Overland Torque Tune (OTT) by Overland Tailor
Discussion in 'Performance and Tuning' started by JustDSM, Mar 20, 2022.
  1. May 18, 2024 at 12:56 PM
    #1581
    PiñonTaco
    PiñonTaco Well-Known Member
    2020 TRD OR DCLB
    Recently had my OTT tune reflashed from version 7 to the version 9 Emissions compliant tune. Just drove the truck 1250 miles from SF Bay Area to north of Santa Fe, New Mexico. Lots and lots of elevation changes. Generally kept it on cruise at 80mph. Overall mileage for the entire trip was 20.6. Was running with fairly full load and cab-height Snugtop Rebel.
    Checked via hand calculation at every fill-up, and those numbers were typically .2-.3 mpg higher than what the Tacoma displayed, so the overall trip mileage may well be higher than 20.6.
    The tune performed great, noticeable improvement from OTT-7. I’m very pleased.
    TacoTime55 and JustDSM[OP] like this.
  2. May 18, 2024 at 1:38 PM
    #1582
    JustDSM
    JustDSM [OP] Oderint Dum Metuant
    Justin
    Ogden, UT
    Thank you for the feedback sir! Glad to hear you’re enjoying the updated file.
    Well be in touch with the CARB details!
  3. May 22, 2024 at 7:41 AM
    #1583
    ncflyer
    ncflyer Well-Known Member
    Did a trip with gradual up hill and had it shift from 5th to 4th three times in quick succession. Not a steep grade and no one in front of me with cruise set for 70. This has happened intermittently in the past as well. Can't find program information but believe it was the "2nd level response" from a basic from what I recall from the initial install. Thanks for any information suggestions.
    3rd gen 2022 double cab with a few lighter wt mods. (32" or so tires, camper topper, winch with Aluminum bumper, lift) if that matters.
    Also considering regear to 4.88 and wondering what the "regear tune" does for that sizing and the newest tune version. Would likely go with base level setting for acceleration. Any info. on how that would work together...OTT?
    Thanks for any info.
  4. May 22, 2024 at 8:32 AM
    #1584
    JustDSM
    Justin
    Ogden, UT
    Would you clarify if you were using radar cruise or "traditional" cruise mode when the above occurred? And I also assume this was with the OE calibration?
    Our gear set specific files have a revised shift schedule matched to the specific differential ratio selected (be that 4.88 or 5.29).
    A regear along with the tune really does help the double overdrive 3G Auto behavior in the hills. The increased mechanical advantage afforded by the gear change helps put more torque into the rear wheel for a given vehicle speed. The tune file optimizes the shift schedule for the change, and enhances it further with a modest increase in torque at just about all RPM/Loads while giving you various options to address the pedal/throttle ratio. Together they work as a package, though individually, they are both worlds of improvement over 'stock.'
    3GTCMLMTD likes this.
  5. May 22, 2024 at 8:33 AM
    #1585
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Radar/adaptive cruise control essentially functions as stock for all 3rd Gen Tacoma tunes available. If you’re expecting cruise control to behave wildly different with the tune vs stock, that is not the case.
  6. May 24, 2024 at 11:12 AM
    #1586
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    I updated my tune last year May. How do I know when there's an updated version released?
    JustDSM[OP] likes this.
  7. May 24, 2024 at 11:15 AM
    #1587
    JustDSM
    Justin
    Ogden, UT
    Send us an email to info@overlandtailor.com or reach out to the tune who applied your flash and we'll confirm for you.
    Otherwise, feel free to post the date you were tuned and what vehicle you have and I can let you know!
  8. May 24, 2024 at 5:29 PM
    #1588
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Any R&D on tuning the 2.4L turbo @JustDSM ?
  9. May 24, 2024 at 6:51 PM
    #1589
    JustDSM
    Justin
    Ogden, UT
    Waiting on our flashing cable. We'll be hitting it hard here shortly. We'll be collecting lots of data and making a post regarding 4G development. It should be pretty tech-heavy with lots of pressure and temperature differential data to help the community and allow us to assess better where the truck is in terms of OE state of tune versus how much headroom is left on the table while still retaining margins of safety for using the truck as a "truck." But were as excited as any and really interested in the potential of the new Toyota platforms..
    Gmak621[QUOTED] likes this.
  10. May 24, 2024 at 7:01 PM
    #1590
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Love to hear it! And anxiously waiting
    JustDSM[QUOTED][OP] likes this.
  11. May 24, 2024 at 7:20 PM
    #1591
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Super excited to see if the detuned SR can be "unlocked" for the power it was designed to have.
  12. May 24, 2024 at 7:38 PM
    #1592
    YatYas1833
    YatYas1833 Well-Known Member
    22 WHITE TRD OFFROAD 4x4 DCSB
    King 2.5’s with adjusters from accutune front and rear, 88 rotors rear add a leaf, Camburg X-joint UCA’s, Factory style trd pro 16” wheels with 0 offset, 285/75/16 KO2’s, pro grille, Front bumper viper cut, trd front skid plate, full RCI under skid plates, Cali raised trail sliders, exhaust cut dump, KDMax 10.0 tune
    So I’ve waited a while to do a review of this tune but I can honestly say, by far this is the best thing I’ve ever done to my truck. I had the latest KD Max tune and this tune completely BLOWS it out of the water. Sooooo much smoother on the freeway and shifts like a normal vehicle would while still maintaining speed up inclines. I have the mild-medium setting and it is perfect. For reference, I have a 3 inch lift, 33” KO2’s, steel skid plates and rock sliders. No change in mpg’s over the KD Max though which isn’t a big deal.
  13. May 24, 2024 at 7:45 PM
    #1593
    venezian
    Los Angeles
    2022 7545E
    I tuned 5/3 or 5/4 2023. 2022 TRD OR MT
    let me know if you need more details.
  14. May 24, 2024 at 7:55 PM
    #1594
    JustDSM
    Justin
    Ogden, UT
    That's all that's needed. We do have the SEMA-CE (CARB-EO Pending) calibration that is available.
    From a driveability/performance standpoint it's a very mild update. However, with you being in CA, the eventual CARB-EO will be worth it for you to update for legality/SMOG compliance. Send your tuner a message and he'll get back with you otherwise send me a PM and I'll have him reach out to you.
    Justin
    bulalo and venezian[QUOTED] like this.
  15. May 24, 2024 at 7:56 PM
    #1595
    JustDSM
    Justin
    Ogden, UT
    You can be assured we'll evaluate that and likely offer that as a "low cost" option for folks.
    JasonLee[QUOTED] likes this.
  16. May 26, 2024 at 7:47 PM
    #1596
    guest_707
    guest_707 Well-Known Member
    Does yours ever shift into 6th gear on the freeway? I haven't gotten a tune on mine yet but it almost never goes into 6th unless I'm going 80+ or something insane like that. Currently on 255/85r16s but even with stock tire size, it was always cruising in 5th on the freeway anywhere from 2100 to 2500 rpm between 65-75 mph on flat ground.
  17. May 30, 2024 at 1:55 PM
    #1597
    JustDSM
    Justin
    Ogden, UT
    Exciting news! We're thrilled to announce that Overland Tailor Tuning (OTT) is NOW offering comprehensive calibration support for KLine Toyota Platforms. This means that our services now cover full calibration support, including throttle and transmission tuning, for KLine 4.0L and 4.7L Toyota platforms.
    Initial support includes calibrations for the following vehicles:
    • 4.0L 4Runner (2003/2004)
    • 4.7L 4Runner (2003/2004)
    • 4.7L GX470 (2003/2004)
    • 4.7L Tundra (2004)
    • 4.7L Sequoia (2003/2004)
    • 4.7L Land Cruiser (2004)
    But that's not all! We're also gearing up to support 2002-2004 3.4L 5VZ platforms, with additional vehicles on the horizon.
    Don't miss out on unlocking the full potential of your Toyota platform. Contact your OTT retailer to schedule your KLine calibration.
    Please note: KLine files will only be available through OTT authorized retailers. Currently, OTT will not supply "tune packs" to DIY clients. However, if you reside in an unserviced area, OTT can supply "pre-tuned" ECUs for you with an exchange program or outright purchase. Please contact OTT directly for a pre-tuned ECU purchase. Pricing starts at $450.00USD + S/H for pre-tuned ECU's. (Final price subject core ECU cost)
  18. May 30, 2024 at 2:41 PM
    #1598
    JasonLee
    15 TRD OffRoad
    OMG. Yet again, deliver on promises that were from some [REDACTED]. Makes me wish I had kept my 1st gen now!!
    thanks for the hard work!
  19. May 31, 2024 at 1:54 PM
    #1599
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    This is awesome! I see a lack of 05/06 Tundras, and don't know other models well enough to speak to those... But is this because of VVTI? Is there a possibility for 05/06 Tundra tunes in the future?
  20. May 31, 2024 at 1:58 PM
    #1600
    JustDSM
    Justin
    Ogden, UT
    We have files available for the 2005/2006 CAN based Tundra's right now. Full engine/transmission calibration. Have a 2006 going on the dyno next week. :)
    We've also got full engine/transmission calibrations available for 2007-2009 4.7L Tundras, available soon from our retailers.
