OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Sep 4, 2018 at 9:04 PM
    #181
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I am not familiar with the specifics of the Ecoboost or turbocharged cars in general. But I would imagine that a Factory turbo system has an ECU controlled waste-gate, and of course a knock-sensor+ECU controlled timing. They can change the boost and timing when different fuels are used.
    OV tune is a sophisticated tuning operation, but I have doubts about whether they can program the Stock Tacoma ECU to control a waste-gate. I don't know if that is even possible.
    Lawfarin and Stocklocker[QUOTED] like this.
  2. Sep 4, 2018 at 9:22 PM
    #182
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    For sure. I am no expert on what is going on with the 2.7L ecoboost as the vehicle is a work truck I am given to drive, so it is much more of an “appliance” in my life than my Taco. I just put 87 in it and drive it like you would a work truck, and it behaves just fine.
    Alesimo likes this.
  3. Sep 4, 2018 at 10:34 PM
    #183
    Jorge3098
    Jorge3098 Active Member
    Jorge
    Bay Area, CA
    2016 Toyota Tacoma TRD OFF ROAD Double Cab
    I'm definitely subscribing to see how this develops.
  4. Sep 5, 2018 at 4:18 AM
    #184
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    It may not be a matter of not being able to swing the 93, but just living somewhere the pumps only go to 91. I know around me the closest place I can get 93 or better is the track
  5. Sep 5, 2018 at 4:42 AM
    #185
    bbrown
    bbrown Well-Known Member
    Buster
    Geauga County Ohio
    '17 Super White TRD-OR DCSB 6-SPD
    255/85R16 ST MAXX
    Is there really a debate? Synthetic is the only option for 0W-20. :cheers:
  6. Sep 5, 2018 at 5:09 AM
    #186
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    There will be no 87 octane tune option for this kit.
    Remember, there is a big difference in static compression ratio between the ecoboost and the 2GR-FKS.
    The stock Tacoma ECU cannot control a wastegate, but we have our MAFT box that can do all sorts of stuff :)
    Also, yes you can run 87 octane in the ecoboost, but you severely hinder it's performance and bring yourself to a thin margin before detonation becomes a serious issue. The ECU then has to do various things like restrict throttle, cut out ignition, dump fuel, lower boost.
    It is simply not safe to attempt 87 on this truck with boost. It has a hard enough time with 87 with no boost at all due to the way the ignition strategy is.
    I am super excited for this.
    Already working with the Turbocharger manufacture to see what we can do. Definitely want to TT a Tundra next.
  7. Sep 5, 2018 at 5:27 AM
    #187
    AnotherUser256
    AnotherUser256 Well-Known Member
    Magnuson TVS1900 Supercharger with 87mm pulley, Catted OVTune dumptubes, Doug Thorley 2.5in y-pipe, custom mufflers, 76mm Tundra throttle body, 5.29 Yukon gears, JamesT custom fuel rails, Yotawerx 87mm tune, Eibach Pro Truck Stage 2 suspension. And some other stuff.
    Matt:
    Assuming stock a Tacoma is about 220 to 230 whp, how reliable will +350whp be? That is a significant increase. Can a stock 2GR-FKS handle that or are those numbers for the more "advanced" kits where internals are swapped out? Also will the transmission reliably handle the power?
  8. Sep 5, 2018 at 5:31 AM
    #188
    OVTune
    OVTune
    My test truck will take the beating to see how much power can reliably be held, but 350whp does not scare me at all with this engine. I will also be pushing it much further. 12psi to get started..
    Remember this same engine is in the Camry making "30hp" more and revving and extra 700 rpm. Our engine is an electronically neutered version of the 2GR-FKS
    Hank Heel, mZiggy, Chipi3s and 4 others like this.
  9. Sep 5, 2018 at 5:40 AM
    #189
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Is it neutered only to help long term reliability or are there other reasons you think?
  10. Sep 5, 2018 at 5:48 AM
    #190
    OVTune
    OVTune
    I don't see it as a reliability issue more as a utility thing. What benefit is there to buying a 300hp truck if you get 300hp at damn near 7000 rpm.
