Overland Torque Tune (OTT) by Overland Tailor
Discussion in 'Performance and Tuning' started by JustDSM, Mar 20, 2022.
  1. Oct 17, 2023 at 2:53 PM
    #1281
    YatYas1833
    YatYas1833 Well-Known Member
    22 WHITE TRD OFFROAD 4x4 DCSB
    King 2.5’s with adjusters from accutune front and rear, 88 rotors rear add a leaf, Camburg X-joint UCA’s, Factory style trd pro 16” wheels with 0 offset, 285/75/16 KO2’s, pro grille, Front bumper viper cut, trd front skid plate, full RCI under skid plates, Cali raised trail sliders, exhaust cut dump, KDMax 10.0 tune
    Does anyone know what the added HP and torque is over stock with this tune?
  2. Oct 17, 2023 at 2:59 PM
    #1282
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    3GTCMLMTD and JustDSM[OP] like this.
  3. Oct 19, 2023 at 5:59 AM
    #1283
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    Is there any plan to/is the tune actively being refined? The reason I ask is the jumpiness/jolting behavior when accelerating from a stop and also when slowing down and then speeding back up. My truck during these times jolts/lurches forwards and I was wondering what the origin of this is and if there are plans to tune this out. 2017 3.5 with OTT on lite throttle.
    disk_55FL likes this.
  4. Oct 19, 2023 at 7:06 AM
    #1284
    JustDSM
    JustDSM [OP] Oderint Dum Metuant
    Justin
    Ogden, UT
    Out of curiosity when were you originally tuned?
    Make contact with your tuner or reach out to indo@overlandtailor.com if you bought files direct from us. We’ll confirm you are on the latest (which did address the areas of concern), and/or make a custom throttle variant for you to address your specific concern.
    TRDRed likes this.
  5. Oct 19, 2023 at 7:20 AM
    #1285
    gthupman
    Greg
    Maybe April or may of this year ? Updates since then?
    JustDSM[QUOTED][OP] likes this.
  6. Oct 19, 2023 at 7:27 AM
    #1286
    JustDSM
    Justin
    Ogden, UT
    No update to the tune. However, we did add some additional throttle settings in June that I think will suit you much better.
    As mentioned, reach out and we’ll get you taken care of. Be that an alternate throttle setting or something custom for you.
    PowerKord and TRDRed like this.
  7. Oct 19, 2023 at 7:47 AM
    #1287
    gthupman
    Greg
    Awesome! Will do
    TRDRed likes this.
  8. Oct 19, 2023 at 2:42 PM
    #1288
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    What throttle levels did you go with? Medium used to give me the same sort of problems with jolts/lurches at low speeds. I ended up checking my ATF level and found I was 9-10 oz low. When I topped it off, everything smoothed out. I still get some occasional jerkiness but no where near before
    cfarley, PowerKord, dave82at and 2 others like this.
  9. Oct 19, 2023 at 6:10 PM
    #1289
    gthupman
    Greg
    Lite with medium on the ECT button
  10. Oct 20, 2023 at 6:27 AM
    #1290
    AZPhys13
    I have the same, is it jerky on both settings? Lite has always been smooth but until topping the ATF I avoided medium like the plague unless I was already up to highway speed
    PowerKord likes this.
  11. Oct 21, 2023 at 1:13 PM
    #1291
    gthupman
    Greg
    Yes jerky on both but more pronounced on medium. I notice it most in parking lots and on my commute I go over several rail road tracks and when I come down the backside of the tracks going downhill the revs raise trying to slow the truck down and then as I get back on the throttle that’s when it jerks most
    TRDRed likes this.
  12. Oct 22, 2023 at 11:35 AM
    #1292
    gthupman
    Greg
    Got the updated tune flashed and it’s significantly improved. Stuck with same lite/medium. Jerkiness nearly gone
  13. Oct 22, 2023 at 3:27 PM
    #1293
    Mickey65
    Mickey65 Well-Known Member
    Carroll, Maryland
    2023 Solar Octane TRD Pro
    Response is lees jumpy if you use your toes lower on the pedal instead of the natural use of the ball of your foot on the middle of the pedal. Learned that with an old GMC 10 ton dump truck. If you used the ball of your foot on the brake pedal the air brakes would put you into the windshield. When you used your toes on the pedal it stopped smooth as silk.
