OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Sep 5, 2018 at 7:08 PM
    #241
    treimche
    treimche Well-Known Member
    Fargo, ND
    Did anyone else order it yet?
  2. Sep 5, 2018 at 7:08 PM
    #242
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    So @OVTune, I expect that if we get the base kit, we can upgrade to a higher level later on when/if we want to?
    Chipi3s likes this.
  3. Sep 5, 2018 at 7:09 PM
    #243
    Anchovy
    TRD Ferguson
    Using less fuel to do the same work doesn't mean you use less fuel? Confusing...
  4. Sep 5, 2018 at 7:09 PM
    #244
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Did
    Did not know the transmission is used in diesels
  5. Sep 5, 2018 at 7:10 PM
    #245
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    What you are failing to realize is that the engines use the exact same fuel. The turbo engine generates more power but it’s power you don’t use. Typically more air means more fuel, more fuel is less mpg.
    The same 3.5 liter is used in the Ford GT. More power, lighter car yet gets 14 mpg combined. By your logic it should have significantly better mpg.
    SC4333 likes this.
  6. Sep 5, 2018 at 7:10 PM
    #246
    BeaverNation
    BeaverNation Well-Known Member
  7. Sep 5, 2018 at 7:13 PM
    #247
    crazychris4124
    crazychris4124 Earn those pinstripes
    Westchester County, NY
    '17 Inferno Moneypit
    Too many but also not enough mods
    $0.00 seems a little expensive but I'll do it
  8. Sep 5, 2018 at 7:16 PM
    #248
    Hank Heel
    Hank Heel Well-Known Member
    WA
    I don’t think these exact ones, but Aisin transmissions are usually used on HD RAM’s
  9. Sep 5, 2018 at 7:17 PM
    #249
    TelosHedge
    TelosHedge tiny moron
    Central NC
    18 Inferno Sport DCSB 4x2
    We're talking about at least a 100whp increase. It doesn't matter if you use a turbo, supercharger, imagination, or Fred Flinstone's feet - power does not come free. If you introduce more air via turbo, you need more fuel to compensate.
    Keep in mind that while turbocharging CAN be done to increase efficiency, it's not done in the same way as when turbocharging to add power. In our case, taking a 3.5 V6 and throwing 2 turbos on it is going to increase output, at the expense of requiring more fuel to make it. If you wanted to be more economical, take the 3.5 out, and put a smaller motor in with a small turbo on top of it. That way you end up with a smaller displacement engine for efficiency, and then more flow via the turbo when power is needed. This is how my turbo S2000 made 450+whp and still got 30mpg - but only when i kept the thing from spooling!
    Step on the throttle, and you have to pay. There's just no such thing as free energy.
    4drtaco03, Watt maker, GDT and 3 others like this.
  10. Sep 5, 2018 at 7:18 PM
    #250
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
  11. Sep 5, 2018 at 7:19 PM
    #251
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    Why go through all this trouble to swap to a factory Tcase just for a manual shifter? Just get an AtlasII and have 2 manual shifters and a plethera of gear/range options. Same amount of work and prolly for nearly the same price
  12. Sep 5, 2018 at 7:23 PM
    #252
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    Shit too many options!
  13. Sep 5, 2018 at 7:24 PM
    #253
    E$Yota
    Ethan
    Dothan, AL
    Added to cart, about to buy!
    Edit:
    Wow free shipping too!
    Shellshock, Lawfarin, mZiggy and 3 others like this.
  14. Sep 5, 2018 at 7:27 PM
    #254
    Comb
    Comb Known Member
    Shipping is probably like 6 grand though.
    xxTacocaTxx, KkelX4 and mZiggy like this.
  15. Sep 5, 2018 at 7:28 PM
    #255
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    650whp tacoma here i come baby!
  16. Sep 5, 2018 at 7:28 PM
    #256
    TelosHedge
    Central NC
    Do not confuse what the right pedal does. In cable-driven cars, the throttle opened the throttle body which forces more AIR into the motor. The ECU in a fuel injected vehicle will read that amount of air via MAP or MAF sensor and then tell the injectors to add fuel to compensate. Yes, you can 'lean out' that mixture with aftermarket tuning to produce more power to an extent, but that does not exactly equate to around town fuel mileage because those are two different driving scenarios that call for two different fuel curves.
    Now consider our modern day drive-by-wire cars. The right pedal does not necessarily have to correlate directly to the throttle body at all. As has been said before, the car knows when you push the pedal, you're asking for more power. How the ECU handles that request can be interpreted as something you do not like - thus, the OVTune was born.
    TRACKER54 likes this.
  17. Sep 5, 2018 at 7:32 PM
    #257
    JoeCOVA
    Joe
    Colorado Springs
    Ya I would just spend the money on a taco box. You get a lever and dual Tcases
  18. Sep 5, 2018 at 7:32 PM
    #258
    E$Yota
    Ethan
    Dothan, AL
    100% confirmation that my purchase is free. Thanks Mat. Do you take tips?
    Shellshock, mZiggy and Chipi3s like this.
  19. Sep 5, 2018 at 7:34 PM
    #259
    Chipi3s
    San Diego
    He basicly posted the rest of the info we have all been waiting for lol... now all we need is price. Damn 650whp.....
  20. Sep 5, 2018 at 7:36 PM
    #260
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Lmfao i feel like the webpage was published on accident. It's clearly incomplete and prior to Mat's projected date to release info
    Chipi3s likes this.
Thread Status:
