OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jul 27, 2019 at 4:16 PM
    #2861
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    something people who drive a Prius worry about, or so I'm told
  2. Jul 27, 2019 at 4:42 PM
    #2862
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    To get better fuel economy you're going to have to keep it largely out of boost, and where's the fun in that...boost is why you're installing the thing. Also the higher octane fuel cost will negate it anyway. Anyone using the "potentially better MPG mindset" to persuade them into getting a turbo/supercharger is in for a rude awakening
  3. Jul 27, 2019 at 5:09 PM
    #2863
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    But should do it anyway. :headbang:
    GillyLink and eon_blue[QUOTED] like this.
  4. Jul 27, 2019 at 5:37 PM
    #2864
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
  5. Jul 27, 2019 at 7:21 PM
    #2865
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    This my my love/hate fuel economy for my Cummins. Majority of the time, I’m getting 22-24 MPG. But when I get my foot in it, oh boy.
    GillyLink likes this.
  6. Jul 27, 2019 at 10:28 PM
    #2866
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    What if you’re already lead foot because you want to have X amount of power on tap, then with turbos that same power level comes on much earlier thus lower cruising RPM?
    At least in my mind, this seems to be how one could actually increase MPG. More power on tap = less lead foot to achieve same speed/acceleration. No??
  7. Jul 27, 2019 at 11:15 PM
    #2867
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Cheaper is only one facet.
  8. Jul 28, 2019 at 10:32 AM
    #2868
    soggyBottom
    soggyBottom Well-Known Member
    Without having these kits done and a decent sample size, I don't think the data is available yet. As others have noted, the FI will allow the engine to consume more fuel. I suspect your question was more of a "what can I expect to get in normal highway/city driving compared to stock". There is a lot of circumstantial info available online that rotex super chargers and various turbochargers do increased fuel economy.
  9. Jul 28, 2019 at 11:23 AM
    #2869
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    We need some more teaser vids this week!
    d.ustn, Amchuge and Chipi3s like this.
  10. Jul 30, 2019 at 6:36 AM
    #2870
    1997tacomav6
    Denver
    Because this supercharger is not a roots style does the boost get adjusted by the pulley
    only or a waste gate like the turbo?
    When going from sea level to 6000 feet Denver or 10,000 feet over the mountain divide depending on original boost you can actually loose 2 or 3 pounds of boost easily on a roots type supercharger.
    Do either of these setups, supercharger or twin turbo compensate to spin faster to keep
    the original 6 pounds of boost? (I think is the setting) when operating at altitude or will the tune keep the supercharger and turbo at the original rpms and loose boost with altitude?
    The higher the altitude you go the supercharger or turbo will have to spin much faster with a different tune if so to keep the original 6 pounds of boost.
    If sea level your adding 100 extra hp and there is no compensation for boost, or a different tune, altitude loss hp can be 30-40 hp less depending.
    Amchuge, MGMSangTaco and Brostjoe like this.
  11. Jul 30, 2019 at 9:20 AM
    #2871
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
  12. Jul 30, 2019 at 11:40 AM
    #2872
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    Yes, just change the pulley to raise/lower boost. Only pulley down to what you've been tuned for, but you can go up to lower boost without a re-tune.
  13. Jul 30, 2019 at 4:18 PM
    #2873
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
  14. Jul 30, 2019 at 5:45 PM
    #2874
    1997tacomav6
    Denver
    What about for the turbo?
    Will it compensate and keep the same 6 pound boost at sea level to the altitude 10,000 feet?
    With the same tune?
    Brostjoe likes this.
  15. Jul 30, 2019 at 5:57 PM
    #2875
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    Correct me if I'm wrong, but I believe the turbos have a waste gate set to 8 psi or whatever he wants to run. The turbos should boost to that 8 psi and the waste gate will open at that pressure and not allow over boost. So the altitude shouldn't really matter because the waste gates are set to open at that specific pressure.
  16. Jul 30, 2019 at 6:48 PM
    #2876
    1997tacomav6
    Denver
    This website explains it in detail and apparently some turbo do not have waste gates but most do.
    https://www.dieselarmy.com/engine-tech/boosting-altitude-elevation-effects-turbochargers/
  17. Jul 30, 2019 at 7:21 PM
    #2877
    soggyBottom
    No, you will have 8psi of pressure over ambient. Pressure is normally regulated by a metal spring that should be consistent no mater the altitude. BUT ambient pressure normally presses on the back side (spring side) of the diafram meaning that boost pressure is relative to the altitude. There may be another wastegate design that I'm not familiar with but as far as I know, this is consistent with all mechanical WGs.
    Pikes peak cars generally run larger turbos than would be idea at the start of the race causing additional lag. Using electronic boost controllers, the boost is gradually raised based on the altitude.
    Torspd and Bullnettles like this.
  18. Jul 30, 2019 at 7:22 PM
    #2878
    Skydvrr
    Nick
    YMH
    Black '17 OR
    HPA is the shit.
    1997tacomav6 likes this.
  19. Jul 30, 2019 at 8:33 PM
    #2879
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    That's good info. I know some car manufacturers are using electronically controlled waste gates. My ex had a Chevy sonic that had one. It would actually boost to a pre determined torque given the conditions. It boosted anywhere from 12-18 psi to hit the torque number it was requesting. That car ran just as well at 12k ft as it did in Denver at 5k ft.
    xxTacocaTxx and 1997tacomav6 like this.
  20. Jul 31, 2019 at 5:32 AM
    #2880
    soggyBottom
    I know very little about tuning but I imagine this could be done by trying to burn a specific amount of fuel. I don't think it'll be possible with the Tacoma ecu because of the non-existent I/O to a boost controller.
    It appears there are some post controllers that have built in altimeters. This the the first result on Google
    http://viper.mountainperformance.com/Viper-Electronic-Turbo-Boost-Controller-Compensator_p_31.html
Thread Status:
