OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jun 23, 2019 at 7:31 PM
    #1981
    RRRepsol
    RRRepsol Member
    Nate
    2019 Cement Tacoma TRD Off-Road
    Brand spankin'
  2. Jun 23, 2019 at 7:49 PM
    #1982
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    It means URD is building the kit with OvTune ....
    thewarriordinghy and joey.taco like this.
  3. Jun 23, 2019 at 8:49 PM
    #1983
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Ahahah. Yes. Give me maximum boost
  4. Jun 23, 2019 at 10:16 PM
    #1984
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    I am up for a SC even if its more complex and expensive than a turbo. That low end get up and go is what the 3rd gen Tacomas desperately need. I heard that superchargers can slightly improve fuel economy, would that be true for this truck?
  5. Jun 23, 2019 at 10:25 PM
    #1985
    RC84
    RC84 Well-Known Member
    3G Double Cab TRD OR
    SCS F5 - 17x8.5 Matte Gunmetal Cooper ST Maxx - 255.80.17
    Both turbo and sc has the potential to increase mpg...highway. Overall, the turbo should be more efficient.
    Also, a turbo is going to be more complex vs a sc.
    Turbo also has the potential for better low end vs sc...good example would be fords ecoboost motors.
    Sleipnir, Reh5108 and GillyLink like this.
  6. Jun 23, 2019 at 10:38 PM
    #1986
    Kclamer
    Konstantin
    Seems like everyone has two opinions that are completely opposite each other, some say turbo lags and boost comes on later, some say SC spools up with the cranck so immediate boost. I would think that with a SC the power is always predictable, you push a pedal the engine revs, power is there. I owned an Audi S4 with a twin turbo and that thing took forever to boost. Wheres a shop owner had a SC V8 Audi and the thing would snap your neck off every time he floored it.
  7. Jun 23, 2019 at 10:58 PM
    #1987
    nubbins
    nubbins Member
    SCs only improve MPGs if you drive like you never installed the SC, and conservatively at that.
    SC power is instant, but IMO because it's steady and always there there's no thrill of a slightly delayed head-snapping pull like on a twin turbo. SC reminds me more of a hopped up NA motor, whereas turbo usually has a wonderful torque range between 1500-4000 in your typical application.
  8. Jun 23, 2019 at 11:04 PM
    #1988
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Nice. Glad twins is back on the board. Love the diff options too. Good job @OVTune
  9. Jun 23, 2019 at 11:36 PM
    #1989
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Hey, by any chance can you turn off the ABS module ?
    Just put a 4.5 LT kit on the front and putting a full floater in the rear so I no longer have any ABS cables connected
  10. Jun 24, 2019 at 12:39 AM
    #1990
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Most people who suggest turbos are down low point to the Ecoboost, which is a unique engine in that Ford went for power down low with twins instead of max HP numbers. In general a supercharger pulls harder off the line which is why you find them on the fastest accelerating custom dragsters. That being said there is no reason why OVTune couldn't size the turbos to be impressive down low. For an average driver though a constant pull over lag then heavy boost might be more appeasing. That being said some guys can't live without that blowoff hiss :p.
    RyanL likes this.
  11. Jun 24, 2019 at 3:55 AM
    #1991
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Not working with URD on this one
  12. Jun 24, 2019 at 4:14 AM
    #1992
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    @OVTune would it be a reasonably safe assumption that the stage 1 kit linked on your website will be ideal for those with OEM exhaust setups, nothing aftermarket, and not looking for max power possible? Or will all FI kits essentially require your dump tubes at a minimum? Personally, I've got the OEM "headers" and the TRD exhaust, and it'd just be convenient to run that with FI, even though the setup would obviously be more restrictive.
  13. Jun 24, 2019 at 5:57 AM
    #1993
    NamelessTaco
    NamelessTaco Well-Known Member
    Jeremy
    Washington MO
    N/A
    A centrifugal supercharger doesn't have instant power! Its connected to the crank so power is even with the RPM.
    https://youtu.be/mZ4EiKsoMzg
    Refer to that video there, and their running a Rotex SC, and they even show the graphs showing the direct relation of RPM to boost production for a SC. Properly sized turbos for the engine came on and makes more HP for same PSI
  14. Jun 24, 2019 at 6:14 AM
    #1994
    treimche
    treimche Well-Known Member
    Fargo, ND
    All these arguments are completely pointless until you know exactly what turbo and supercharger will be included with each kit. Turbos are more efficient, and much more flexible than superchargers, when properly sized for the engine. Small-ish ball bearing turbo on a 3.5L motor will spool VERY fast, and when properly tuned, spool time will be minimal.
    xxTacocaTxx, GillyLink and Reh5108 like this.
  15. Jun 24, 2019 at 6:52 AM
    #1995
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    I agree, and I believe he mentioned the turbocharger already didn't he? GT something it's a few pages back I thought? Turbos are more complicated to install but the gain is incredibly worthwhile. That video shows the under the curve which is an amazing feeling!
  16. Jun 24, 2019 at 6:58 AM
    #1996
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    It's impossible to run turbos or SC with 87 oct correct?
    Sadly, I drive 25k miles or more a year so that would be like an extra $1k in gas a year, my thinking is that money + SC/turbo cost could go to a bigger engine/vehicle upgrade instead like a 5.7 tundra or upcoming turbo 2021 tundra.
    harlequin_forest likes this.
  17. Jun 24, 2019 at 7:10 AM
    #1997
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    Some engine yes you can but performance is reduced cause detonation risk. All youd gain is a v8 with same MPG and less acceleration and so on, and bigger off road truck, so not sure your gonna gain much of anything
    Crimson Flam3s likes this.
  18. Jun 24, 2019 at 7:23 AM
    #1998
    Juice33
    Juice33 Well-Known Member
    L.J.
    Mass
    2018 6MT Tacoma TRD Pro
    Not necessarily. If you want more power, you are going to have to run higher octane. It may be possible to do a baseline tune that only uses 87, it won't have a lot of power, but I am sure it could still be an improvement over stock.
    I don't want or need a bigger truck so getting a bigger truck with a bigger engine is out of the question. Now, depending on what the Bronco looks like and has for a drive train (Raptor Bronco!!!???), then I will have to put this turbo/SC kit up against that.
  19. Jun 24, 2019 at 7:29 AM
    #1999
    RedTacoATX
    RedTacoATX Well-Known Member
    Bryan
    Austin, TX
    Black 2016 Tacoma TRD skeeewp DCSB & 1992 DLX RC V6 4X4 MT 35's FTW
    None....yet.
  20. Jun 24, 2019 at 8:42 AM
    #2000
    mZiggy
    mZiggy Honey badger
    Marc
    Unconfirmed of course, but there's been rumors of a 7-speed manual trans, with the speculation being that the extra gear is a lower gear and something more appropriate for off-road/low range
Thread Status:
