OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Aug 4, 2019 at 11:05 PM
    #3121
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    What I meant was that @OVTune mentioned they wouldn't be making 87 octane as an option since they couldn't increase power as much or at all.
    Ecoboost engine's lower compression ratio than the 2GR, is what allows them to use 87 much more effectively. They don't really lose much power compared to 91/93.
    Hell if all we got was a 50 tq/50hp increase with 87 on the SC, I would still be happy with that, but chances are, that isn't achievable.
  2. Aug 4, 2019 at 11:12 PM
    #3122
    Crimson Flam3s
    It's definitely not an easy decision given the price points, but as you mentioned, when it's all said and done, Turbos would likely run more expensive.
    I don't believe an extra 1.5 psi would hurt much, anything under 7-8 psi seems to be safe for most unmodified engines.
    At this point, my only concerns are final SC numbers, mpg loss due to it's parasytic nature, running premium fuel(Which would cost about $7-8k after 5 years given SC cost + extra premium fuel cost) vs simply upgrading to a new vehicle like the next gen tundra which I have been on the fence about.
    Gotta see what comes out first, and by then, hopefully we will have a lot more hands on info and details about SC or TT.
    scifidelity likes this.
  3. Aug 4, 2019 at 11:24 PM
    #3123
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I could probably combine my Taco and Cayman into a Cayenne GTS for about the same price tag. I’d get another 1300 lbs of towing, and 400 lbs of cargo capacity. But I’d give up a pickup bed and a manual weekender...
    Nah, just going to keep what I have and make it work within the limits.
  4. Aug 4, 2019 at 11:25 PM
    #3124
    RushT
    North Texas
    Plus, I don’t like driving that much money as a daily.
  5. Aug 4, 2019 at 11:37 PM
    #3125
    eon_blue
    Azusa, CA
    Ecoboost engines recommend higher octane but will adjust and run fine without it. Unless I'm wrong my understanding on these 3rd gen turbos and S/Cs is that they will require higher octane fuel. Putting 87 in will cause it to run lean and running lean spells death for any engine.
    Same as with the TRD superchargers for 1st and 2nd gens...cannot run 87, you must run 91 minimum.
    =JSG= likes this.
  6. Aug 5, 2019 at 3:10 AM
    #3126
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Not quite. Putting lower octane fuel will cause pre-detonation and/or pinging. Those conditions CAN be caused by running excessively lean, but in this case they would be caused by inferior fuel not having the detonation resistance that premium fuel does
    loading_name likes this.
  7. Aug 5, 2019 at 6:50 AM
    #3127
    NamelessTaco
    NamelessTaco Well-Known Member
    Jeremy
    Washington MO
    N/A
    If you look at the TT vs the SC, have to remember that the SC runs off crank speed so is only good on high end. Specifically more so when it's a centrifugal model. It will be a bit tougher on engine due to drawing power to make it work. But on other hand, the TT when towing will boost even faster due to the engine being stressed more, IE long gears, less shifting, added weight yada yada. For pure fun either is fine, but Turbos are significantly more effective and efficient than a SC engine. That fact is obvious, ford even knew this, that's why their engines are all turbocharged not supercharged, add wastegates and you can make a small turbo hit boost instantly then gate so it wont overboost, such as the EcoBoost, and the OVtuned 3.5 TT, charts show its boost being rapid, even at 5psi if you drove it with a camping trailer like a 5K model uhm, a Jayco model. Stock truck then a tuned TT truck, the TT will have much smoother take off ,cruising and hill pulling, you won't really gain much with a SC unless you have a pulley to make it spin faster than before to up the boost in the *Sweet spot* that you the driver personally run your truck at. I've had the privilege to be in both scenarios, a single turbo, twins and compounds (person 4bt Cummins truck), and a supercharged SS cobalt, and a 750WHP GT500 Shelby, while the SC has a incredible linear pull all the way through unless you're in the top of the revs, the boost is only SO good. Not saying it is not worth it for some, I'm personally after boost everywhere, off idle to mid range and high end.
  8. Aug 5, 2019 at 1:27 PM
    #3128
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Patiently but verrrry anxiously waiting for those 10 PSI dyno numbers!!! :thumbsup::fingerscrossed::bananadance:
    Trock, Doomsday, Chipi3s and 2 others like this.
  9. Aug 5, 2019 at 9:02 PM
    #3129
    TacoMateo
    TacoMateo Well-Known Member
    Nor Cal
    2019 DBLB TRDOR CEMENT
    Hey @OVTune can I get a discount on a turbo setup? If you agree I promise to personally throat punch the first 5 people to complain about their gas mileage after installing a kit.
    I think it would make both of us feel better after all the hard work your doing and reading some of the negative comments.
    Btw I’m just joking.... keep up the good work! Hope To have a tune and kit soon.
  10. Aug 5, 2019 at 9:17 PM
    #3130
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    You would lose so much money on air travel alone. If he was a smart business man, he'd take you up on that deal.
  11. Aug 5, 2019 at 9:26 PM
    #3131
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Fairly certain he’d drive his turbo’ed Taco!
    crigg93 and PB FAB like this.
  12. Aug 5, 2019 at 9:27 PM
    #3132
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Depends on the contract! Either way, fuel would be crazy!
  13. Aug 6, 2019 at 2:29 AM
    #3133
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Grand dude likes this.
  14. Aug 6, 2019 at 4:04 AM
    #3134
    jewboi
    jewboi Well-Known Member
    So I’m just curious what everyone’s thoughts are on how risky the turbos would be on this truck. Mat has already mentioned the gains on the 5psi setup which I’m assuming he is calling the ‘base’ setup.
    How likely is it that the other components of the truck fail with all this added power? I drive a manual so I already know the clutch would be a weak link but I’m curious how far this goes. Seems to me like it’s a ton of added stress on everything from u joints to transfer case, transmission obviously, CV joints, rear end even.
    I’d love to get these turbos and have some serious fun with the truck. I can live with having to get a new clutch. But if I have to start thinking about a tranny swap and blown transfer case it may be a hard no for me.
    Myles G likes this.
  15. Aug 6, 2019 at 4:20 AM
    #3135
    jerzsubbie
    Davidson, NC
    ‘13 GX460
    Valid concern but I’m somewhere between “not concerned” and “don’t care” because:
    1) Toyota is notoriously conservative, taking quality almost to an extreme
    2) I hate the lack of power so much that if it weren’t for this turbo setup, I’d likely be buying a tundra or raptor in the next 12-24mo
    3) fixing broken CVs or other moderately expensive items, maybe even trans, would still be cheaper than buying a new FS truck
    4) While he’s no Toyota engineer, I trust that Mat will do the research and testing to know what these trucks will handle and dial it back from there.
    Trock, xxTacocaTxx and 2001 4x4 like this.
  16. Aug 6, 2019 at 4:45 AM
    #3136
    Anchovy
    TRD Ferguson
    Also mat tortures his test truck so he can find the limits so we don’t have to worry
  17. Aug 6, 2019 at 4:53 AM
    #3137
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I think a lot of that will have to do with how you drive it. If you dump the clutch every time you leave the driveway, red line and bang through the gears, those parts will obviously not live as long. Roll on the power once you are already moving and it won't be so bad. I had an 06 6 speed previously, and I did not have enough faith in that transmission to add any power. I know the new one is different but I don't know anything about it.
    SC4333 likes this.
  18. Aug 6, 2019 at 8:33 PM
    #3138
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    Its all about how you drive, if you dump the clutch with the steering wheel at full lock in 4wd, your CV shafts wont be too happy but that wouldn't be a good idea on a stock truck either.
    Also your transfer case is a torque multiplier (X 2.xx) so when you go into 4lo, you're putting alot more torque through your driveshafts, CVs and rear end then this kit will be putting out
  19. Aug 6, 2019 at 9:34 PM
    #3139
    RushT
    North Texas
    AKGSD likes this.
  20. Aug 9, 2019 at 9:54 PM
    #3140
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
Thread Status:
