Overland Torque Tune (OTT) by Overland Tailor
Discussion in 'Performance and Tuning' started by JustDSM, Mar 20, 2022.
  1. Apr 21, 2022 at 7:33 PM
    #101
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    You have a sick truck. 2nd Gens get a ridiculous tune from the Overland Tailor Team. I’m honored to work with @JustDSM and @Boltripper to get you all tuned up. Enjoy it and reach out if you need any adjustments.
  2. Apr 21, 2022 at 7:41 PM
    #102
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I'm right there with you I'm going elk shed hunting next week and have some hefty passes to go over and I'm sure some snow wheeling to do to get to camp this will be the big test for me . I too am close to 35" tires and stock gears will be monitoring many parameters with obd fusion . Like to treat my truck nice but definitely make Toyota 3.5l do some work.
  3. Apr 21, 2022 at 7:46 PM
    #103
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    Look forward to seeing these results! As a side note, OBD Fusion's capture rate for datalogging is actually really slow. If you have access to techstream and want to capture more datapoints for actual datalogging, it's a better tool. However when you're driving and just want to put your phone on the dash, the Fusion is great!
    Some of the other tune creators used OBD Fusion to log data to build their tunes, but the Toyota ECU makes micro adjustments at a much faster rate than the Fusion was able to log, thus a lot of important data was missed when the other tunes were built. @JustDSM and @Boltripper did extensive datalogging to build the Overland tunes using Techstream/HPTuners and have really improved their product using the proper tools.
  4. Apr 21, 2022 at 8:13 PM
    #104
    shotgunbilly420
    I use my aftermarket hu to connect to my odb port . Yeah I've read many times how obd fusions capture isn't quite accurate. But to monitor tc and transmission temps along with coolant temps and I understand the front diff temps are possibly just calculations it works enough to make sure I'm keeping the truck safe . Especially when I'm pushing it hard .
  5. Apr 21, 2022 at 8:25 PM
    #105
    trdquoc
    "Q"
    Exactly… you’re using it to monitor which is perfect. Smart Taco owners like you are using the correct tools. I’ve noticed lower trans temperatures with OTT than the other tunes (names will not be mentioned)… I hope you see the same results! OTT was definitely focused on reliability and longevity as well and their product shows.
  6. Apr 21, 2022 at 8:27 PM
    #106
    lferrara
    lferrara Well-Known Member
    Luke
    Saint George, UT
    2014 DC TRD OR
    JD Fab Lower Pivots, JD Fab Slide Rack, JD Fab Inner Fenders, JD Fab UCA, DIrt King LCA, King Coilovers, 4.88 gears, 91 octane tune, etc...
    I agree! You can tell how much time they’ve put into it! They know exactly what they are doing.
    edit: you guys putting 85 in your truck. Stop it! :oops: the hp tuner guys are disappointed in you.
  7. Apr 23, 2022 at 6:57 AM
    #107
    oliver1539
    oliver1539 Well-Known Member
    Kentucky
    2022 Pro/2016 Off Road
    Great thread! Justin tuned my 2015 supercharged Pro and it runs amazing. Picking up a 22 today or early next week (whenever it arrives) and I plan on doing this mod first thing.
    Keep up the great work!
  8. Apr 23, 2022 at 11:23 PM
    #108
    AC-EAZy59
    AC-EAZy59 Member
    2020 Voodoo Blue Tacoma TRD Off-Road
    @trdquoc looking to finally tune my truck and I’m in the SoCal/OC area. You have any time Monday?…
  9. Apr 24, 2022 at 6:34 AM
    #109
    trdquoc
    "Q"
    I’ll make time, I’ll send you a PM
  10. Apr 24, 2022 at 7:23 AM
    #110
    shotgunbilly420
    vf tuner website is all new this morning ? Wondering if the vf tuner software is getting upgraded soon. The new looking site looks killer.
    JustDSM[OP] likes this.
  11. Apr 24, 2022 at 2:24 PM
    #111
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    Just flashed OTT 7.0 I flashed medium throttle and damn a little much for me so I just flashed lite peddle. I will report back after a few miles and the learning process. Very easy to flash myself with the VF tuner.
  12. Apr 24, 2022 at 2:50 PM
    #112
    oldtoyman
    Kevin
    North of Seattle
    Oh snap flashed the lite throttle and WOW it’s perfect for me. Then hit ETC button and I get mild throttle. Very cool.
    trdquoc and JustDSM[OP] like this.
  13. Apr 24, 2022 at 3:43 PM
    #113
    oliver1539
    Kentucky
    So, if I purchased the VFTuner tuning kit, I could then purchase a vin locked tune and flash myself? How much are the OTT 7.0 tunes? Sounds easier than driving 4 hours “each way” to the closest turner.
    Also, if I need something changed, I could do it myself, bigger tires or different gears?
    venezian, GilbertOz and JustDSM[OP] like this.
  14. Apr 24, 2022 at 3:51 PM
    #114
    JustDSM
    JustDSM [OP] Oderint Dum Metuant
    Justin
    Ogden, UT
    Correct, you (or anyone else) that has VFTuner, we can supply VIN locked tune packs for your setup which include the different throttle offerings we have standard. In the future if you change gears/tires or want something custom to meet your needs, we're more than happy to work with you to get what you're looking for.
    VIN Locked Tune Packs are $300 (as of 4/24/22) for new clients. Those already tuned (by another tuner) should contact John at info@overlandtailor.com to discuss our discounted rates.
  15. Apr 24, 2022 at 3:54 PM
    #115
    JustDSM
    Justin
    Ogden, UT
    Glad you found something you liked. We tried hard to nail down settings that fit most folks needs. Some like it hot, some prefer it mild. If something in-between our offerings is desired, be sure to let us know and we can work something up for you needs.
    oldtoyman[QUOTED] likes this.
  16. Apr 24, 2022 at 4:04 PM
    #116
    JustDSM
    Justin
    Ogden, UT
    It is looking pretty good! 1.6 should be dropping early next week according to Mat. Will be interesting to see what's new!
    Always taking care of folks! Love it!
    Thanks so much for your continued support! I'm certain you'll find the 3rd Gen work we've done just as impressive. We've worked hard and thank you for trusting us with your vehicles.
  17. Apr 24, 2022 at 5:21 PM
    #117
    oliver1539
    Kentucky
    Nice! Sounds like the way to go in my situation. I’m always adding modifications, so it would make more sense to do myself.
    Thanks
    JustDSM[QUOTED][OP] likes this.
  18. Apr 24, 2022 at 5:24 PM
    #118
    oliver1539
    Kentucky
    Absolutely! Thanks for great work and getting these trucks to run like they should from the factory.
  19. Apr 24, 2022 at 5:36 PM
    #119
    oldtoyman
    Kevin
    North of Seattle
    I am probably going to lose sleep tonight thinking about how much fun the drive to work in the morning will be.
    cemented, JustDSM[OP] and oliver1539 like this.
  20. Apr 25, 2022 at 8:06 PM
    #120
    oldtoyman
    Kevin
    North of Seattle
    I think with 4:88 gears this truck would just be about perfect along with the OTT tune.
