Overland Torque Tune (OTT) by Overland Tailor
Discussion in 'Performance and Tuning' started by JustDSM, Mar 20, 2022.
  1. Apr 25, 2022 at 8:08 PM
    #121
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    Got used to lite throttle pretty quick. Hit the etc button and it was better so when I got home I flashed the mild / medium etc tune. Tomorrow will even be more fun.
    LstMinutePanic and JustDSM[OP] like this.
  2. Apr 25, 2022 at 8:15 PM
    #122
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Funny, that’s how OTT’s @Boltripper has his own truck set up. And @trdquoc
  3. Apr 26, 2022 at 1:40 PM
    #123
    oldtoyman
    Kevin
    North of Seattle
    You guys have any vinyl stickers that say OTT tuned?
    JustDSM[OP] likes this.
  4. Apr 26, 2022 at 1:45 PM
    #124
    Boltripper
    Boltripper Well-Known Member
    Hoover, Alabama
    2020 TRD Off Road Access Cab A/T in MGM
    Khaya Camper with Custom Mods - BP-51's, 4.88's, 33's', Dissent Offroad Front and Rear with Bud Built on the sides...
    We have them and they are the same as our avatar.
    john
  5. Apr 26, 2022 at 2:15 PM
    #125
    oldtoyman
    Kevin
    North of Seattle
    Hit me up on how to get one. Thanks
  6. Apr 26, 2022 at 4:15 PM
    #126
    Tacoma_Doc
    Tacoma_Doc New Member
    2022 Tacoma DC TRD OR MGM
    You won't regret it! My 22 only had 800 miles on the odometer and was 2 weeks old.
  7. Apr 26, 2022 at 4:23 PM
    #127
    VictorFox78
    VictorFox78 Well-Known Member
    Michigan [Yooper]
    2022 DCSB LR OR
    lol, I just hit over 600 miles and can't wait!
    trdquoc likes this.
  8. Apr 26, 2022 at 7:47 PM
    #128
    lferrara
    lferrara Well-Known Member
    Luke
    Saint George, UT
    2014 DC TRD OR
    JD Fab Lower Pivots, JD Fab Slide Rack, JD Fab Inner Fenders, JD Fab UCA, DIrt King LCA, King Coilovers, 4.88 gears, 91 octane tune, etc...
    Something I have noticed within the last 4-5 days is that the engine seems to sound better and my idling seems smoother. Might just be in my head but the engine definitely seems happier. Wish there was one for my wife’s 98 4 runner :)
  9. Apr 26, 2022 at 11:10 PM
    #129
    HRC4
    HRC4 Member
    2020 Tacoma TRD Pro MT
    URD short shift kit 265 75 16 Goodyear Duratrac's
    I can say that I agree with most of this statement, but I don't fully agree with it all. 35's are for sure adding a lot of rotating mass and reducing the overall reduction ratio from the crankshaft to the ground.
    By adding a lower reduction set of gears will return the losses from the tire diameter increase from the rear pinion bearing forward, and return to a more factory stress level from the rear driveshaft forward. But it certainly isn't putting less stress on the differential. the axle shafts, carrier bearings ring gear and front pinion bearing are all seeing the same amount of load as having a stock gear ratio, the difference is you end up dividing the "work" into the reduced pinion gear teeth, and bearing rpm. So really you can expect an accelerated amount of wear on those pinion teeth, and increase in wear on pinion bearings over a stock truck. The work is still the same, you are just trading heavy load into higher wear over a given time.
    Theoretically you can only help reduce some of the differential stresses, by increasing the ring gear diameter, which would give a longer moment arm from the center of the axle shaft to the center point of contact from the pinion. it would provide a better leverage ratio with the same amount of input torque coming from the driveshaft.
  10. Apr 27, 2022 at 7:50 AM
    #130
    21TacoTRDOR
    21TacoTRDOR New Member
    2021 Black Tacoma TRD OR
    Leer 100XR, Fox 2.0 F/B, Deaver custom leaf springs
    Anyone know if there is a tuner in or around Spokane, WA? The closest I am seeing is the Seattle area. I reached out to PNW tuning via their website but haven't heard anything back yet. I am sure they are just busy. Any help would be appreciated. Thanks.
    JustDSM[OP] and PNWTacoma like this.
  11. Apr 27, 2022 at 7:55 AM
    #131
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    This is why I still have my stock 3.90 ratio. Beefy . I'm considering doing a dual case
    PNWTacoma likes this.
  12. Apr 27, 2022 at 8:55 AM
    #132
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    There is both @PNWTacoma and myself representing the northwest and we’re both based out of Portland but travel all over. DM me if you need any help.
  13. Apr 27, 2022 at 12:10 PM
    #133
    shotgunbilly420
    I'm possibly thinking about joing your group so we can give more options for customers . I have vf tuner just not the pro license
  14. Apr 27, 2022 at 12:11 PM
    #134
    shotgunbilly420
    I'm 30min inland of ocean shores
  15. Apr 27, 2022 at 11:59 PM
    #135
    HRC4
    HRC4 Member
    You can use a rear center section, and front clamshell from a manual trans truck, and find then in a wreckers to gain a 4.30 gear ratio cheaper than buying and installing a set at a shop. Just make sure its from a manual off road or Pro, so you get the 8.9" rear ring gear.. the sport trucks have a smaller ring diameter.
  16. Apr 28, 2022 at 2:38 AM
    #136
    AbdullaJaafari
    AbdullaJaafari Dubai Taco
    Abdulla
    Dubai, UAE
    2018 Tacoma TRD Off-road
    One major thing the Tacoma community in the UAE has been looking for is to bypass the rev-limit throttle cut.
    Our only offroading consists of dune bashing in the desert so you need consistent power without any gear changes or drop in power and the Tacoma fails at that.
    Has there been a solution for that with OTT?
  17. Apr 28, 2022 at 3:30 AM
    #137
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I believe you were the one who posted on the vF tuner forums a while back as well? Haven't seen this feature become available yet, and I can't recall if it'll be available this weekend.
  18. Apr 28, 2022 at 3:42 AM
    #138
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I had this combo in my old truck with 35’s. It wasn’t really a major difference. Luckily it only cost me $600 in labor to swap out diffs from my buddys MT truck.
    I would just spend the money and go 5.29’s if I were doing it again
    e46_ema likes this.
  19. Apr 28, 2022 at 4:16 AM
    #139
    shotgunbilly420
    Interesting
  20. Apr 28, 2022 at 5:43 AM
    #140
    oliver1539
    oliver1539 Well-Known Member
    Kentucky
    2022 Pro/2016 Off Road
    Justin, sent you a pm in regards to a tune.
