OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jul 17, 2019 at 3:12 PM
    #2641
    Shellshock
    Iowa
    What if you bolt on a new high capacity oil pan?
    BassAckwards, Skydvrr, Torspd and 3 others like this.
  2. Jul 17, 2019 at 5:12 PM
    #2642
    soggyBottom
    soggyBottom Well-Known Member
    I wondered about that. The tapping part is easy. It's the removing and reinstalling that I don't want to do.
  3. Jul 17, 2019 at 6:28 PM
    #2643
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    The oil pan is tiny, it’s not like a full oil pan front to rear. It’s probably 5 by 8 inches. Super easy to access.
    Skydvrr, skyking3 and GreyBaldTaco like this.
  4. Jul 17, 2019 at 6:37 PM
    #2644
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I did my first oil change myself on mine this weekend. I was amazed at how small it was and could see how people drain the tranny if they aren't paying attention.
    Running Board Man likes this.
  5. Jul 17, 2019 at 6:49 PM
    #2645
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Is there an upper and lower oil pan?
  6. Jul 17, 2019 at 8:21 PM
    #2646
    treimche
    treimche Well-Known Member
    Fargo, ND
    With the turbos mounted so low and far back, there might be the need for a pump to get oil to return back to the oil pan. Usually turbos are placed above the oil pan so gravity will make the oil drain back into the pan. There are other methods of achieving this though too, like using a scavenging oil pump system.
  7. Jul 17, 2019 at 8:26 PM
    #2647
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    There will be a scavenge pump in the turbo kit from my understanding
    Cementoffroad and GillyLink like this.
  8. Jul 17, 2019 at 8:30 PM
    #2648
    Cementoffroad
    Cementoffroad Well-Known Member
    Josh
    18 Cement OR
    Not only that but -10 return line at a minimum too to make sure the oil drains quick enough. Im interested in seeing how this setup lasts over 20-30k miles. Maybe the one picture makes it look worse then it is, so ill reserve full judgement until i see more.
  9. Jul 17, 2019 at 8:51 PM
    #2649
    su.b.rat
    su.b.rat broken truck
    are the oiling requirements similar with a SC?
  10. Jul 17, 2019 at 8:53 PM
    #2650
    Cementoffroad
    Josh
    18 Cement OR
    Rotrex are self contained units i believe
    su.b.rat[QUOTED] and SC4333 like this.
  11. Jul 17, 2019 at 8:56 PM
    #2651
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
  12. Jul 17, 2019 at 11:19 PM
    #2652
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    GillyLink likes this.
  13. Jul 18, 2019 at 11:35 AM
    #2653
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Got the wife on board last night, now I don't know which one to go with lol
    05Taco4x4, hbaade, skyking3 and 2 others like this.
  14. Jul 18, 2019 at 11:48 AM
    #2654
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Turbo is more power, but more complicated.
    You’ve already done the hardest part. Get the turbo.
  15. Jul 18, 2019 at 11:50 AM
    #2655
    ratcityrain
    Seattle, WA
    I am pretty certain I want the Turbo.
  16. Jul 18, 2019 at 12:05 PM
    #2656
    bunz559
    bunz559 Well-Known Member
    Fresno, CA
    2018 Tacoma TRD Off-Road
    Will custom e-tuning be available soon too with the release of these kits?
  17. Jul 18, 2019 at 1:18 PM
    #2657
    soggyBottom
    You should get both.
    GreyBaldTaco likes this.
  18. Jul 18, 2019 at 1:20 PM
    #2658
    eon_blue
    Azusa, CA
    Someone here needs to twin charge their 3rd gen...do it for science
    xxTacocaTxx and GillyLink like this.
  19. Jul 18, 2019 at 1:21 PM
    #2659
    MESO
    State of Jefferson
    compound TT setup
  20. Jul 18, 2019 at 1:22 PM
    #2660
    su.b.rat
    hey my Volvo has both. runs like dream too.
Thread Status:
