OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jul 5, 2019 at 8:29 AM
    #2121
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    This^^
    You should probably do some of your own research before making assumptions and bashing a vendor in his own thread. Not trying to white knight, but you’re acting like a dick.
  2. Jul 5, 2019 at 8:36 AM
    #2122
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    We have been working on a 4.88 tune (which will be released with 2.0).. we work on more than 1 thing at once.
    iDrew, jholc21, PvilleJohn and 16 others like this.
  3. Jul 5, 2019 at 10:04 AM
    #2123
    scifidelity
    scifidelity Well-Known Member
    Ok. Fair. Good to know he makes the snails and blowers. Makes sense he makes a tube for them in that case. I would guess more people have re-geared 3rd gens than have turbo 3rd gens. It’s more common than you think and literally everyone would do it if they could test drive a re-geared one. Should have come from the factory with 4.88, and anyone adding weight and/ or large tires should go 5.29.
    Most importantly, I made assumptions in my original post and it had negative undertones and I’m sorry for that. I can own it. Looking forward to the tune for 4.88!!!
  4. Jul 5, 2019 at 3:31 PM
    #2124
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Technically you are correct.
    Other than OVTune's trucks (3?), there are no other turbo/supercharged 3rd gens on the market.
    Since FI is not possible without this tune.
    OVTune will be first in creating the one and only 3rd gen FI market.
  5. Jul 5, 2019 at 3:36 PM
    #2125
    su.b.rat
    su.b.rat broken truck
    regearing is out of order if the motor is running well under its reliable power output level as demonstrated by the 2GR-FKS in other applications. re-tune the motor and optimize the engine hardware we have, and most will not need to consider regearing. yes regearing is great but the motor is tunable and enough for most. $700 vs. $2k+. and then mileage etc...
  6. Jul 5, 2019 at 4:23 PM
    #2126
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Not sure how tuning would effect re-gearing and vice versa (maybe my own ignorance plus I drive a 6spd MT) . I see them as distinct separate issues that can help drivability. Tuning optimizes engine performance & efficiency which is independent of the gears. Tuning is dynamic and highly variable with engine speed, temp, fuel, ignition timing, etc. Re-gearing essentially increases torque while decreasing wheel speed (acceleration) but is constant and not related to how the engines runs. I guess if you dramatically increase HP & torque with a tune then re-gearing might not be necessary but if your truck is too heavy with larger diameter tires then lower gears will likely always be needed to drive the truck effectively and efficiently. (Example is trying to take off from a stop in 4th gear of a 500 HP car... can be done but acceleration is compromised because of poor gear ratio). I do agree that both OVTune and 4.88/5.29 gears can significantly improve drivability of these trucks but don't see how they are directly related.
  7. Jul 5, 2019 at 6:02 PM
    #2127
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Well we only have another 27hr before the week is over... anxiously waiting for the news:burnrubber:
    Shellshock and Caboose117 like this.
  8. Jul 5, 2019 at 9:48 PM
    #2128
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    jerzsubbie likes this.
  9. Jul 6, 2019 at 12:42 AM
    #2129
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Intercooler Looks like RIPP superchargers. If it is, most likely Centrifugal type of setup.
  10. Jul 6, 2019 at 5:24 AM
    #2130
    jerzsubbie
    Davidson, NC
    ‘13 GX460
    He did say “it will be tucked down in here”, so must be centrifugal since a root style only goes one place.
    +100hp to the wheels sounds great. Raptor-like power in a smaller truck = winning!
    Edit: I’m more interested in what RIPP’s tuning solution will be since we know OVTune’s tuning is proven and takes care of the trans.
    Alesimo likes this.
  11. Jul 6, 2019 at 10:21 AM
    #2131
    OVTune
    OVTune
    slow.taco and Inferno__Taco like this.
  12. Jul 6, 2019 at 4:17 PM
    #2132
    ratcityrain
    Seattle, WA
    Cool, but I'll wait for yours to release
    slow.taco likes this.
  13. Jul 7, 2019 at 11:41 AM
    #2133
    Captndarty
    Captndarty Well-Known Member
    2017 Magnetic Grey limited
    Good luck with that ......
    Brostjoe, shane100700 and TS7xTaco like this.
  14. Jul 7, 2019 at 1:06 PM
    #2134
    CaptainVoodoo
    CaptainVoodoo Well-Known Member
    Charles
    Quebec
    2019 TRD Pro Voodoo Blue M/T
    None yet
    As I said, hopefully lol I'm still waiting for him to put the 7k redline in the 2019 04B40 tune
    GillyLink likes this.
  15. Jul 7, 2019 at 1:29 PM
    #2135
    RedLantern
    Honolulu, Hi
    Looks like gadgets been busy too. Unless it’s just a sticker :rofl:
  16. Jul 7, 2019 at 1:33 PM
    #2136
    OVTune
    OVTune
    Nice. Glad to see more companies listening to 3rd gen owners.
  17. Jul 7, 2019 at 1:36 PM
    #2137
    RedLantern
    Honolulu, Hi
    Agreed! I’ve had both but I’m stuck on turbo’s.
    Lord Helmet likes this.
  18. Jul 7, 2019 at 1:40 PM
    #2138
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Magnuson is going to be unfashionably late to the 3GT boost party lol
    ratcityrain and Anchovy like this.
  19. Jul 7, 2019 at 1:42 PM
    #2139
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    Good to see multiple people going at the boost. The push is on.
  20. Jul 7, 2019 at 1:57 PM
    #2140
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    @Chipi3s and I used to break their balls a lot on Instagram and we always got under their skin :rofl:
Thread Status:
