Overland Torque Tune (OTT) by Overland Tailor
Discussion in 'Performance and Tuning' started by JustDSM, Mar 20, 2022.
  1. Jun 17, 2022 at 11:48 AM
    #381
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
  2. Jun 17, 2022 at 12:50 PM
    #382
    montanacruiser
    montanacruiser Well-Known Member
    2017 DCLB Off Road
    Any one close to Montana that does this tune?
  3. Jun 17, 2022 at 1:18 PM
    #383
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I'm interested in the OTT tune too. Any OTT tuners in Michigan?
  4. Jun 17, 2022 at 3:12 PM
    #384
    321TacticalSolutions
    321TacticalSolutions New Member
    I have a 2021 Tacoma & I live in FL where there are no hills what so ever. My issue is while in 6th gear, I get a surging while driving 70-80 mph. It's feels like your running out of gas, or there is a misfire. The RPM's are steady, so it's not an engine problem. I took into dealership for service at 5k mile service, they said truck drives as expected, & claimed they tested it against another Tacoma to verify. I'm sure this is a transmission update issue, I hope. Any thoughts?
    Will any tune get rid of the surging in 6th gear? OTT, or KDMAX
  5. Jun 17, 2022 at 4:27 PM
    #385
    shotgunbilly420
    Ott for the win
    JustDSM[OP] likes this.
  6. Jun 18, 2022 at 4:02 PM
    #386
    NickJacq23
    NickJacq23 Well-Known Member
  7. Jun 25, 2022 at 3:31 PM
    #387
    RCTuningFL
    RCTuningFL OTT Tuner - Florida/Puerto Rico/Carribean
    RC Tuning FL
    Melbourne / Brevard County, FL
    2020 Tacoma TRD Pro @rctuningflgarage
    OTT + Magnuson Supercharger - 5.29s etc etc.
    Looking good! :bananadance:
  8. Jun 25, 2022 at 6:31 PM
    #388
    NickJacq23
    where in Michigan?
  9. Jun 25, 2022 at 6:32 PM
    #389
    33yrsoftoys
    joel
    mid Michigan
    Midland or Saginaw. Central Michigan
  10. Jun 25, 2022 at 6:36 PM
    #390
    Anhnguyen310
    Anhnguyen310 Well-Known Member
    Maryland
    2019 Toyota Tacoma DCLB TRD Off-Road CEMENT
    Had that issue when I was running the kdmaxx stuff. Super annoying on the highway when you get the random Rev up. Issue was remedied after switching to OTT. Way smoother transitions from gear to gear
    Muajilong likes this.
  11. Jun 25, 2022 at 10:04 PM
    #391
    RCTuningFL
    RC Tuning FL
    I'm in Melbourne if you decide to go with OTT.
    LstMinutePanic and JustDSM[OP] like this.
  12. Jun 26, 2022 at 10:20 AM
    #392
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I’m in Lake Tahoe at the moment - and will be swinging by Sacramento in the next few days… is there anyone in the vicinity?
    - I don’t do the ‘gram and Facebook wanted some ID info for my account… so I nixed it!
    thanks!
    cemented likes this.
  13. Jun 26, 2022 at 12:10 PM
    #393
    dogodell
    dogodell Active Member
    2019 Tacoma SR
    Anybody in SC capable of helping me get set up with this tune?
    Weighing options and trying to figure out if it's worth the investment for vf for a one time tune or not.
  14. Jun 26, 2022 at 4:12 PM
    #394
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    You could hit up @InternationalHarvester in the Reno area. He also covers Sacramento.
    OZ TRD[QUOTED] likes this.
  15. Jun 26, 2022 at 4:13 PM
    #395
    cemented
    Cole
    Portland, OR
    I would try and reach out to @SearArtist who is in Charlotte and see if you can’t figure something out.
  16. Jun 26, 2022 at 4:23 PM
    #396
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    PM incoming
  17. Jun 26, 2022 at 6:23 PM
    #397
    LstMinutePanic
    LstMinutePanic Well-Known Member
    Colorado
    2018 Black Tacoma OR DCLB AT
    I recently upgraded from 265/75/16 SL Ultraterrains (31.6 inch, 40 lbs per tire, and great tire BTW) to some FJ rims and 255/80/17 E-rated Cooper S/T Maxx's (32.8 inch, 51 lbs per tire), and my mileage hardly took a hit. Drove over Independence Pass yesterday, and even with the heavier, larger tires, I still got over 22 MPGs whereas I was getting 23 on my smaller Ultraterrains.
    I chose OTT for the torque and performance. The MPGs have been an unexpected bonus.
  18. Jun 26, 2022 at 6:30 PM
    #398
    Langsta
    Langsta Active Member
    So far I went with OTT past few weeks now and I love it better torque and performance shifting alot better. for Mpg nothing changed for me
  19. Jun 27, 2022 at 9:33 AM
    #399
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    For those of us in CA, Has anyone been dinged on there Smog check that has OTT? Mt understanding is that they are looking for a Checksum number to match. This number is found using a binary comparison of the file on the car vs the stock file. I cant confirm this, but theoretically any change in that file would cause a different Hex code to be generated causing a failure.
    OZ TRD likes this.
  20. Jun 27, 2022 at 11:15 AM
    #400
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    You're referring to the CVN