    TRDRed likes this.
  14. Oct 22, 2023 at 6:41 PM
    #1294
    coachwhip99
    coachwhip99 Well-Known Member
    Samuel
    Auburn,AL
    2018 Tacoma 4x4 Sport Quicksand
    Seat covers, Tool box,BFG KM3s
    How do you get your truck tuned and how much is it?
    JustDSM[OP] likes this.
  15. Oct 22, 2023 at 6:54 PM
    #1295
    JustDSM
    Justin
    Ogden, UT
  16. Oct 23, 2023 at 7:09 PM
    #1296
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    Got the OTT tune today. I was looking into tunes recently and came across the OTT as the likely best option for what I wanted. I was browsing the website to see where the closest tuner was, and it just so happens that Marty from ATO Tuning LLC is only an hour away from me. I contacted him yesterday and I got tuned today. I've been running a Pedal Commander for the past two years on Sport mode so I was already accustomed to throttle sensitivity. Marty was awesome and made sure I had exactly what I needed and wanted. He was riding around with me logging the file while texting to @JustDSM to get everything dialed in. I started out with the mild flash however it wasn't quite enough for me. The medium is perfect and is very comparable to the Sport Mode with the PC which is what I was used to. That's where the similarities end. The hour drive home was amazing. Third Gens are notorious for gear hunting but 2nd Gens are pretty bad too. That was eliminated. The RPMs were steady and didn't bounce around, particularly when accelerating on the fly. The power increase was very noticeable, and Marty added the K&N CAI to the mapping profile for better utilization, and possibly even more horsepower. I'll be honest, the "medium" profile on a 4.0 almost feels like a small block V8. My truck felt like it always had power at the ready and I actually had to pay attention to my speed on the way home. Like so many others have said, it feels like I got a new engine and transmission and it's fun to drive instead of an aggravation. As far as the Pedal Commander goes, I'll be packaging it up and selling it soon. It definitely has its place if all you're looking for is throttle response. A tune however will redo your shift points and patterns, air/fuel ratio, actual increase in HP and torque, as well as other refinements to the drivability of the truck. This is my first ever tune and I'm extremely happy. Overland Torque Tune is doing everything right. Two thumbs up fellas. :thumbsup::thumbsup:
  17. Oct 23, 2023 at 8:40 PM
    #1297
    JustDSM
    Justin
    Ogden, UT
    Appreciate your business and for trusting OTT with your tuning needs. Your detailed review is also very much appreciated. 2G’s are a personal passion project for me so it makes me very happy to hear that work brings you more enjoyment from your truck.
  18. Oct 24, 2023 at 5:46 AM
    #1298
    Tacoma13_NC
    Thanks again Justin. Between my own experience as well as the countless videos that I've watched online, everyone that works for or is contracted to tune this system is very professional, polite, and knowledgeable. It makes the experience fun and enjoyable, especially for people who may have anxiety in remapping their vehicle's ECU. Customer service is everything and you guys nail it. My truck is like a brand-new truck, and maybe it's my imagination or placebo but I think it even idles smoother now too. Thanks again!
  19. Nov 8, 2023 at 4:12 PM
    #1299
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    I'm trying to get a feel for what sort of improvement I would expect with tuning. About the only thing I can compare it to is when it's in cold start and I'm going through my first shift or three; while I never get on it until fully warmed up, whatever enrichment, timing, and/or throttle response is going on there I like quite a bit - when I leave work, I pull out on to a busy road so I can say first hand it seems to pull harder at low RPM ("almost like it should to begin with"). It's a stretch, but can anyone else compare/contrast to this as well?
  20. Nov 8, 2023 at 5:04 PM
    #1300
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    Have you seen this? I’m guessing yes, but if not, you may get some info on how the tune feels from her reaction.
    FishingInSand, TRDRed and TacoTime55 like this.