    Having a truck that has a rev limiter @6700 is kind of pointless, and selling a truck that quotes 300hp @ 6700 is also a hard sell I think.
    the same engine in the camry revs higher and makes more, in the lexus IS350, GS350, revs higher and makes more. Nothing in the ECU is different.
  11. Sep 5, 2018 at 5:51 AM
    #191
    iPaint
    iPaint Well-Known Member
    Nebraska
    2017 TRD OR DC 4x4 AT
    So, if a 2GR-FSE makes 400whp+ @ 7psi, and you are pushing this 2GR to 12 psi, that’s probably in the neighborhood of 450-500whp?
  12. Sep 5, 2018 at 10:45 AM
    #192
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    400whp tacoma sounds amazing x.x
    double_duez and mZiggy like this.
  13. Sep 5, 2018 at 11:24 AM
    #193
    Shellshock
    Iowa
    I wish I had a 35 gallon fuel tank for the terrible fuel economy I'd be getting with that kind of power :(
    mZiggy and TheTacoChrist like this.
  14. Sep 5, 2018 at 11:33 AM
    #194
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    marazaii, mZiggy and Prairie Hawk like this.
  15. Sep 5, 2018 at 11:38 AM
    #195
    Shellshock
    Iowa
    TheTacoChrist likes this.
  16. Sep 5, 2018 at 12:00 PM
    #196
    TheTacoChrist
    TheTacoChrist Well-Known Member
    Dick
    2018 TRD PRO Taco
    Lettuce removed Ghost pepper sauce added Subbed: Tortured baby cow for tofu.
    They don’t have the adapter plates ready for the 2018+ Tacoma’s yet either.
    I’ve been checking in every month to see if they are ready yet.
    Really need that extra fuel for some piece of mind.
    On a different note,
    Where should I look for springs to handle the extra weight of all of my armor and extra gas, and equipment?
  17. Sep 5, 2018 at 1:05 PM
    #197
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Maybe in a suspension related thread? I dunno, just guessing :):thumbsup::rofl::anonymous:
  18. Sep 5, 2018 at 1:22 PM
    #198
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Yeah, there's good reasons Toyota is well known as one of the best engine builders out there. They might not be flashy, but they're pretty much always incredibly over-engineered for their intended purpose and as a result respond relatively well to modifications for power as long as the running conditions of the motor have not noticably changed. I trust that the injectors and other fuel system upgrades @OVTune has planned along with his noted tuning abilities will get us a reliable turbo platform, coupled with the fact that he's been talking relatively conservative turbo setups as far as I can tell. I for one can't wait to see the final result... My whole build has been leading up the moment boost becomes readily available :burnrubber:
    Chipi3s likes this.
  19. Sep 5, 2018 at 1:28 PM
    #199
    stevotivo12
    Stephen
    My guess would be at 2500 rpm you're talking double the power output we have now. I would guess a V6 taco is making about 120hp at 2500 currently, I think 250hp at 2500 rpm is achievable, judging based on my experience with twin turbo 4 cylinder setup in the Range Rover evoque and twin turbo 6 cylinder in the Ford explorer sport 3.5 ecoboost. Both are absolute rockets from about 2200 rpm on though on the range rovers larger turbos there is a noticeable lag until then, but as Matt mentioned you'd be hard pressed to find a smaller turbo than the 3.5 ecoboost ones and that thing can move in a straight line
  20. Sep 5, 2018 at 1:58 PM
    #200
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    One thing to consider from your post is that the Explorer although a bit heavier is also AWD. One issue is going to be with the lightness of our truck’s rear ends.
    You would think it would make them WAY faster overall (and in some aspects it will), but with a shitload of power with a light rear end the traction can also be an issue. I know talking about traction breaking in a Taco is funny, but at 400 hp it came definitely come into play when you stomp it for sure.
    I am really wanting to see what Mat has as far as numbers, overall specs, and videos of an actual truck performing in real time to give us a legit big picture of what we are going to be getting.
    Chipi3s likes this.
Thread Status:
