Override fog light programming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlexHermsen, Jul 7, 2015.
  1. Jul 7, 2015 at 12:13 AM
    AlexHermsen
    AlexHermsen [OP] Active Member
    Alex
    Oceanside, CA
    2015 4.0l 4x4 Sport
    CAI, Flowmaster Super 44, HID's, Leveling kit, Camper shell
    Got a 2015 TRD sport model and noticed that the fog lights can only be activated when low beam headlights are on. Does anyone know how to override this so I can be able to use the fogs in any setting?
  2. Jul 7, 2015 at 12:16 AM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    There are a lot of threads about how to get them to come on anytime just search "fog light anytime" however it requires some modding and there is no way to override it in any type of programming
  3. Jul 7, 2015 at 12:17 AM
    AlexHermsen
    Alex
    Oceanside, CA
    2015 4.0l 4x4 Sport
    so basically the only option is to have them on all the time... even when it's in day time setting?
  4. Jul 7, 2015 at 12:19 AM
    Josh828
    Josh
    Avery NC
  5. Jul 7, 2015 at 12:29 AM
    tubesock
    tubesock Well-Known Member
  6. Jul 7, 2015 at 1:45 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    There is a reason they are set up like that. You do not drive with high beams in the fog and these are fog lights. In some states it is illegal to drive with them on when there is no fog or when other vehicles are approaching.
    JD_P likes this.
  7. Jul 7, 2015 at 8:22 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    The solution to your problem is addressed simply in the link in my sig. Takes about 5min total and will make it so your fogs remain in when you activate your brights. No other changes are made to behavior otherwise.
  8. Jul 8, 2015 at 10:03 PM
    AlexHermsen
    Alex
    Oceanside, CA
    2015 4.0l 4x4 Sport
    so I checked it out and was super stoked until you said the high and low beams will both be on... unfortunately thats not what Im going for since I have high beam halogens and low beam HIDs the reason is because I like my HIDs for all around driving but switch to halogens if Im going long distances on highways and dont want fuckers flashing me every 5 minutes because they think I have my brights on. that being said I want to be able to use my fogs so i can still maximize my visibility. anyway, hopefully someone has a solution...
  9. Jul 8, 2015 at 10:18 PM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    Go here. This is the best way IMHO.
  10. Jul 22, 2015 at 10:47 AM
    MotoMoose68
    MotoMoose68 Well-Known Member
    Ed
    Southwestern Colorado
    2014 Tacoma TRD Sport
    Strut Spacer and block lift, w/33" tires on custom wheels.
    Of course, anyone considering a mod should know how it applies to local laws. Where I am, it's not illegal to run fog lights and many people run them anytime they have their low beams on. Aside from helping in rain and snow, fog lights generally throw a low wide light pattern. This helps with visibility along the side of the road. To me, it only makes sense to include this low wide lighting with high beams, as it helps fill the covered area going from low to high beams. I've always noticed how much better you can see, when both low and high are on at the same time. This can be seen on many vehicles, while holding the high beam flash feature.
    Anyone driving is no more at fault, for leaving their brights on, by having fog lights on at the same time. Fog lights don't blind people, due to the low wide pattern.
