelmobile: if you feel like your throttle setting isn't 100% to your liking be sure to let us or your tuner know. We have options, and if something custom is in order, we can work with you on that. It's important to us you get what you need.[/QUOTE]
    I mentioned to my tuner about offering an “S” shape sort of throttle feed for the manual trucks. I’d like to try something that has a very easy feed for the first say 7-9% for easy city driving, and good highway manners while cruising (not sure how deep the accelerator is while cruising at 70-75) and then sweep into a more aggressive setting where you want to have the meat when you need it to pick up quickly, and then it can sign off the last say 10% because really there isn’t a need to push that deep into the pedal anyway.. those percentages are just a guess and not an accurate idea.. it helps to not have a choppy or snatchy feel especially if in low range and off roading.
    JustDSM[OP] likes this.
  4. Mar 23, 2022 at 8:25 PM
    MaxTaco6
    MaxTaco6 Well-Known Member
    Vancouver, BC
    2022 TRD OR Lunar rock
    It's been 3 weeks since I got the tune. I must say driving is much better and more enjoyable than stock. Major improvements: 1. No moore sluggish start, it basically feels more powerful at low speed, it just pulls. 2. No more awkward shifting when up and down the hill. Thanks for the tune @dave82at
    e46_ema, HRC4, LstMinutePanic and 2 others like this.
  5. Mar 24, 2022 at 7:52 AM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    The mythical Canadian ACLB OR 6MT model. Nice to see.
  6. Mar 24, 2022 at 7:12 PM
    Phil1717
    Phil1717 New Member
    Phil
    2020 White Tacoma TRD
    lift, different wheels and tires, different grill
    I have a 2020 Toyota Tacoma TRD Off-Road Premium and have gone to David (Yota Tune) in Burlington, Ontario three times to get my truck tuned. The Overlander (OTT7) Tune is by far the smoothest, most torque, best fuel efficient I've found and eliminates gear hunting making the trucks' transmission run like how it should have been from the factory. I had the KDMax tune prior to this one and found that is was jerky, the gears would hang on too long and I knew there was room for improvement. Mind you, my throttle response is the non-aggressive one because the aggressive is too jerky and aggressive for my liking. I look forward to the updates for the Overlander (OTT7) tune and will be going back to get the latest version of it whenever possible.
    JustDSM[OP] and BortisYeltzen like this.
  7. Mar 25, 2022 at 8:43 AM
    JustDSM
    Justin
    Ogden, UT
    HRC4 - Depending on the configuration of your truck - It's weight, tire size, gearing, and amount of drag present will all factor into the equation. There's also some environmental factors at play such as density altitude, slope/grade, etc. that provide some external influence to where someone may be with pedal input to maintain a given highway speed. Lots of variables!
    Sounds like you're looking for something akin to a logistic growth curve that I'm familiar with..
    What you're looking for is pretty easily accomplished in the calibration but it's a very slippery slope to put into practice for for the masses. As the variables mentioned above mean many folks require vastly different pedal percentages to maintain their preferred cruising speed. Configuring the "ramp-up" in throttle application too close to the cruising pedal percentage will cause the truck to have a tendency to surge forward anytime additional speed is required or as you approach an incline making the truck potentially jerky when cruising at speeds slightly above your typical cruising speed. Configuring the ramp-up point too far out will largely defeat the purpose of what you're looking for in addition to making the progressiveness of the throttle very steep meaning any pedal input within the ramp-up area will likely be very sensitive/touchy.
    There are also fueling considerations to factor in, as for many (especially during difficult times) fuel economy is an important consideration for many and this type of throttle mapping would have some adverse affects.
    One critical performance metric OTT has been committed too, is development of a throttle mapping strategy that is consistent and predictable with how the throttle is controlled. While our auto offerings are not quite as progressive as what you're looking for, if it's something you absolutely feel you need - we can work on something for you.
    HRC4[QUOTED] and cemented like this.
  8. Mar 25, 2022 at 9:31 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I'm thinking they're asking for that curve because it mimics a drive by cable setup.
    @HRC4, is that your intention? If so, it's a fairly simple calculation to achieve for sure, but you would need to keep in mind that other maps can affect how far the throttle opens. Even though it's set to open at 50% per the 2D throttle maps, other maps may limit it to 40%.
  9. Mar 25, 2022 at 10:25 PM
    HRC4
    HRC4 Member
    @JustDSM Yes I’m sure there are an infinite number of variables to consider that is way over my head here. My thinking here is the beginning portion of the throttle to have an instant reaction but with a slow input. Any bump on a road in a direct drive truck especially in a lower gear makes for a choppy and snatchy drive that requires a constant effort to control. An auto truck gets the benefit of the torque converter and a taller rear ratio to feather out any throttle jolting. Our roads up in Canada are a disaster from frost heaving and municipalities not caring to repair them, so we all seriously need an off road truck to get around these days haha. I was also thinking the same thing once up to highway cruising speeds, that economy might be slightly better if there was less “involuntary reaching” into the throttle if it was over sensitive.. I am on the light setting now, and couldn’t imagine what the aggressive would be like to drive, especially in low range on a rough trail! I do miss the old cable trucks that reacted instantly to the input when playing off road, it’s tougher to bump up over things when the truck responds a second late.
    @ktbell444 yes I would love a drive by cable feel. It’s the only real way to be able to drive a manual truck, well, like a manual truck.
    ktbell444 likes this.
  10. Mar 26, 2022 at 11:40 AM
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    This tune cannot be beat for big heavy trucks, as one can assume from the “Overland” name.
    But assuming it’s only for big heavy trucks is a mistake. Stock and mildly modified trucks see huge gains, AT and MT options are both strong.
    4.0L tunes done with HPTuners are equally incredible.
    2010 Tacoma:
    2008 FJ
    This Overland Tailor family of tunes is unmatched. Lots of other tunes making noise, but Overland Tailor just quietly getting the job done and making people happy. There is something to their data driven process.
    If you are in Utah and want to test these tunes, please reach out and I am happy to put this family of tunes against any other tune on the market.
  11. Mar 26, 2022 at 12:36 PM
    MLee
    MLee Well-Known Member
    Mark
    Knoxville TN
    2018 Limited Cement
    OTT 7.0
    Do you offer VIN protected files for those of us that can flash our own trucks?
    timclark82 and JasonLee like this.
  12. Mar 26, 2022 at 12:44 PM
    JustDSM
    Justin
    Ogden, UT
    Indeed we do. Please PM @Boltripper or email him at info@overlandtailor.com.
  13. Mar 27, 2022 at 10:01 AM
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Free thread bump
    :cheers:
    PNWTacoma and JustDSM[OP] like this.
  14. Mar 29, 2022 at 4:20 PM
    gpdx
    gpdx Well-Known Member
    Portland
    13 DCSB TRD Offroad
    5100/887, topper, rack, 265/75/16
    I’ve had this tune on my 2nd gen for a couple months now. It’s a great improvement!
    cemented, Boltripper and JustDSM[OP] like this.
  15. Mar 30, 2022 at 12:12 AM
    #35
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    One of those happy truck owner . :thumbsup: Too happy lol. Been driving truck more than my rav4 which changed this week because of gas prices . Beers won over gas :cheers: nah lol
  16. Mar 30, 2022 at 8:35 AM
    #36
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    How is the OTT compared to the KDMax?
    JonnyBb likes this.
  17. Mar 30, 2022 at 9:14 AM
    #37
    BortisYeltzen
    Barrett
    Salt Lake City, UT
  18. Mar 30, 2022 at 10:07 AM
    #38
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Thanks for chiming in Kurt! We’re glad you’re enjoying the your custom calibration on your 2nd gen. Super clean too!
    Haha I said the same thing driving my wife’s car to work but that only lasted a week. have been bringing the taco instead.
  19. Mar 30, 2022 at 4:55 PM
    #39
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Cool.
    Couple questions... one is subjective...
    First, will I have an issue with cruise control?
    Second, while I have OV2.0, and it is MUCH better than stock, I live in a hilly area, so, it still hunts a little... hell, cannot even hit 6th on the highway @80..
    What is the verdict from those that live in hilly/mountainous areas, and run other tunes?
    JustDSM[QUOTED][OP] likes this.
  20. Mar 30, 2022 at 4:58 PM
    #40
    JustDSM
    Justin
    Ogden, UT
    @BortisYeltzen - What is your input on the matter?
