OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jul 9, 2019 at 6:22 AM
    #2301
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    @OVTune
    How do Ecoboost engines make boost using 87? Wonder if that technology/method could be integrated in the tacoma to retard the timing.
  2. Jul 9, 2019 at 6:29 AM
    #2302
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Reducing ignition timing.
    The compression ratio of the ecoboost 3.5L engine is 10:1. So with significantly retarded ignition timing it's possible to boost with 87 octane due to direct injection.
    However our engine 2GR-FKS the compression ratio is 11.8:1.
    This compression ratio allows for more torque to be created with less boost pressure, but because the static compression ratio is this high, we do not have plans to make it 87 octane safe.
  3. Jul 9, 2019 at 6:35 AM
    #2303
    Crimson Flam3s
    I see, that's very interesting! Thanks for your response.
    Does retarding ignition timing when using lowet octanes have any other adverse effects besides lower power output in EB engines?
    slow.taco and SouthtownTaco like this.
  4. Jul 9, 2019 at 9:19 AM
    #2304
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Im pretty exited for this thread! I can’t wait to see what the SC results are!
  5. Jul 9, 2019 at 9:19 AM
    #2305
    SteddyTeddy
    SteddyTeddy Active Member
    Ted
    2016 Tacoma TRD Sport
    Retarding the timing is used to help prevent predetonation. With higher compression ratio's higher octane fuel is the only safe way to keep from melting a piston or 6.
    Crimson Flam3s and jerzsubbie like this.
  6. Jul 9, 2019 at 10:24 AM
    #2306
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Or Miller Cycle :cool:
  7. Jul 9, 2019 at 10:26 AM
    #2307
    andrewbrandon19
    andrewbrandon19 Well-Known Member
    @OVTune
    Do you know yet what the power curve for the K04 option will look like compared to the K03?
  8. Jul 9, 2019 at 10:29 AM
    #2308
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    ^+1.
    Gearing is independent of engine performance (with exception of AT having ECU controlling shift points). You can have all the added HP and torque but if you are geared too high (as with increased diameter tires and increased weight), the truck is at a mechanical disadvantage regardless of HP. Used to think that the 18 wheeler diesels relied on lots of HP & torque to pull heavy loads but its all actually proper gearing (up to 18 spd transmissions). This concept is even more important for offroading applications. Otherwise increased HP/torque will just be burning out clutches quicker.
    slow.taco and Caboose117[QUOTED] like this.
  9. Jul 9, 2019 at 10:40 AM
    #2309
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Yeah, made a ton of sense when he explained it!
  10. Jul 9, 2019 at 12:03 PM
    #2310
    Jmanrex
    Jmanrex Well-Known Member
    GA
    2018 PRO cavalry
    apologies if it was already mentioned but can another vendors dump pipes be used with your setup?
    also , will you be offering your pipes ceramic coated?
  11. Jul 9, 2019 at 1:30 PM
    #2311
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    @OVTune would it be possible to move the secondary cats down stream to help with a sniffer test for emissions? Or would it not be worth it? (I know a guy who can do a custom exhaust for me, I’m just wondering)
  12. Jul 9, 2019 at 1:36 PM
    #2312
    OVTune
    OVTune
    I have only tested fitment with ours.
    Ours our stainless steel. I have not considered offering coating.
    With front cats it should pass emissions
  13. Jul 9, 2019 at 1:49 PM
    #2313
    CaptainVoodoo
    CaptainVoodoo Well-Known Member
    Charles
    Quebec
    2019 TRD Pro Voodoo Blue M/T
    None yet
    @OVTune I sent you an email this morning but I have yet to get an answer, seems quicker here lol
    I can't go to check out for the dump pipes because it says there are no shipping methods available for my address, can't you ship north of the border?
  14. Jul 9, 2019 at 2:24 PM
    #2314
    OVTune
    OVTune
    Hmm.. I'll look into it.
    Usually when I am on the forum I am doing tickets at the same time, however with the current amount of tickets right now it's going to be a 24-48 hour wait on replies.
  15. Jul 9, 2019 at 2:27 PM
    #2315
    12thManQuicksand
    12thManQuicksand Active Member
    Austin
    '18 TRD Off Road 4X4
    Ship them to me and I’ll send them up to you :thumbsup:
    shane100700 and joey.taco like this.
  16. Jul 9, 2019 at 2:33 PM
    #2316
    CaptainVoodoo
    Charles
    Quebec
    None yet
    Are you a Nigerian Prince? Lol
    I figured you were busy with tickets more than usual, no rush I'm at work and won't be home until mid-august, not like I need them ASAP
    Thud, PB FAB, jerzsubbie and 4 others like this.
  17. Jul 9, 2019 at 3:23 PM
    #2317
    motogeek
    motogeek Taco Tueday? Tacos Everyday!
    Tacomeat
    America
    Tacoma SR5 TRD 4x4
    2.5 Toytech Inch Lift 285 Cooper SST
    Already Sold Out! ? >> Was hoping for something under 3k.. :( I was quoted to do a lexus v8 for that price.
  18. Jul 9, 2019 at 3:24 PM
    #2318
    Anchovy
    TRD Ferguson
    That’s dreaming territory
  19. Jul 9, 2019 at 3:46 PM
    #2319
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    A Lexus V8 in a Tacoma for $6,000.... what are you waiting for.
  20. Jul 9, 2019 at 3:47 PM
    #2320
    Anchovy
    TRD Ferguson
    You really have me contemplating on my next big buy for my truck, the twin turbos are really convincing :drool:
    slow.taco and Chipi3s like this.
Thread Status:
