Overland Torque Tune (OTT) by Overland Tailor
Discussion in 'Performance and Tuning' started by JustDSM, Mar 20, 2022.
  1. Sep 23, 2024 at 3:05 PM
    #1821
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    I emailed Matt at VF a bunch if you want to send him an email as well may help get the tools we need to squeeze a few more horses. Considering it makes next to no power any increase is felt lol.
    paulisinataco[QUOTED] likes this.
  2. Sep 24, 2024 at 4:23 AM
    #1822
    SHADOWDRIFTER19
    SHADOWDRIFTER19 Well-Known Member
    RH
    2019 2.7L TSS OR
    Putting in my LCE header today, would you recommend a re-tune?
    Torspd likes this.
  3. Sep 24, 2024 at 8:16 AM
    #1823
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    VF Tune is different from OTT Tunes, they have seperate section in Performance forums.
  4. Sep 24, 2024 at 12:56 PM
    #1824
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    I am not talking about a different tune, vf tuner is who makes the tuning software
  5. Sep 24, 2024 at 1:24 PM
    #1825
    JustDSM
    JustDSM [OP] Oderint Dum Metuant
    Justin
    Ogden, UT
    You will not need a retune unless you'd like to change your setting.
    The improved scavenging and additional air mass the engine moves through it, will be accounted for with the mass airflow sensor. The additional airflow and subsequent load will operate in their respective regions of the mapping. Should we have EROM file avail., I might suggest a tweak or two..
  6. Sep 27, 2024 at 9:34 AM
    #1826
    BlueRibbonRM
    BlueRibbonRM Well-Known Member
    2023 TRD OR
    Took my long trip today which is a mix of normal roads, highways, and mountain back roads. I can say the drive this year with the OTT tune was way smoother than my trip here last year when my only modification was the Anderson intake manifold spacer. This definitely is exactly what the truck has been missing all this time and it is definitely worth it for all the 6MT drivers. The one part of the trip is a good mile climb up a steep hill, had no issue climbing that in 4th gear around 2500-2700rpm and with minimal throttle input. Last year I needed to be in 3rd gear well above 3k and a lot more input. I realize the throttle sensitivity is increased with the mild setting, but even with that in mind it was still obvious how much of a difference was needed. I finally feel like the truck drives as best as possible for what it has to work with. Wish I had done this sooner!
  7. Oct 3, 2024 at 9:00 PM
    #1827
    JustDSM
    Justin
    Ogden, UT
    The latest:
  8. Oct 4, 2024 at 5:24 AM
    #1828
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    I got the same email update yesterday fingers crossed it comes to life, did not know there was anything still for the 3.5 to be worked on.
  9. Oct 4, 2024 at 6:59 PM
    #1829
    paulisinataco
    paulisinataco Well-Known Member
    Utah
    2022 sr access cab 4x4
    But we were here first :D
    Dfpftw likes this.
  10. Oct 17, 2024 at 6:33 PM
    #1830
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    Quick question and I apologize if this has been asked before, but will a reflash work to increase the alternator charging output? I recently bought an AGM battery and need to boost my charging capability for it. Currently sitting around 13.5 according to my scangauge. There is a voltage booster with fuse that I can buy to remedy this also, but I wanted to check here first. Thanks.
  11. Oct 17, 2024 at 6:54 PM
    #1831
    JustDSM
    Justin
    Ogden, UT
    Only on 3rd Gen (2.7 & 3.5) Tacoma and 4th Gen Tacoma.
    Tacoma13_NC[QUOTED] likes this.
  12. Oct 17, 2024 at 7:06 PM
    #1832
    Tacoma13_NC
    Thanks for the clarification. :thumbsup:
    JustDSM[QUOTED][OP] likes this.
  13. Oct 18, 2024 at 9:39 AM
    #1833
    grambo911
    grambo911 Well-Known Member
    SF Bay Area, Kommiefornya
    2023 Lunar Rock Trail Edition
    AWE Exhaust, KARTBOY exhaust hangers, custom 1/0 exhaust grounding, lots of Titanium hardware from my old builds, silly JDM bits from my old Subaru builds, Uniden Bearcat Off Road CB, Firestik 2 w/custom CF mount, custom KARTBOY plate frame with Rigid Industries Spot on ball head mount, Yakima Mega Warrior w/custom CF cross brace. ARP extended studs (not installed yet), Optima Red Top, Siless Insulation in cab. Diode Dynamics LEDs throughout... More titanium fasteners. K&N intake snorkus delete. Greddy hose clamps throughout. DBA 4000XS Brake Rotors. TRD PRO fogs. Dakine Tail Gate Pad. Body Armor Sliders. Icon Stage 4 Lift. Eibach 1" Lift Blocks. Overland Taylor Tune. Rough Country Spare Tire Bed Mount. 67 Designs stuff on the dash. Uniden Radar Detector Hardwired. Spod Lighting Controls. RC Black Series Bumper Lamps RC Black Series Grill Lamp. Body Armor Stealth Front Bumper. Extended Brake Lines. Greddy Shift Knob. More to come of course.
    I've been researching tuning my truck and am really happy with what I have read and seen regarding the OTT tune. Hoping to book a date near SF or Sac sooner than later. Bravo on all of the effort you have put into your offerings. Coming from the Subaru community, an OTS Cobb tune was an absolute must for a stock STI. I could not believe how poorly they ran from the factory. (Garbage CA91 gas is not good for stock EJ's. Made em' run lean...) Anyway, I hope to do some business soon and am very glad to have found this thread. :thumbsup:
    Pics because the forums are no fun without pics...haha
  14. Oct 18, 2024 at 2:29 PM
    #1834
    SHADOWDRIFTER19
    RH
    2019 2.7L TSS OR
    How would one go about getting another OTT sticker?
    JustDSM[OP] likes this.
  15. Oct 18, 2024 at 2:30 PM
    #1835
    JustDSM
    Justin
    Ogden, UT
    Send me a PM with your address, I'll get you taken care of.
    Here very soon we'll have a completely new website where you can purchase OTT merch direct.
    3GTCMLMTD, ERod27 and trickynicky17 like this.
  16. Oct 18, 2024 at 3:05 PM
    #1836
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    For second gens. There’s a resistor that can up the voltage. Don’t remember where to get it.
  17. Oct 18, 2024 at 3:53 PM
    #1837
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Tacoma13_NC and Tacodog[QUOTED] like this.
  18. Oct 18, 2024 at 10:38 PM
    #1838
    Bill_C
    Bill_C Member
    Bill
    Central Valley, CA
    2022 White TRD Offroad
    This may not be the place for this, so I apologize in advance, but where are ya'll putting your CARB stickers? Inside driver door, under hood, no where because the smog station can't tell it's tuned anyway?
  19. Oct 18, 2024 at 10:45 PM
    #1839
    JustDSM
    Justin
    Ogden, UT
    It should be placed under the factory emissions sticker on the hood.
  20. Oct 18, 2024 at 11:12 PM
    #1840
    Bill_C
    Bill_C Member
    Bill
    Central Valley, CA
    Cool, thanks for the quick response
